Tyre Sizes
JustinH
Tyre Sizes
Postby JustinH » Sun Sep 17, 2017 5:42 pm
I need to get some new tyres for this bike I'm restoring. Turns out at least one of the wheels isn't original because they're both different sizes. I didn't even notice until I held the rims next to each other a second time, so I'm not too concerned about the difference, no one will know except me.
My question is regarding tyres, the wheels are 27x1 1/4 and 28x1 3/8, which according to the ISO standards take 630mm and 642mm tyres respectively. I definitely can't fit regular 700c(622) tyres on(I had a go), but I'm wondering if I could stretch a 27x1 1/4 tyre onto the 28x1 3/8 wheel. It's only 12mm and I suspect it will depend on the tyre as well. I'd rather have matching tyres and I can't find one tyre in both sizes plus it's just easier if they're both the same.
Thoughts?
uart
Re: Tyre Sizes
Postby uart » Sun Sep 17, 2017 5:59 pm
JustinH wrote:I need to get some new tyres for this bike I'm restoring. Turns out at least one of the wheels isn't original because they're both different sizes. I didn't even notice until I held the rims next to each other a second time, so I'm not too concerned about the difference, no one will know except me.
Thoughts?
I doubt it. It's pretty much impossible even to stretch a 700c (622) tyre onto a 27" (630) rim. A few people have managed to get them on but they never sit right, and that's only an 8mm difference. So I can't see you managing to get 630 onto a 642 rim, which is a full 50% more (12mm instead of 8) to stretch.
If you look around I'm pretty sure that some 28x1 3/8 tyres are still available.
Derny Driver
Re: Tyre Sizes
Postby Derny Driver » Sun Sep 17, 2017 7:33 pm
Dont worry if the tyres dont match. Or the wheels. People didnt care about that chit in the old days.
hazarama
Re: Tyre Sizes
Postby hazarama » Sun Sep 17, 2017 8:56 pm
I had a bike with 700c tyres on 28" Westwood rims. I didn't put them on but I can tell you there was a lot of swearing involved with getting them off. I'm sure you could get a 27" tyre on a 28" rim, but I wouldn't..
Not too long ago I setup a 28" rear and 27" front for bit of fun and liked it a lot. The 28" soaks up the bumps quite nicely and the 27" is noticeably lighter up front.
In terms of getting 27" and 28" tyres that are aesthetically a close match, Abbotsford Cycles look to have Block Tread Standard Wall in both sizes.
uart
Re: Tyre Sizes
Postby uart » Mon Sep 18, 2017 11:47 am
I'm not nearly so sure!
Are you really sure that was a 642 rim and a 622 tyre, because I'd say that is pretty much impossible. As I said above, many people have tried 622 on a 630 rim and I've not personally seen (or even been able to find on the web) of a single documented case of it being successful. A very small few have said that they actually got them on, but none have had them seat correctly.
Torana68
Re: Tyre Sizes
Postby Torana68 » Mon Sep 18, 2017 5:36 pm
Are you really sure that was a 642 rim and a 622 tyre, because I'd say that is pretty much impossible. ..............
maybe 635mm 28 x 1 1/2? still probably not, 28" and 29" fit a 700c rim though :)
Ozpushies! for ALL Australian made bikes.
"It's only original once"
hazarama
Re: Tyre Sizes
Postby hazarama » Mon Sep 18, 2017 10:04 pm
No, I'm not 100% sure. I'll check the tyres and rims when I get home next week.
Admittedly, it does sound a bit silly, as I've had trouble getting a 27" tyre on a 27" rim before - they were Schwalbes which are renowned for their tight fit, bit still...
JustinH
Re: Tyre Sizes
Postby JustinH » Mon Sep 18, 2017 10:22 pm
The part after the "28 x" is very important when considering rim size, it refers to a rim standard rather than specifying what the size is. It's almost meaningless as a measurement in itself. Here is the table with all the conversions if you're interested, there's a huge difference between the 28" wheels, I read somewhere that 28 x 1 1/8 was an Australian specific size. https://en.wikipedia.org/wiki/ISO_5775
I actually kind of answered my own question without realising it before I even wrote the post. I tried to fit regular 700c tyres on the 27 x 1 1/5 rim and couldn't get close and as mentioned, that's only an 8mm difference.
Thanks for the link to Abbotsford Cycles, they do have blocktread in both sizes as well as a bunch of other parts that I need to get for the bike so my problem is solved along with a few others :)
uart
Re: Tyre Sizes
Postby uart » Mon Sep 18, 2017 10:27 pm
Ok thanks.
As torana mention, there was more than one 28" rim size standard. The other one was 635, so just maybe a (630) 27" tyre on a (635) 28" rim might be possible. A 622 tyre on a 642 rim just seems too crazy, it's actually about a 6.5 cm difference in bead circumference!
uart
Re: Tyre Sizes
Postby uart » Mon Sep 18, 2017 10:37 pm
JustinH wrote:The part after the "28 x" is very important when considering rim size, it refers to a rim standard rather than specifying what the size is. It's almost meaningless as a measurement in itself. Here is the table with all the conversions if you're interested, there's a huge difference between the 28" wheels, I read somewhere that 28 x 1 1/8 was an Australian specific size. https://en.wikipedia.org/wiki/ISO_5775
So a tyre marked 28" could be any of 622 or 635 or 642.
Torana68
Re: Tyre Sizes
Postby Torana68 » Tue Sep 19, 2017 7:44 am
and not forgetting 27" can be found on 700c tyres (singles)....
hazarama
Re: Tyre Sizes
Postby hazarama » Wed Sep 27, 2017 9:38 pm
Ok, the tyre was 37-622 but the rim diameter was 630. So not the size I thought it was..
WyvernRH
Re: Tyre Sizes
Postby WyvernRH » Thu Sep 28, 2017 8:24 am
Yup, 28 x 1 5/8 x 1 1/4 is a common marking on European tyres that are actually 622 (700c)
There is also the infamous Dutch 27"x 1 1/2 size which is actually 609. Quite different when compared visually but I do know someone who bought a large batch of these off the internet (not me) thinking they were getting cheap 630 sized tyres so buyer beware!
uart
Re: Tyre Sizes
Postby uart » Thu Sep 28, 2017 12:13 pm
WyvernRH wrote:Yup, 28 x 1 5/8 x 1 1/4 is a common marking on European tyres that are actually 622 (700c)
Yeah Richard, you really need the ISO tyre size to be sure with those "inch" sizes!
hazarama wrote:Ok, the tyre was 37-622 but the rim diameter was 630. So not the size I thought it was..
Thanks for the update hazarama. So it was actually a 700c tyre on at 27" rim. That's still pretty impressive, it's still a massive stretch to get that to fit. Just wondering, did the beads ever sit properly on that thing, or were they (or at least one side) scrunched in towards the center "V" of the westwood style rim?
hazarama
Re: Tyre Sizes
Postby hazarama » Thu Sep 28, 2017 10:20 pm
The bead was bit sunken in and didn't look right and I haven't used those tyres or the rims. Found a picture of the front wheel as it was when I picked up the bike.
