WTS - [NSW] Ellsworth Evolve - 29er dual suspension
Postby mike95 » Sun Dec 09, 2012 4:43 pm
Item: Ellsworth Evolve 29er - 4" front and rear, Blue smoke anodised.
Item Condition: good
Reason for selling: not getting enough use, prefer hardtail 29er for the trails i ride.
Price and price conditions: $2400ono
Extra Info:
Bike is in great condition.
This has been a great bike with legendary Ellsworth quality, the current build is more toward the trail bike end of things but can be built up lighter for racing.
I have only recently swapped the brakes for the new shimano XT / ice tech setup.
1x9 setup with X0 gripshift, & salsa 32T ring + E13 XCX ST guide is only a few rides old.
Nobby Nics are near new.
Ritchey foam grips are near new
Can swap some parts over for reduced price - eg -
xt brakes / rotors for Hayes stroker trail brake.
salsa 32T ring + E13 XCX ST guide for standard triple ring setup with x9 front mech
Seatpost has a few marks on it from being lowered & raised when the misses rides the bike a short distance to work.
chain has a few spots of surface rust & can supply a new sram chain if required.
Bike recently serviced & bottom bracket removed & re greased.Both Fork & shock serviced approx 12 months ago.
Component build
Fork: Manitou Minute 29er 100mm w/20mm thru axle - white!
Shock: Fox Float R with pro pedal
Shifters & mechs: 9 speed SRAM X9 rear mech, x0 grip shift with SRAM cassette and chain ( option for x9 trigger if you prefer )
Crankset: Truvativ Stylo 175mm - salsa 32T single ring with E13 XCX ST guide
Headset: Chris King pewter
Stem: Syncros 110mm - white!
Handlebar: Salsa Pro moto carbon flat
Brakes: 2012 Shimano XT with 160mm ice tech rotors
Front Wheel: Sun EQ27 rim on DT340 20mm hub w/ Nobby Nic 2.25"
Rear Wheel: Sun DS-2 rim on Ringle hub w/ Nobby Nic 2.25"
(Both with Stan's tubeless conversion)
Seatpost: Kore i-beam w/20mm layback
Saddle: Kore
Pedals: - wellgo MG-1 magnesium or Shimano spd m20's
Grips - ritchey foam
Pictures:
mike95
Users browsing this forum: drsnoopy
