Help Identifying a 70's? Gitane
visrealm
Postby visrealm » Tue Apr 17, 2018 9:50 am
I picked this up from my Dad's shed. No history (unfortunately, he's not around to ask).
It looks very 70's to me, but there isn't much in the way of identifying marks.
What I know:
It's pretty rough, but is rideable.
It was sold by Standish Cycles West Lakes SA (still has that sticker)
60cm C-T. (it's my size)
10 speed.
Huret Front, Read Derailleurs and friction DT shifters. All working well - but need new cables.
175mm Sugino Maxy crankset?
Mafac Brake levers.
Cinelli stem.
San Marco saddle.
27" Mavic rims fitted to Normandy QR hubs - They actually spin really well.
Frame has brackets on top tube for a pump.
Nothing helpful on the bottom bracket.
95526 A stamped on what I assume is a stand bracket behind the bottom bracket:
Numbers on the rear dropout:
Other random shots:
My feeling is it's not worth spending much on, but given it is rideable at the moment (would probably need new cables, brake pads and tyres to make it safer. Tyres look fairly unused, but they are aged)
Any ideas?
Troy
'14 Avanti Corsa SL Team (Roadie)
'13 Specialized Secteur Disc (Commuter)
'04 Giant Yukon (MTB)
'12 Avanti Cadent 1 - R.I.P.
P!N20
Re: Help Identifying a 70's? Gitane
Postby P!N20 » Tue Apr 17, 2018 10:23 am
You could trawl through the Gitane catalogues: http://velobase.com/Resource_Tools/CatalogScans.aspx
Just select Gitane in the brand field and press filter.
Looks in pretty good condition really. I reckon with a bit of elbow grease it would come up looking pretty nice.
uart
Postby uart » Tue Apr 17, 2018 10:31 am
visrealm wrote:My feeling is it's not worth spending much on, but given it is rideable at the moment (would probably need new cables, brake pads and tyres to make it safer. Tyres look fairly unused, but they are aged)
Yeah it would come up pretty nicely with just a basic clean up.
BTW. That is one long stem!
uart
Postby uart » Tue Apr 17, 2018 6:41 pm
BTW Visrealm, do you know what is the length of that stem. Have you measured it?
10speedsemiracer
Postby 10speedsemiracer » Tue Apr 17, 2018 7:36 pm
Has a very late 70s/very early 80s feel to it. Not a high-end bike as indicated by axle-mount derailleur/crank/clamp-on shifters, but would probably resurrect very well and ride nicely.
Don't really know why but I'm feeling 1979/1980 for this. It may be one of the intermediate models like a Gypsy or something along those lines. Don't think that stem is OE however.
Mmm, SunTour
visrealm
Postby visrealm » Wed Apr 18, 2018 12:36 pm
Thanks all,
I think I will get it riding again. Just won't spend much on it.
uart wrote:BTW Visrealm, do you know what is the length of that stem. Have you measured it?
140mm centre to centre :shock:
Troy
uart
Postby uart » Wed Apr 18, 2018 6:05 pm
visrealm wrote:Thanks all,
For a really quick and nasty clean up I just treat the rusty parts with a phosphoric acid based rust converter (I usually use the "SCA" home brand stuff), and then just shin it up with some WD40. The rust converter blackens all the red/brown rust and pacifies it. The WD40 helps pacify and seal it. Plus re-grease all the bearings.
visrealm
Postby visrealm » Sun Apr 22, 2018 10:40 am
10speedsemiracer wrote:Has a very late 70s/very early 80s feel to it. Not a high-end bike as indicated by axle-mount derailleur/crank/clamp-on shifters, but would probably resurrect very well and ride nicely.
I think you're pretty close, 10speed. Started servicing the components and both derailleurs are stamped xx78.
Troy
visrealm
Postby visrealm » Sun Apr 22, 2018 11:23 am
Have ordered new tyres, tubes, brake and shifter cables, bar tape, and koolstops.
I've serviced the headset, bottom bracket, derailleurs, shifters and callipers.
Will post an update once I have it all together again. 8)
visrealm
Postby visrealm » Fri Apr 27, 2018 5:58 pm
The big reveal :)
Very happy with the result for a total spend of ~$110
Just need to ride it :)
10speedsemiracer
Postby 10speedsemiracer » Fri Apr 27, 2018 6:52 pm
That came up really well. Think you'll enjoy riding that.
Mmm, SunTour
rkelsen
Postby rkelsen » Fri Apr 27, 2018 9:23 pm
Well that came up better than expected.
Good job! :D
Hagar
Postby Hagar » Sat Apr 28, 2018 6:26 pm
Sweet!!!
visrealm
Postby visrealm » Sun Apr 29, 2018 6:48 pm
Thanks all.
Did a little 10km with the kids today. Rides great.
Though, having never used DT shifters before, they'll take some getting used to. Also, the bars are super-narrow. My #1 has 44cm bars, these are 37cm. The bike feels like it fits well otherwise though.
Pretty happy overall.
531db
Postby 531db » Tue May 08, 2018 5:28 pm
That 140mm reach handlebar stem and the narrow handlebars are not original, they look as if they came of a 1980's track bike based on the shape of them. Some wider bars would not be out of place if you felt inclined to fit them.
Also those brake shoe bolts are way to long in there protrusion outside the caliper arms, I'd be worried at the damage they might cause.
But good job, it's come up well.
visrealm
Postby visrealm » Tue May 08, 2018 6:02 pm
Thanks. I've since cut the brake pad threads down. Had the same thought.
Here's a pic from the weekend.
I'll probably just leave it. The reach is ok for me. I'll get used to the narrow bars.
Troy
Users browsing this forum: P!N20
