Frame touch up
Re: Frame touch up
Postby Clydesdale Scot » Mon Nov 12, 2018 6:45 pm
Tamiya wrote:
Clydesdale Scot wrote: you may need to mix two colours together to get a better match
good luck, it's not easy to adjust "red" :twisted:
There's nothing you can add to X7 Red to make it "more" red. :lol:
depends on exposure to the elements.
X7 is described in a RGB color space, hex #fd0000 is composed of 99.2% red, 0% green and 0% blue. Whereas in a CMYK color space, it is composed of 0% cyan, 100% magenta, 100% yellow and 0.8% black. It has a hue angle of 0 degrees, a saturation of 100% and a lightness of 49.6%.
silentC
Re: Frame touch up
Postby silentC » Mon Nov 12, 2018 7:53 pm
I was looking at Italian Red as a possible match.
The problem with online colour charts is they very much depend on your monitor displaying colours accurately, which they rarely do, same if you print them. But I suppose given it's a limited range it would give a guide as to which one is likely to be closest.
"If your next bike does not have disc brakes, the bike after that certainly will"
- Me
