Shimano Alivio freehub interface
Mickey1980
Postby Mickey1980 » Sun May 13, 2018 10:27 pm
Hi, all,
I have a pair of old wheels with the 7 speed hyperglide freehub (Shimano FH-MC-10 Alivio Parallax).
I want to upgrade to a 8 speed freehub, but the spare one I've got is of a different interface to the hub.
Image of the one I've got on the wheel:
Are these not common anymore?
Is this something to do with road vs MTB?
Also, would I have to re-dish the wheel?
Thanks!
Mickey1980
Re: Shimano Alivio freehub interface
Postby Mickey1980 » Sun May 13, 2018 10:28 pm
In case you cannot see the pic:
https://photos.app.goo.gl/svbEmEEcbrDjbnBF2
10speedsemiracer
Postby 10speedsemiracer » Mon May 14, 2018 2:51 am
Early to mid 90s MTB stuff, I remember seeing them and noticing the hefty, bigger barrel. There are such things (I think) as Parallax 8/9sp freehubs, but think they were in the Deore line-up, and also I don't know how common/uncommon they are. Will probably need to ask someone more mountain-bikey than me.
For some reason I'm vaguely remembering MC18 but that was in a different context. I'm not certain that this will fit, you'll need to research.
Any reason you particularly want 8sp vs 7sp ?
In any case, you'll need to compare your hub (wheel) to the chart and see which 8/9sp freehubs will fit onto your hub. And yes, will need to dish/re-dish the wheel to do it properly. I'd consider another wheel which has a slightly newer hub format.
Apparently the Parallax stuff was good gear though, for it's time..
Mmm, SunTour
