SOLD:WTS:Perth:CINELLI XA STEMS, silver 10.5 and black 10.0
brentono
Postby brentono » Sun Oct 04, 2009 10:00 am
Have 2x CINELLI XA STEMS, silver 10.5 and black 10.0
Both in good condition, as you can see, would look at $30ono a piece.
I am in Perth, so there would be postage and handling,
so maybe it's better to go local.
Can PM me if your interested, and make an offer.
BrentonO
Lone Rider- I rode on the long, dark road... before I danced under the lights.
Thoglette
Re: WTS:Perth:CINELLI XA STEMS, silver 10.5 and black 10.0
Postby Thoglette » Sun Oct 04, 2009 3:29 pm
brentono wrote:Have 2x CINELLI XA STEMS, silver 10.5 and black 10.0
Hi BrentOno,
I understand that these came in 26 mm and 26.4mm bar-diameter sizes. Any idea which these are?
CD
AzzA
Postby AzzA » Sun Oct 04, 2009 9:53 pm
Ahh, been looking for a black stem for a while. PM sent.
brentono
Postby brentono » Mon Oct 05, 2009 10:36 am
Hi Thoglette/Conrad,
Have put a micrometer, on both, and as the inner rim is serrated,
it is difficult to measure, would find it hard to believe there were
2 sizes, as I see with 0.4mm variation, it would make little difference.
I may be wrong, but at either setting it works?
As I write, there's interest in both, so you had better make contact, ASAP
BrentonO
brentono
Postby brentono » Mon Oct 05, 2009 10:39 am
Azza,
Got your PM and now reply
BrentonO
darkhorse75
Postby darkhorse75 » Mon Oct 05, 2009 5:29 pm
PM ed you, cheers.
brentono
Postby brentono » Tue Oct 06, 2009 9:50 am
Seems there is only one size, as I thought, this is the quote I picked up on the XA...
"The binder is drilled with 26.4mm diameter hole for the handlebar. Again, this 26.4mm is the unique Cinelli size that Cinelli makes their handlebars to. The hole on the inside, is then knurled, producing many small gripping peaks that lock onto and hold your handlebar."
Hope that helps,
BrentonO
brentono
Postby brentono » Tue Oct 06, 2009 9:57 am
Darkhorse75,
Have PM'd you,
BrentonO
brentono
Postby brentono » Tue Oct 06, 2009 11:27 am
Azza/Arran,
Have PM'd you
BrentonO
brentono
Postby brentono » Tue Oct 06, 2009 1:45 pm
Hi All,
Black stem is now gone, thanks to all who enquired
Darkhorse75 has a new stem to go on his Black Fixie,
BrentonO
brentono
Postby brentono » Tue Oct 06, 2009 1:52 pm
Sorry Azza/Arran you were a little slow in getting around
to replying, maybe next time.
BrentonO
brentono
Postby brentono » Tue Oct 06, 2009 4:03 pm
Hi All,
Siver stem is now gone, thanks to all who enquired
Radiodog has a new stem in the post, thanks Rob.
BrentonO
