SOLD [BNE] 2009 Giant XtC 16" frame $250
waynohh
Postby waynohh » Tue Oct 06, 2009 11:49 am
SOLD
Giant XtC ALUXX SL Butted Alloy frame
16".
1560g for medium, slightly less for this one, stiff and very fast.
1 1/8 Integrated headset, not included.
30.9mm seat tube ID / seat post OD.
27.2mm seat post adapter machined to fit flush in the seat post clamp.
68.0mm english BB.
Smooth BB face.
V-brake bosses and disc mount.
Designed for 100mm travel fork.
Designed for top swing front dérailleur, but conventional/bottom swing is also compatible.
Link to giant website:
http://www.giant-bicycles.com/ko-KR/partsaccessories/framesets/1055/29636/
Bought 05-04-2009 new for $525, done 2400km commuting, no trails, no impacts or damage.
$250
pickup from Brisbane, weekend delivery wouldn't be a problem either.
Can install BB's, cranks, cassettes, cut cables, etc, etc for you free. +$100 to build whole bike, as long as you bring everything else in clean, working order.
If someone needs forks, then you can take those as well for $200
Reba Race motion control, dual air.
1620g
Adjustable from 85mm to 115mm
No poploc
Spare set of enduro dust seals
Spare o-rings
Plenty of 5wt and 15wt oil.
Headset crown race installed.
$200
I'll do a full service when the o rings I've ordered arrive.
Geometry (unchanged between 2009 and 2010 models):
S
16" nominal sizing/frame size
575cm top tube length
118mm head tube length
73.5deg seat angle
70.5deg head angle
1061.5 wheel base
423mm rear center (chain stay length)
With 115mm travel, 11.0kg incl pedals excl accessories:
The frame has the wide down tube at the head tube and the same seat stays, etc as the domestic version
Not like the one pictured below.
You can get both versions on ebay if you need a larger size.
RHS:
LHS:
Size:
Seat Tube, clamp with 27.2mm adapter:
Rear:
Hanger:
Head Tube:
Dr_Mutley
Re: [BNE] 2009 Giant XtC Small 16" frame $300
Postby Dr_Mutley » Tue Oct 06, 2009 3:16 pm
I'll take the xtr and xt dérailleurs, xt shifters, and used 520 pedals....
What saddles u got?
waynohh
Postby waynohh » Tue Oct 06, 2009 4:52 pm
Saddles - nothing special
crappy WTB Rockey V $5
crappy womens selle something $5
Selle SMP Stike Extra $50
All the dérailleur and shifters are the previous gen stuff, but just kept working till I switched from rapid rise and to top swing.
Have spare conventional XT front - $10
<removed images of dérailleurs, etc>
Dr_Mutley
Postby Dr_Mutley » Tue Oct 06, 2009 7:49 pm
I'll grab the XT front dérailleur too thanks... I'll pm u tonite and work out payment and post ;-)
cheers Harry
waynohh
Re: WTS [BNE] 2009 Giant XtC 16" frame $300 updated pics
Postby waynohh » Fri Oct 09, 2009 10:04 pm
Cleaned, updated photos.
Users browsing this forum: MSNbot Media, Yahoo [Bot]
