Low Normal: Yes
Speeds: 9-Speed
Max Sprocket: 34T
Min Sprocket: 11T
Front Difference: 22T max
Used: about 1,500km on road
$50
Shimano RD-M760 Deore XT Rear Dérailleur Rapid Rise SGS Long Cage
Low Normal: Yes
Speeds: 9-Speed
Max Sprocket: 34T
Min Sprocket: 11T
Used: a lot more than the above one, perfect working order though.
$30
Shimano FD-M761 Deore XT Front Dérailleur Conventional Down Swing
Swing Action: Conventional Down Swing
Rear Compatibility: 9-speed
Total Top-low Max. Capacity: 22T
Top-middle Min. Capacity: 12T
Top Gear Teeth: 44T
Cable Routing: dual-pull type
Chain Stay Angle: 66-69 deg
Seat Tube Band Mount: 34.9mm (no adapters)
Used: same as the RD-M760, perfect working order.
$20
Pickup Brisbane city business hours or add $10 for shipping anywhere else.
PM is best contact
RD-M960
RD-M760
FD-M761
