Mystery Cinelli Component or Tool
P!N20
Postby P!N20 » Wed Nov 07, 2018 3:03 pm
Found this over at bikeforums.net that's keeping me awake at night; a mystery component or tool stamped Cinelli.
https://www.flickr.com/photos/49705339@ ... 271292045/
Anyone know what it does or what it is for? Perhaps it's not bike related?
It has the winged logo so >1978.
It doesn't have a high quality finish so I'm thinking it's a tool rather than a component.
The bolts look like they're meant to clamp something, but there's some little stops suggesting it probably shouldn't clamp too much.
The teeth may accommodate an elastic band perhaps?
Some have suggested it may be some kind of third hand tool.
Maybe it's only part of a larger tool like a truing stand or something?
The original thread is here: https://www.bikeforums.net/classic-vint ... hread.html
Re: Mystery Cinelli Component or Tool
Postby familyguy » Wed Nov 07, 2018 3:45 pm
If the bottom was spread to bottle cage spacing (64mm) then the notched arms wouldn't quite be parallel to one another. It if was spread to canti/centrepull spacing they might be. Still, doesn't help.
I like the OP's reasoning for buying it: it had Cinelli on it.
10speedsemiracer
Postby 10speedsemiracer » Wed Nov 07, 2018 7:50 pm
somewhere way back in the back of my brain, when I look at this, I think centrepull or cantilever brake tool. Haven't seen this particular tool but have seen something similar (waaay back in the 70s)
I think the one I recall, not as ornate, was an old Hozan. But I'm dredging the memory cells..
Mmm, SunTour
GaryF
Postby GaryF » Wed Nov 07, 2018 9:05 pm
I've got no Idea what it is but I want one too.
P!N20
Postby P!N20 » Thu Nov 08, 2018 10:37 am
Do you think there should be some handles coming off those notched bits? Then it might be some kind of spoke tension relieving tool...
WyvernRH
Postby WyvernRH » Thu Nov 08, 2018 1:33 pm
Possibly used to straighten bent chainrings or chainring teeth?
10speedsemiracer
Postby 10speedsemiracer » Thu Nov 08, 2018 1:46 pm
I've got a funny feeling that there's a bit missing, like a turnbuckle or screw adjuster between the two serrated arms sort of thing for tightening or adjusting.
Mmm, SunTour
P!N20
Postby P!N20 » Thu Nov 08, 2018 2:45 pm
WyvernRH wrote:Possibly used to straighten bent chainrings or chainring teeth?
I like you're thinking.
10speedsemiracer wrote:I've got a funny feeling that there's a bit missing, like a turnbuckle or screw adjuster between the two serrated arms sort of thing for tightening or adjusting.
I know, right? You feel those serrated bits have a part to play.
NASHIE
Postby NASHIE » Thu Nov 08, 2018 5:17 pm
Doesn't look like it opens up enough to be old spoke tension type tool ie that bolts onto one spoke. Brake spring testing type of tool....again with something missing, or just part of some fancy packaging/display contraption.
WyvernRH
Postby WyvernRH » Fri Nov 09, 2018 12:22 pm
OK, I think I might have this.
The straddle cable on a cantilever or centre pull brakeset is clamped in the bolts at each end close to the brake arms. This leaves the serrated arms at a slight angle from horizontal above the straddle cable serrations on the down side of the arm. You tuck a finger under each serrated arm and pull up to tension the straddle cable and push the brake pads against the wheel. This allows your other hand to tuck the cable puller thingy under the straddle, adjust the brake cable running thru it and tighten up the lock bolt.
What do you think? It would work best on Cantilever brakes I feel.
Derny Driver
Postby Derny Driver » Fri Nov 09, 2018 12:26 pm
WyvernRH wrote:...You tuck a finger under each serrated arm and pull up ...
Or use springs of various tensions?
Those serrated arms are crying out for some springs to be hooked on
10speedsemiracer
Postby 10speedsemiracer » Fri Nov 09, 2018 12:28 pm
I was thinking the same sort of thing, although a cable tie or spring would fit into the serrated arms maintaining tension on the straddle cable, leaving two hands free, one to pull through the brake cable and the other to tighten the yoke.
The spring I'm thinking of is similar (but smaller) to a drum brake tension spring...
Mmm, SunTour
P!N20
Postby P!N20 » Fri Nov 09, 2018 1:32 pm
WyvernRH wrote:OK, I think I might have this.
Oh yeah, similar to a Pro-set tool with a bit more functionality: https://www.bikewagon.com/shimano-tl-cb ... -gauge-set
I think we have a winner.
WyvernRH
Postby WyvernRH » Fri Nov 09, 2018 2:50 pm
Yes, good idea both - a spring or cable tie would free off both hands. Probably meant for a spring similar to the one in the picture IMHO?
