Randonneur/Cyclocross/Gravel grinder project
spirito
Re: Randonneur/Cyclocross/Gravel grinder project
Postby spirito » Sat Jan 25, 2014 1:23 pm
koen wrote:
I do understand a very few may have issues but in general it seems majorly overstated.
In your opinion.
But do you understand that telling other people they are wrong for choosing something that clearly works for them might end up with .... :roll:
We all do it though. The moment someone asks me about stand over height I assume that their parents were brother & sister :lol: :P
Postby singlespeedscott » Sat Jan 25, 2014 1:46 pm
koen wrote:First..Its a gravel bike...not a world tt contender.
As I said before LDR is not one to go slow.
koen wrote:... yet along with all other cyclists until the recent decade or so we never thought about q angle
Thats because cranks from 20 years and back actually had lower q factors than their modern day equivalents. People didnt notice it because it wasnt an issue.
koen
Postby koen » Sat Jan 25, 2014 3:28 pm
I didn't say people were wrong to buy the latest spin whether its 29ers or q factor. It's just this is a retro forum and we aren't all about the latest thing.
Some of us are luddites on steel rims :)
Postby ldrcycles » Sat Jan 25, 2014 9:40 pm
I alluded to crank choice a while back but it wasn't particularly clear, the triple in the photos was just what the frame had on it, when i build the bike up it will definitely have double cranks, most likely standard going through an MTB derailleur to an 11-32 cassette. I am contemplating compact cranks but i had them on my first road bike a few years back and HATED them.
The stem in the pic is significantly longer than what it will get, either 80 or 90mm. If anything is hurting more than your legs after a few hours then you're not pushing hard enough :lol: . I remember reading an article ages ago (possibly rivendell?) which talked about the effects of shorter stems as opposed to taller ones. Either way you can be sure i'm not heading out on any odysseys until i've got the position dialled.
I'll have to check the size of the Miyata, but i've got a feeling it's a similar size, in terms of geo and quality it's virtually identical, but the mystery frame wins by virtue of the double bottle mounts on the DT.
Postby ldrcycles » Sat Jan 25, 2014 9:44 pm
Oh forgot to mention, i had triple cranks on an Apollo Concorde a while back and other than the shifting being rubbish (worn rings and junk FD) and hating the ~50t big ring i never had any issues with it. That's the only bike i've managed to clear the Obi Obi on so far :) .
Postby singlespeedscott » Sat Jan 25, 2014 10:50 pm
What's wrong with a 50t chainring?
Postby ldrcycles » Sat Jan 25, 2014 10:54 pm
Oh nothing wrong with it, if you only ever ride up Bellthorpe, everywhere else it's too damn short :D .
koen
Postby koen » Sun Jan 26, 2014 2:42 pm
I like those cranks that came with that bike on OP and they suit my riding. I especially like the granny on occasional mega hills. But the 110mm spider is problematic on big rings. Had a tandem with 55t on 110 and it flexed soo much it sometimes was reluctant to change up. ( plus after all the Q discussion I measured my old bikes and some of the old deore triples are not much different to the road bikes I have. I guess it is affected alot by spindle choice on old square taper bikes...something harder to change on new BBs)
LugNut
Postby LugNut » Tue Mar 04, 2014 2:08 am
One of us! One of us! One of us!
I built a late 80s Specialized Rockhopper as a bush basher to live at my dad's place in Castlemaine, and it quickly became my daily commuter. I'm currently building another for a friend out of a custom built Gotty Hansen frame.
I'd say that they don't really fit into any of those categories; they're a little sluggish and heavy, and not very blingy or attractive, except in an 'old worn t shirt' kind of way. I'd call it a Dirt Tourer.
If you need more bar rise, try using a Dirt Drop stem, Nitto still make them and they can be bought through Ben's Cycles in the States.
For tyres, I'd go for something lightweight and with a soft casing, because damn they're sluggish enough as it is. I went for Resist Nomad 2.15" tyres on a friend's recommendation and haven't looked back. They can be found locally. They're far lighter and have a softer casing than Marathons, and make for a buttery smooth ride. I've had one flats in just under a year, which is good considering they spend most of their time in the broken bottle capitol of Melbourne.
2.15s wont fit in my friends frame, so I'm looking to get a set of Compass 26x1.75 tyres, which look even nicer.
For cranks I'm happy with the 110bcd Specialized triple that came with it, previously set up with a 28-39-48, but now without the granny as I rarely used it. Combined with the 32t cassette it gives me enough range to do nearly anything, including mountain biking, but a smaller inner might be better. I always wanted to set it up with a triple as a double but running a single 'commuter' ring on the main spider, say a 46t, and then one granny MTBing/arse hauling ring on the inside triple, say a 32t. Fun times.
Anyway here's a few pictures of a recent ride through the Otways for build inspiration. I have since gone back to 44cm Nitto Noodle bars, instead of the 38cm SR Randonneurs pictured there, because I preferred the width and I needed that Technomic stem for another bike. Replaced it with a Nitto Dirt Drop stem.
IMG_2665 by biekomelbourne, on Flickr
IMG_2670 by biekomelbourne, on Flickr
IMG_2684 by biekomelbourne, on Flickr
LugNut
Postby LugNut » Tue Mar 04, 2014 3:01 am
Also, Centurion had a colour scheme exactly like that.
Postby ldrcycles » Tue Mar 04, 2014 9:10 pm
I think i've seen your stumpy in another thread, it's a neat looking rig.
I was actually thinking about this project today, as i'm looking at nicking the Microshift brifters for another project :) .
LugNut
Postby LugNut » Tue Mar 04, 2014 11:06 pm
Take some piccies to give this thread closure before you pull it apart!
Postby ldrcycles » Wed Mar 05, 2014 6:17 pm
Pull it apart? I haven't even started sandblasting it yet, let alone building it :) . No the gravel grinder is still sitting in the queue patiently waiting for her time, but in the meantime i'm going to have a crack at putting drop bars on my original Jamis mountain bike.
Postby ldrcycles » Wed Jul 16, 2014 1:14 pm
It's been quite a while but there's some significant news on this one now. Specifically, the Kojima/Nishiki/whatever is heading back into the shed, because i found a better candidate yesterday.
It's a 1989 or thereabouts Apollo Cross Trainer. Cromo allegedly involved somewhere, it's fairly heavy but that may just be down to the steel bars, stem, seatpost, cranks and brakes :) . The original wheels were Exage hubs on Araya rims, the ones in the photo are off another project, but show that it fits 700x38s with a huge amount of room to spare. Now i know i said i was ok with 26" after test riding the mystery frame but it has always been a nagging annoyance, and i'm much happier with 700C, short of finding a frame that's designed around 27 x 1 3/8" wheels (which would have to be pretty unlikely).
The only potential fly in the ointment is that while the top tube is the right length (56cm), the seat tube is just 53.5, so i will need to find a suitably enormous seatpost in 25.8mm. But i think i have one on hand already, so it mightn't be an issue.
Postby ldrcycles » Wed Jul 16, 2014 7:38 pm
Nope, no flies, ointment, buffalo, march or otherwise :) . The first seatpost i picked up was the right size, so in it went along with the traditional test bar/stem combo. Fits very nicely, so now it's just a matter of buying some big fat tyres (most likely 38mm Maxxis Overdrives) and a pair of wheels to suit.
silentbutdeadly
Postby silentbutdeadly » Thu Jul 17, 2014 9:21 am
It should be effective but I would be wary of the dirt road handling if you continue with your traditional positioning unless you can get your bum back further over the back wheel when the going gets 'interesting'.
Apart from your typically eye-watering saddle to bar drop...this is fast resembling my own mongrel grinder viewtopic.php?f=70&t=75323
Unfortunately, for this bike, the front end is suffering on the rough tracks. The headset has drifted apart a couple of times already and just yesterday the A-head conversion quill let go of the fork in some sand which nearly caused some grief. Putting a quill stem back in it isn't an option as I'm without suitable drop bars (though plenty of flats). The back end has suffered too with both the seat post and the rear QR skewer failing. The former was sorted with a USE Shokpost while the latter was replaced with a spare Hope skewer.
I have a perfectly good but redundant Cannondale hardtail 29er that's only a couple of years old just sitting in the shed...so that might get a major touch up and this bike will go flat bar and be moved on to a new owner...
Postby ldrcycles » Thu Jul 17, 2014 5:23 pm
This is my current "dirt bike" and the one i used on the 200km epic that got me wanting a more gravelly bike in the first place.
That's the only photo i can find of it and was just after i had restored it, so the seatpost is not at my height, it actually sits about 3 or 4 inches higher than that. As well as the 200k ride (http://www.strava.com/activities/98415963/) I've done about 6 or 7 Noosa Strade Bianche long course rides and a few short solo gravel rides. Never had a problem with handling or traction, and only had 3 flats, 1 from smashing into a timber bridge at about 40kmh, one which was a mystery and a blowout (possibly damaged casing) just a kilometre or so from the end of the Kilcoy ride. Hopefully the 700 x 38s will be as good with flats as the 27" tyres have been.
Postby ldrcycles » Sat Jul 19, 2014 7:11 pm
Just a couple of questions as i start to get the parts together.
I'm looking at using straddle cable carriers like this just because they are prettier than the ones i'm used to seeing but do they actually have any advantages?
And i've seen a couple of comments saying that fork mounted hangers are less prone to judder and have some other advantages over the headset mounted type?
Rob74
Postby Rob74 » Sun Aug 10, 2014 9:45 pm
koen
Postby koen » Sat Aug 16, 2014 4:49 pm
I wished this bike turned out lighter but the frame without forks was 3kg. Anyway it was $80 off ebay with a few problems
Got rid of most stuff except the deore drivetrain and brakes. My old 90's XT race wheels fit well.
I spent including the bike $250 but I reckon with new and 2nd hand bits I had it owes me $600 and seems very pretty.
11.8kg 21 speed fun bike, to be seen in 2015 popping to the IGA
or tearing up some miles on all those excellent white gravel roads around Stanthorpe, maybe with Chris?
morini
Postby morini » Sat Aug 16, 2014 5:17 pm
Ride around Stanthorpe every day if I can. I will once my shoulder heals. Broke the a/c joint four weeks ago and got told by the physio (in the Soup Nazi's voice);"no riding for you.......for another two weeks." Now I understand how those pros feel when they come down. Blo*dy painful injury.
Does this mean I need to start building a gravel grinder?
KGB
Postby KGB » Sat Aug 16, 2014 8:21 pm
@ldr: I like them because they actually clamp onto the straddle cable, rather than the cable just laying across like the normal ones.
A bump in the road, a knock from a knee/branch/whatever or a kink in the straddle cable can cause the brakes to shift sideways resulting in uneven pull and potentially rubbing brakes. It doesn't happen all that often but it does happen.
koen
Postby koen » Sun Aug 17, 2014 9:37 am
morini wrote:Ride around Stanthorpe every day if I can. I will once my shoulder heals. Broke the a/c joint four weeks ago and got told by the physio (in the Soup Nazi's voice);"no riding for you.......for another two weeks." Now I understand how those pros feel when they come down. Blo*dy painful injury.
Sorry to hear that mate. Get well soon. I reckon a good sturdy pair of road tyres would handle the granite roads okay.
Otherwise I have two tandems and you can always sit on the back of one if you can't stay upright on a single bike :p
Postby ldrcycles » Sun Aug 17, 2014 9:49 am
KGB wrote:@ldr: I like them because they actually clamp onto the straddle cable, rather than the cable just laying across like the normal ones.
That plus they look good is plenty enough excuse for me :) .
That Gary turned out to be one schmicko ride koen!
I'm gradually getting the parts together for my project, Hopefully i'll have the frame and forks off to the powdercoaters in the next week or two.
Anyone got any silver square taper road triple cranks with a 52t big ring, or low profile cantis that take V brake type pads?
silentbutdeadly
Postby silentbutdeadly » Tue Aug 19, 2014 10:26 am
ldrcycles wrote:Anyone got any silver square taper road triple cranks with a 52t big ring, or low profile cantis that take V brake type pads?
Have a rummage through your spares pile. You may find a hybrid five arm triple with the right BCD that you can drill the rings off and fit a 52 big ring to. I did this with a four arm 104BCD version that now runs a single 40T.
The cross bike runs Shorty's with road pads and they work a treat if you can find some. Failing that...old school cantis with pin style pads turn up at the tip shop not too infrequently...
