1952 Hobbs 'Blue Riband': the next iteration
Re: 1952 Hobbs 'Blue Riband': the next iteration
Postby Clydesdale Scot » Sat Jul 28, 2018 11:54 am
I finally have the front hub that I am happy with, thanks Simon.
and the new strong rims in the Constrictor Asp style
Imagehubs and rims by philip.knight, on Flickr
the hubs and rims can go off for measuring and the spokes can be ordered from Britain.
and playing with the front end jewellry
Imagefront end progress by philip.knight, on Flickr
Postby Clydesdale Scot » Sat Aug 04, 2018 9:25 am
if Dare handlebar grips were good for the 1946 Hobbs of Barbican, then they are also good for the Blue Riband.
These came up on the British evilbay.
Imagedare grips by philip.knight, on Flickr
I was the only bidder (no surprises there).
So red grips to lift the conservative appearance.
And this needs to have red elsewhere.
Simon (a cycling friend who has a good eye for detail) has suggested red toe straps.
And I have thought I can have a red highlight on the chainset.
If you know your late 1940s/early 1950s British lightweight rare components you will know where this might be going.
Hobbs of Barbican produced some top end components under the Lytaloy name.
They are highly sought after whenever they appear.
But one of the rarest items is the Lytaloy chainset. Rare because they often cracked. It has been suggested to me that current knowledge of the alloy grades should provide a grade that will work.
So I am now chasing another rabbit down a hole and my drive-side survivor is being modelled by a professional. If that works, the model will go off for CNC machining.
ImageLytaloy chainring by philip.knight, on Flickr
Then I can paint the area around the name, and that will further repeat the red in the grips, and balance the appearance.
Just like on John's Alcon
But there will be a set of Williams cranks in the intervening period.
Johnj
Postby Johnj » Sat Aug 04, 2018 12:18 pm
I had the good fortune to buy a non-cracked NDS crank for the Alcon. Happy to send the cracked one to you if you like Phillip.
Postby Clydesdale Scot » Sat Aug 04, 2018 2:37 pm
that would help a great deal in modelling the 'missing' arm.
thanks
Postby singlespeedscott » Sat Aug 04, 2018 3:43 pm
I wouldn’t be using a CNCed crankarm modelled off a thin section forged one. If the forged item use to crack the CNC version will not last long.
Postby Clydesdale Scot » Sun Aug 05, 2018 7:16 am
The CNC machining will be done by someone who makes crank arms for these. If Mick has concerns with the design, he has a clarity in his communication style which even I could not misinterpret.
Postby Clydesdale Scot » Sun Aug 19, 2018 10:20 am
The Sturmey Archer cable run. Conventionally the cable is run from the trigger through an outer cable to a fulcrum clip on the top tube. This fulcrum clip can be located to effectively change the cable length. The bare cable continues to pulley assembly located near the saddle then to the crimped cable termination housed in an inline adjuster, then a short chain into the SA hub.
Except this frame has a down tube mount.
From my reading, the cable run along the top tube and down close to parallel to the seat stays is preferred as it will allow a more consistent cable tension when the wheels are placed in the rear dropouts. This cable tension is critical for the operation of the gears. The end of the cable is terminated with a crimp (modern fittings have an alternate system that is bulky and not pleasing). This limits the ability to adjust the cable once it is installed.
I will try a few workarounds to achieve the same results.
The cable from the trigger:
ImageBR cable run 1 by philip.knight, on Flickr
into an inline adjuster:
ImageBR cable run 3 by philip.knight, on Flickr
The inline adjuster I have installed is to fill the role of the movable fulcrum clip.
into a modified cable stop:
ImageBR cable run 2 by philip.knight, on Flickr
then to the cable stops through some more housing (not shown)) then to the hub (yet to be built).
ImageBR cable run by philip.knight, on Flickr
The consistent placing of the rear wheel will be managed by the Cyclo chain tensioners shown.
The chainring and the crank arm have been modelled.
They are available for viewing (for a short time) at
https://autode.sk/2vQYmrr
https://autode.sk/2vPubRn
GaryF
Postby GaryF » Sun Aug 26, 2018 11:27 am
Your work is so good. This is such a beautiful project and I know the end bike will be one that you can visually feast on for hours finding interesting mechanical gems from the past and interesting ways of bring them into this century. Congratulations Clydesdale Scot.
scooter1971
Postby scooter1971 » Mon Aug 27, 2018 4:11 pm
Great to see bikes like this coming back to life.
Gives me the motivation to get going with my own soon.
Postby Clydesdale Scot » Sat Sep 08, 2018 4:51 pm
a nervous time... dealing with old rubber.
ImageHobbs BR20180908 by philip.knight, on Flickr
The Dare handlebar sleeves were given a treatment of 303 Aerospace Protectant, then into a bucket of warm water. Gentle pushing had them installed without drama.
Then for the GB Superhood lever hoods. The notches cut for the adjusters, then gentle pushing and levering had them also installed.
The cable outers measured, cut, ground and placed into position.
Finally some colour to provide interest.
Much available at my fingertips.
Postby singlespeedscott » Sun Sep 30, 2018 8:52 am
Looks good. Never thought to place a bell there. I guess when I need it I’m usually not in the drops.
Postby Clydesdale Scot » Sun Sep 30, 2018 1:11 pm
This bike is being setup along the lines of the time trial bikes of the late 1940s and early 1950s.
The medium ratio SA fixed hub suggests that direction. It was this rather special hub that this project has been built around.
The time triallists were required to have a bell and use it when approaching another rider prior to overtaking. So it is placed to be accessible when racing.
These images are from Classic Lightweights
Postby singlespeedscott » Sun Sep 30, 2018 2:07 pm
Looking at those Marsh bars I don’t think I would be using them for anything but tt’s
Users browsing this forum: Releng
