WTB - [BNE] - Malvern Star Forks - 30's - 50's vintage
Postby peteGS » Sun Aug 26, 2012 6:38 am
I'm looking for a set of forks for my '39 Malvern Star 2 Star restoration.
Steerer tube appears to be 25mm (1") diameter and length is about 176mm.
They need to be suitable for 28" wheels with mudguards and they also need to have sufficient rake to clear the head of a little Ducati motor that will be mounted on it.
peteGS
by BNA » Mon Aug 27, 2012 7:43 am
Re: WTB - [BNE] - Malvern Star Forks - 30's - 50's vintage
Postby utedeej » Mon Aug 27, 2012 7:43 am
I've got a set of malvern star forks that have the star in the fork crown. Will have a look and measure them today to see if they could be of use.
utedeej
utedeej
Postby utedeej » Mon Aug 27, 2012 7:52 am
Sorry mate, just checked quickly and the steerer is only a 145mm. Good luck with the chase
utedeej
Postby 240ZR » Mon Aug 27, 2012 3:50 pm
I have a really old set of forks which you have to spread apart to get the front wheel on as the ends (drop outs) are not slotted if you no what I mean, & the steerer is 180mm.
240ZR
Postby peteGS » Mon Aug 27, 2012 10:20 pm
utedeej wrote:Sorry mate, just checked quickly and the steerer is only a 145mm. Good luck with the chase
Bugger! But thanks for checking...
peteGS
Postby peteGS » Mon Aug 27, 2012 10:23 pm
240ZR wrote:I have a really old set of forks which you have to spread apart to get the front wheel on as the ends (drop outs) are not slotted if you no what I mean, & the steerer is 180mm.
180mm steerer should be fine... can you measure the fork leg lengths and the rake at all?
This is what I have now, and these are for 27" wheels:
I need longer fork legs and a larger rake...
peteGS
Postby peteGS » Sun Sep 02, 2012 9:41 pm
Bumpity bump... noone has any floating around? My quest continues...
peteGS
Postby 240ZR » Mon Sep 03, 2012 4:38 pm
The measurements on mine are 385mm & 90mm.
Nick.
240ZR
Nick.
240ZR
Postby peteGS » Mon Sep 03, 2012 7:54 pm
240ZR wrote:The measurements on mine are 385mm & 90mm.
Nick.
Thanks Nick, they look promising! Can you confirm the rake is measured from the centre of the steerer to the centre of the axle? And the fork leg length is measured vertically from under the shoulder to the centre of the axle? I realise my diagram is pretty crappy and may be misleading so best I double check :)
peteGS
Postby 240ZR » Sat Sep 08, 2012 4:07 pm
Nick.
Hi Pete, the measurement are 380 & 85mm.
240ZR
Postby peteGS » Sun Sep 09, 2012 7:47 am
Sounds like they should be worth a try Nick, will shoot you a PM.
peteGS
Postby Dan » Thu Sep 13, 2012 11:41 am
Perhaps too short in the steerer Pete, but did you see these?
(Presuming of course its not you offloading your unsuitable extras)
Postby peteGS » Sat Sep 15, 2012 7:03 am
diggerdantheman wrote:Perhaps too short in the steerer Pete, but did you see these?
Yup, sure did! Got flagged in my eBay saved search :)
Steerer is good, but getting confirmation on the rake measurement as the photos are really hard to read them from. The good thing is I could go and pick them up this week as I have a week off work.
Nick's forks look good but not 100% sure on brand as yet, checking that out at the moment too.
Thanks guys!
peteGS
Postby peteGS » Thu Oct 04, 2012 10:04 pm
After (im)patiently waiting for 2 1/2 weeks I finally got the eBay forks, but unfortunately they're too short. The rake is good but the fork legs aren't long enough.
Here's a comparison with the forks I have now which are tweaked and for 27" wheels:
So I'm still looking for them...
Looks like 380mm or longer for the fork leg and at least 80mm of rake:
It's highly unlikely I'll get a chance to attend the upcoming swap meet unfortunately...
peteGS
Postby peteGS » Sat Oct 20, 2012 8:46 am
Bumpity bump... still looking if anyone's got a pair...
peteGS
Postby milph1988 » Sun Nov 11, 2012 10:37 am
I have some MS forks with a long stem are bent, so if you can straighten them you can have them. It might not be right but it could be worth a try. If i can get them OFF!!
PS you'll have to email me for a pic, i cant seem to work out how to do it
milph1988
Postby peteGS » Sat Nov 17, 2012 7:23 am
milph1988 wrote:I have some MS forks with a long stem are bent, so if you can straighten them you can have them. It might not be right but it could be worth a try. If i can get them OFF!!
Thanks for the offer but will definitely pass on some bent ones... on a motorised bicycle I think there's a bit too much risk in them being weakened.
I did end up getting another almost complete bicycle but that means I'm going to end up with two minus one set of forks, so I'm still on the lookout for a pair.
I'm beginning to think I'll restore two... one for the motor and one for me to start getting some exercise again... :wink:
peteGS
Users browsing this forum: 240ZR, cev, rheicel, richo74, seecuta
