Laprade Seatpost 25.0 x 300mm+
Dezza
Postby Dezza » Sun Jan 05, 2014 4:11 pm
I'm looking for a Laprade style (single bolt, adjustable pitch) seatpost with 25.0mm diameter and length upwards of 300mm to suit a 1983 Vitus roadbike. Darn French and their unusual part dimensions.
I've seen quite a few MTB posts which are 25 x 400 but they look to have a different seatclamp. Need to ensure the clamp can adjust saddle pitch. Would prefer a setback style for that authentic vintage (well, 1983) look. Alloy would give me weight savings over steel if I get the choice. Fluted style would make it even more authentic.
Any ideas folks?
Saro28
Re: Laprade Seatpost 25.0 x 300mm+
Postby Saro28 » Sun Jan 05, 2014 11:27 pm
where u at Dezza?
Dezza
Postby Dezza » Mon Jan 06, 2014 8:25 am
Melbourne CBD (w) & inner west (h)
koen
Postby koen » Mon Jan 06, 2014 3:11 pm
try here and cut it off with a hack saw
ebay
Dezza
Postby Dezza » Mon Jan 06, 2014 9:56 pm
Well spotted thanks. You're not the seller are you ;)
koen
Postby koen » Mon Jan 06, 2014 11:27 pm
Dezza wrote:Well spotted thanks. You're not the seller are you ;)
No but I just got a similar post in the mail today..didn't check if it was from that same seller.
Saro28
Postby Saro28 » Tue Jan 07, 2014 9:05 am
Kalloy 25.0mm Black/ polished paint off. 400mm, $20 + post, used once for build
and then found a Laprade full alloy to compliment polished SS
and then a Campag one showed up 8)
Dezza
Postby Dezza » Tue Jan 07, 2014 10:17 am
Thanks to both of you. I'll keep my eye on the fleabay one and get back to you Saro28.
Meanwhile that blue fluted one looks to be on a Vitus (or an Alan) and for that matter looks identical to the one I'm parting out - and thus you appreciate what I'm trying to do with the look of all that polishing on the lugs, SS and CS.
Dezza
Postby Dezza » Thu Jan 16, 2014 5:44 pm
Dezza wrote:Thanks to both of you. I'll keep my eye on the fleabay one and get back to you Saro28.
I've won the fleabay seatpost so once it arrives I will see how I go and report back.
Dezza
Postby Dezza » Tue Feb 25, 2014 12:30 pm
OK so now I have purchased this seatpost which is the same diameter as the SR one it was intended to replace (25.0mm).
Funny thing is - it doesn't seem to fit. Didn't slide in easily, and with only moderate side to side pressure only 4cm has fitted in the frame and now it's stuck.
Anyone care to explain if I have bought the wrong thing or is it another case of "User error - Replace user" ... :oops:
Postby munga » Tue Feb 25, 2014 7:46 pm
perhaps not all 25.0's are created equal.
i'd measure the exposed section (duh) and see where it went wrong.
did you use lube? how stuck is it? can you fit a saddle and wrench it out of the frame without going beefcake on it?
Postby munga » Tue Feb 25, 2014 7:47 pm
ps: if any of you are selling a post, please get in touch. a mate is chasing one for another, slightly different, french build.
he's a weirdo too. you all are.
Saro28
Postby Saro28 » Tue Feb 25, 2014 8:12 pm
munga wrote:ps: if any of you are selling a post, please get in touch. a mate is chasing one for another, slightly different, french build.
check the weirdo post above :lol: I'm selling from Sydaney :)
ammie7
Postby ammie7 » Wed Feb 26, 2014 4:47 pm
I have a Shimano 600 25.2 mm tri colour vintage. (ie no tri colour decal, but had one). $20
Sent from my iPhone using Tapatalk - now Free
ammie7
Postby ammie7 » Wed Feb 26, 2014 5:32 pm
Re my last 25.0mm x 200mm
Dezza
Postby Dezza » Fri Mar 07, 2014 11:44 am
Munga: thanks for the advice, will see where a saddle gets me. I have that SR laprade 25.0 x ~200 (need to measure) if that was something like what your mate wanted.
Saro: what length are the laprade alloy and the campag you're selling? (Just in case I get the current one out again...)
