Excatly what it says in the title.
Not fazed what condition the hub is in, I only need a few things from it.
Axle must be 10mm x 26tpi.
Posted to or located in Adelaide.
FOUND: Campganolo rear hub (for parts).
Newbies, please read the Market Place Rules before posting in this section. NEW UPDATED RULES !!! Post Title Format: [Your Location] Item Title WTS no longer required - and your location is required.
• Page 1 of 1
FOUND: Campganolo rear hub (for parts).Excatly what it says in the title.
Not fazed what condition the hub is in, I only need a few things from it. Axle must be 10mm x 26tpi. Posted to or located in Adelaide. Last edited by Verbs & Nouns on Thu Feb 26, 2009 2:45 pm, edited 1 time in total.
Solid, for a rear track hub.
AllI really need is the locknut that goes up against the washer that goes up againts bearing cone, in between the frame and the hub, circled in red below.
Surely some hardware store would be able to help me with this...?
$100 for one nut...? Not bloody likely. I think Andy Fyxomatosis is on the case for me...
Be careful that you dont get road locknuts, they are thicker and wont work (experience speaking here)
I am also in need of some track locknuts for a campag rear hub, so if you find a commercial source, pls post it here. Cheers Roger
And Fyxomatosis came to the rescue with the locknut, cone and washer!
• Page 1 of 1
Return to Member to Member Bike and Gear Sales Who is onlineUsers browsing this forum: Google [Bot] |
