WTS - HBT - assorted retro parts
Postby LG » Fri Sep 28, 2012 6:50 pm
I'm not sure whether 'retro' or 'vintage' is the correct term for these, but here goes.
Decided to have a clean out of 'spare stuff' I'll never get round to using. Prices as marked, but feel free to make a reasonable offer. Postage available at cost.
Started cleaning my hubs draw. All these hubs have had bearings inspected, re-greased and adjusted. I have a small pile of discard hubs on my work bench with pitted cones, cups & bent axles, these listed are all fine. Most could do with a wee polish:
Suzue high flange - 126mm rear spacing, 36 spokes, need a bit of a polish, good for old school BMX or road $25
SR low flange - 126mm rear spacing, 36 spokes, spin very nicely, no skewers sorry $20
Normandy high flange - I think 120mm rear and 96mm front spacing (for a 70s peugeot), 36 spokes, simplex skewers $20
Shimano high flange front and rear - 126mm rear, 36 spokes for both, forgot to take a pic sorry, but can email pics if you PM me $25
Campagnolo athena/victory/triomph (I have no idea which as they all seem the same) - 36 spoke, 126mm rear spacing, no skewers sorry, spin lovely and smooth just like a campag should $40
Wheels:
27 X 1 Sun mistral rims wheelset - shimano front hub, joytech rear, 36 stainless steel spokes on each, a nice set of wheels $40
Rigida chromolux/normandy high flange wheelset (1970s peugeot) - bearings are smooth and rims are running true, need a clean $30
Rigida chromolux rims (2) - 36 spoke holes, round and ready to build up, suit a 1970s peugeot $10
Cranks:
Raleigh 3 spider cottered cranks - 40-49 tooth chainrings, good condition $10
Raleigh heron cranks - single 46 tooth chainring, good condition $10
Handlebars:
Cinelli Campione del Mondo - 43cm measured centre to centre at the drops, one side of the clamp area has been trashed where somebody fit it into a nitto stem (I used to keep my computer on it), grooved for aero brake levers $10
Cinelli Giro d'Italia - 41.5cm measured centre to centre at the drops, some marking on the clamp area $10
Probably more to come...
LG = Low Gear
LG
by Forum Ads » Sat Sep 29, 2012 11:25 am
Re: WTS - HBT - assorted retro parts
Postby LG » Sat Sep 29, 2012 11:25 am
Campy hubs, giro d'Italia bars, and the raleigh heron cranks appear to be sold.
Forgot to mention, the other raleigh cranks are 165mm length and a chainring can be easily removed if you'd like to run it as a single.
LG = Low Gear
LG
Postby simonn » Sat Sep 29, 2012 11:34 am
LG wrote:Forgot to mention, the other raleigh cranks are 165mm length and a chainring can be easily removed if you'd like to run it as a single.
Do you know what the BCD of the 3 bolt cranks is? I might have a need for them if the BCD is correct (need to find out what I need now :)).
simonn
Postby LG » Sat Sep 29, 2012 12:49 pm
Simon, I'm not sure how to work out BCD with 3 spider cranks, but these are 100mm or 101mm (depends how I read the calipers) from centre to centre between the chainring bolts.
Also moving down a drawer, found a few more things to add:
Dia Compe Cherry brake set $25
Shimano sora 3300 brake calipers $20
Freewheels - note I haven't used either of these so have no idea what condition the teeth are in:
Shimano 6208 corncob 13-18 6 speed screw on freewheel $15
Sachs 12-21 8 speed $15
Another set of drop bars - these are deep aprox 180mm c/c drop, I assume they are for track or fixie/single speed riding (way too deep for me). 395mm wide c/c and appear to take a 26.0mm clamp, designed to have bar tape right up to the stem $10
LG = Low Gear
LG
Postby LG » Sat Sep 29, 2012 6:58 pm
The 600 freewheel is sold, but I've found another the same in the drawer, just a wee bit greasier.
LG = Low Gear
LG
Postby metalrideroz » Sun Sep 30, 2012 12:04 pm
I will take those raleigh double ring cranks if Simonn doesn't. Postage to 6173 WA? Do you have any hub seals that press into the hub around the cone nut off a 70s normandy or maillard hub in you hub drawer?
Thanks.
metalrideroz
Postby LG » Sun Sep 30, 2012 6:14 pm
Front or rear dust seal? I have a 70s Normandy rear hub shell with 2 seals (no axle etc) which you can probably have.
If simonn doesn't want the cranks they're yours, postage will be $17 for a package a shade over 1kg.
Edit: looks like a 3kg pre-paid sachel will be $12 if they fit.
LG = Low Gear
LG
Postby LG » Tue Oct 09, 2012 7:21 pm
Update: both sets of cranks are sold as are the normandy hubs, rigida rims, and the normandy/rigida wheelset. From the above I still have for sale:
Suzue high flange hubs
SR hubs
High flange shimano hubs
Cinelli campione del mondo bars
Deep drop bars
Sun rims 27 X 1 wheelset
Sachs 8 speed screw on freewheel
A shimano 600 corncob freewheel
Sora brakes
Cherry brakes
LG = Low Gear
LG
Postby LG » Thu Oct 25, 2012 12:48 pm
Sora brake callipers and the 600 corncob freehweel is sold, still have the following for sale.
SR hubs
Deep drop bars
Cherry brakes
Also like to add:
Spinaci bars - not sure if these are cinelli or not. Good condition, with some surface rust on bolt heads. $15 (or $7.50 if you also buy a set of bars :lol: )
1980's Shimano exage road groupset. Good condition, more photos available on request. 6 speed index shifters, shimano SLR aero brakes, 52-42 biopace chainrings, also with a set of joytech hubs (but I can swap these for a set of high flange shimano if you wish) $65
LG = Low Gear
LG
Users browsing this forum: calvinlsyd, Google [Bot], jamesn184, tony.montana
