WTS: MTB & roadie parts.'Garage Sale'.Melbourne
Postby Marx » Wed Jun 17, 2009 9:17 pm
Mods: I ran this past Aushiker for a thumbs-up.
Garage sale.
I need more room for for more new stuff!
Make me an offer !!
PM or phone me if you’re interested in any of this.
Mark: 0419 108 924.
Depending on the amount, item & location I can deliver.
All this can be viewed in Kensington Melbourne.
Frame MTB Hardtail Medium.
Specialized Stumpjumper M4 Pro 2005 model. Size 17, white.
Refer to this link for frame geometry:
http://www.specialized.com/us/en/bc/SBC ... spid=33095
Disk & V-brake mounts.
Rear derailleur hanger included.
Front Derailleur cable plastic scuff plate included (under BB).
Condition: Good. Used, scuffed & scratched from use. No cracks or weld repairs throughout.
$350 or best offer.
Sold Rear wheel - Shimano Mountain Sports. Used. Shimano disk & rim brake compatible, 9speed cassette, with quick release skewer & tubeless compatible.
$50.
Sold Forks MTB - Rock Shox Pilot SL (2003mod) used. 80 or 100mm travel (spacer provided) Spring with air assist (up to 20psi), V-brake & disk brake compatible, 20.5cm steerer length. rebound adjustment.
$50.
Forks MTB - Manitou Axel platinum air 80. Used, disk brake only. Remote ‘bar mounted lock-out. Steerer length 18.5cm, 80mm travel, rebound adjust.
$100.
Rotors – Shimano 160mm diameter, centrelock hub. SM-RT77. Used, but v good condition. Sold as pair.
$60.
Chainwheel, road – Campagnolo, 34tooth, 50kms old.
$20.
Tyre MTB – Hutchinson Piranha 2.0, Airlight, worn.
$10.
Saddle – WTB SpeedV, used. black.
$20.
Seat post – TruVantiv XR single clamp. 27.3mm diameter post, 350mm length, used.
$20.
Seat post – Easton EA50. 30.9mm diameter post, 350mm length, used.
$20.
Seatpost – (no brand). Black/silver. 30.9mm diameter post, 300mm length, used.
$20.
Sold: Pedals – Look KEO classic. Brand new (still in unopened bag). Road shoe cleats included.Sold Pedals – Shimano SPD PD-M520. Used, no shoe cleats.
Pedals – Shimano SPD PD-M124, resin platforms, very used, missing 1x screw.
$10.
Chainwheel – MTB (no brand). black alloy, 104PCD, 33 tooth, used.
$20.
Stem – Koski Stronghold XC. Black, 90mm length, 15degree bend, used.
$30.
Stem – (no brand) Silver alloy, 120mm length, 7degree bend, used.
$5.
Sold Cranks – Shimano LX Hollowtech FC-M572, (2003mod). 175mm arms, 4-bolt. worn & scratched, but 8-spline & pedal threads are 100%.
$20.
Bottom bracket – Shimano BB-E551. 121mm across, internal cartridge type, 8-spline axel. Used. No play or binding. $10.
Bottom bracket – Shimano BB-5500. BC1.37x24, sealed cartridge type, 118.5mm length, 8-spline axel, used but no play or binding.
$10.
Crank arm (left only) – Tru-vativ Firex. 175mm arms, black, used.
$10.
Rear Derailleur (modified) – Shimano XT. Modified as chain tensioner for SS convert on vertical dropouts, used.
$10.
Front derailleur – Shimano LX. mount 34.9mm diameter post, bottom cable pull. Used.
$20.
Front wheel – Shimano WH-M535 16spoke, MTB. Rim brake only, with QR skewer, used.
$20.
Sold Skewers – Security type ‘5sided allen key’. Front & rear with ‘key’. Used.
$10.
Sold 'Bar ends – Tranz X. Silver, 90mm long. Clamps onto ‘bar diameter, used.
$5.
Seat clamp – Black, 27mm diameter (max 30mm), used.
$5.
Bidden cages – BBB. Black alloy. 2x, used.
$5.
Sold Shifters – Shimano LX 9speed (circa 2003). a pair, used.
$15.
A bike and a place to ride.
Marx
Users browsing this forum: Google Adsense [Bot], Howzat, just4tehhalibut, Wazza
