Used for less than 1000km, perfect condition, excellent build quality. Decided to switch to a slightly wider saddle.
Suits people with sit bones around the 130mm mark (same width as the saddle).
This is the least padded version of the range excluding the CF version. The shape has indents for sit bones which the padded versions don't have/can't do because of the padding.
Pictures below demonstrate how I set mine up (male). I suspect a female could/would have it tilted back slightly more than this and sit "in" the saddle more.
Spiel:
The composite from Selle SMP is a high performance competition saddle which gives the rider performance levels and similar low weight of the Carbon Fibre, with a slightly padded ride providing cushioning from road vibrations.
A great balance between ultimate competition performance and comfort. Get ready to Strike ...
Specifications:
Covering: nap leather
Casing: nylon 12 charged with carbon fibre
Frame: AISI 304 tubular steel
Weight: 200 g
Dimensions: 263 x 129 mm
Padding Level: 1/5
Made In: 100% Made in Italy
Retails for $340 - $350 locally.
$250 delivered or $240 pickup from albert st brisbane city.
SOLD
<images removed>
