Repco Cambridge Age
pitty43
Repco Cambridge Age
Postby pitty43 » Thu Mar 13, 2014 6:31 pm
Hi all, Trying to date this Repco Cambridge found in a garage pit. My Guess is 1960,s. Came with Sturmey Archer 3 speed hub and full mudguards.
Cheers Chris.Image
Re: Repco Cambridge Age
Postby munga » Thu Mar 13, 2014 7:19 pm
cambridge is likely early to mid 80's. check the repco thread for catalogues.
pitty43
Postby pitty43 » Fri Mar 14, 2014 11:22 am
Sorry image did not run. Its definitely not 80,s. Codder pin cranks and decals way earlier.
Postby munga » Fri Mar 14, 2014 6:35 pm
i don't know much about ladies' bicycles, but those decals are way later than i expected. more like late 90's early 00's.
see if the Sturmey Archer AWC (looks like a coaster hub to me) hub has a two-digit date code on it.
HappyHumber
Postby HappyHumber » Fri Mar 14, 2014 6:40 pm
pitty43 wrote:Its definitely not 80,s. Codder pin cranks and decals way earlier.
The brand spankers Repco Traveller I received for my 12th birthday in '86 had cotter pins, and an earlier style of livery than this. Cheap bikes still had cotter pins in the 80s. Think Dept Store BSOs.
munga wrote:see if the Sturmey Archer AWC (looks like a coaster hub to me) hub has a two-digit date code on it.
Assuming it's original, it'd surprise me if it was a SA. I would've thought this era of Repco would've had a Shimano 3sp IGH coaster.
- Kym
pitty43
Postby pitty43 » Fri Mar 14, 2014 7:34 pm
Sturmey Archer hub has been removed for another project. It has 88-5 stamped in it. Still not convinced its 80,s. Most other 70,s Cambridges I've seen on E-Bay and Gumtree have more blocked type lettering and alloy cranks. The bike also has 6066 stamped under the serial #. If the date on the hub is correct I guess your correct.
pitty43
Postby pitty43 » Fri Mar 14, 2014 7:43 pm
Just checked through the catalogues posted and found it in the 88-89 catalogue. Thanks all for your help. Better change my Gumtree add now.
HappyHumber
Postby HappyHumber » Fri Mar 14, 2014 7:44 pm
The OP has deleted his hosted images, but some cached versions come up if you Google search them properly;
Crappy, dithered & enlarged version at this link from the '85/86 Catalog. It bears the same style livery & font as my 86 Traveller had back in the day.
FWIW; the full thread was here
- Kym
Postby munga » Fri Mar 14, 2014 8:04 pm
and people wonder why i play wheel of misfortune..
Typhoon Ken
Postby Typhoon Ken » Fri Mar 14, 2014 8:59 pm
Another happy customer off to cash in on all the peoples' good will from here.
Sent from my Nexus 7 using Tapatalk
Users browsing this forum: piledhigher
