New Cinelli 1A stem bought on ebay a fake?
janus77
Postby janus77 » Thu Aug 07, 2008 2:38 pm
So my new 70mm 1A stem just arrived. The Cinelli logo stamped on the top is half arsed, basicall the side of the "C" is missing, and the two L's have kinda fudged together.
Also, the vertical part of the stem has a weird abnormality, in that about 1/4 of the way down from the top, there are some slight lumps in the length of it, not totally straight.
Other than that it looks ok..
Is this normal?
J
janus77
Postby janus77 » Thu Aug 07, 2008 2:55 pm
upside down, bit hard to see..
Postby Mulger bill » Thu Aug 07, 2008 4:56 pm
I don't know Cinelli well enough for a definitive answer Janus, but I'd guess their QC blokes wouldn't put that dodgy stamping in a box :?
Maybe they sell their factory seconds to Asian resellers but it wouldn't be good advertising for the brand.
Shaun
kukamunga
Postby kukamunga » Thu Aug 07, 2008 9:11 pm
Uh.... where's the quill? :?
Postby familyguy » Thu Aug 07, 2008 9:24 pm
kukamunga wrote:Uh.... where's the quill? :?
Wedge stem??
kukamunga
Postby kukamunga » Thu Aug 07, 2008 9:35 pm
Wedge stem??
And wedge they certainly do.... :?
Postby munga » Thu Aug 07, 2008 10:09 pm
they're ok if you remember to grease them before you fit them up the first time. I bought an old frame with a cinelli wedge stem and it came out first go, no dramas at all. the thing was covered in nice thick white grease tho
kukamunga
Postby kukamunga » Fri Aug 08, 2008 8:09 am
It looks like a 'expander' stem. According to Sheldon, expander type stems:-
"Are less likely to damage the steerer if overtightened"
Surely this statement is incorrect, isn't it? I've seen numerous steerers damaged by overtightened expander nuts, but not by wedges. Anyone else care to comment? (Sorry Janus, for hijacking your thread)(By the way, your first name isn't Hugh is it?)
singletracking
Postby singletracking » Fri Aug 08, 2008 9:15 am
I'll check my 1As - I don't think that they have the length cast in the little circle like your picture shows? I could be totally wrong though.
Postby singlespeedscott » Fri Aug 08, 2008 10:18 am
That 1A looks fine to me. It is definitely a newer one with the newer stamping and the length stamped on the stem. As for the letters missing on the top of the quill, you have to remember they where made in Italy and Italian ideals of quality assurance are not as high as those of the Japanese. The Italians are more about style than substance :D .
janus77
Postby janus77 » Fri Aug 08, 2008 2:11 pm
thanks All.. just have to get it on the bike now :)
rogerrabbit
Postby rogerrabbit » Mon Aug 11, 2008 8:29 am
It looks genuine to me. The quality of the Cinelli stamping is "variable" at best.
Roger
janus77
Postby janus77 » Wed Aug 20, 2008 10:03 am
Few more interesting points of difference on this stem.
1. the Bolt for the bar clamp didn't fit in front on, (there was not enough diameter drilled out of the hole for the outer part of the bolt to slide into, so it's sitting in backwards now..
2. There are no filings on the inside of the clamp, it is smooth all the way around.
3. The bar clamp part looks different to the other 1a, in that the 2 sides come together parallel, whereas my other 1a they are slightly angled..
hmmm.. bike shop guy reckoned it could be a dodgy too.. interesting.
Postby familyguy » Wed Aug 20, 2008 10:22 am
janus77 wrote:Few more interesting points of difference on this stem.
I thought that was to hide the bolt head from view and clean the look of it up? In your pic the head is facing the back. Is it still like this?
janus77 wrote:2. There are no filings on the inside of the clamp, it is smooth all the way around.
I cant vouch for all Cinelli's, but most of my quill stems are smooth inside the clamp area. Only one is grooved.
EDIT: Just looked at three 1A's on the web. One is grooved. 2 are not. Maybe they didnt do them all? How many 'fakes' could there be otherwise?!
janus77 wrote:3. The bar clamp part looks different to the other 1a, in that the 2 sides come together parallel, whereas my other 1a they are slightly angled..
Maybe that just means your bars are larger and the faces dont close up as far when you tighten it?
janus77 wrote:hmmm.. bike shop guy reckoned it could be a dodgy too.. interesting.
Do you think he's right? If you paid bugger all for it, then dont worry.
janus77
Postby janus77 » Wed Aug 20, 2008 11:19 am
Thanks Jim.. I'm not worried about it, just more interested.. for $40 plus delivery, I'm happy with the product.
On the bolt question, what I mean is that the allen key bolt part has to face forward (so the smooth head sits out of view), the other way around doesn't fit.
Bike's a bit more jumpy with the shorter stem, will take a ride to get used to it I think, then 3ks to work aint enough.
rogerrabbit
Postby rogerrabbit » Wed Aug 20, 2008 3:54 pm
I recall having the allen key bolt on the front on some. Perhaps the bolt is not original?
Also, are the bars 26.0 or 26.4? run a tape around them and devide by pi.
You may have a 26mm bar in a 26.4 stem.
Roger
janus77
Postby janus77 » Wed Aug 20, 2008 4:34 pm
well the bars are Cinelli Criterium, so I'd assume they're 26.4?
Users browsing this forum: drex
