[Perth] Vintage bikes and parts, nos etc
metalrideroz
Postby metalrideroz » Sun Apr 14, 2013 2:48 pm
Due to illness and medical expenses I have some things for sale. I may add more later.
Pickup from 6175. Postage is available on smaller items.
item: 60s road/track bike
price : $500
postage: no
details:
1964?(s.no. on seatube ends in 64) racer
54cm seat tube x 58cm top tube
cyclo dropouts
williams crankset
brooks vinyl saddle
arai gold brake
ukai rims
galv spokes
Velox Engineering Works fixed/freewheel rear hub
lyotard pedals
campagnolo nuovo sport derailleur and single shifter
4 speed everest freewheel(with period "the coventry england" chain)
currenly set up as fixed with rear brake, originally came with the 4 speed campagnolo set up which sort of works. Rides best as single speed anyway. Don't pay too much attention to the measurements, it's medium-ish, 58cm top tube feels short. Pictured saddle height is a compromise for average legged 174cm person. At full leg extension height it's pretty much drops only. Good for the velodrome, not great for the road.
Frame is lightweight thin wall tubing despite the simple lugs.
Only a small amount of surface rust on the toptube.
Some rust on rear rim.
Tiny, tiny "indent" in the seat tube, needs to be in the right light to see it. Can't feel it.
Right rear seatstay has small "wiggle" near top. Non-issue, bike
tracks perfectly straight and is super stable. You can go full power in the drops then throw into upright no hands, bike doesn't move.
comes with the follwing extras
NOS Zues alpha junior derailleur and shifter
raleigh cottered crankset
kkt quill pedals
monitor brake with a lever
new brown cloth bar tape
new cotter pins
Expensive? Sell campag and zues stuff then you have a cheap, quality vintage fixed or singlespeed.
click on album in links for some extra photos
item: shogun Katana road bike
price : $100
postage: no
details:
55cm tange infinity
exage 7 speed groupset
Pictured wheels, seat and post not included
hoods not pictured but included
most parts cleaned but not polished. need to do rear derailleur and shifters.
levers are smoke colour
scratch on seat tube
needs consumables, less than $100 from crc etc.
If you have a spare wheelset,seat and post it would make a half decent, cheap commuter.
item: basic dia compe aero levers.
price: $5
postage avilable: yes
details: hoods nearly gone but might be usable with a clean if your not fussy
item: modolo corsa non aero levers
price: $20
details: hoods no good
item: suntour seven shifters, fd, rd
price: $20
details: ok condition, cables stuck in shifters
item: nos shimano non aero levers
price: $15
item: clb non aero levers
price: $20
details: look unused, probably nos
item: 600 fd, rd, shifters, levers
price: $80 for lot
details: needs new jockey wheel on rd, will include
item: various crank and pedal caps
price: $2 plus postage
details:some nos, if you can spot a pair $2 plus post(might fit in envelope)
item: various 1 inch quill stems
price: $10 each
details: 60-120mm available
item: nos stem wedges
price: $5 each
details: round type with ridges on side
item: dura ace 7400 7 speed freewheel
price: $30
details: 12-17 or 19 can't check at moment, light use.
item: Galli track hubs
price: $50
details: high flange, 36h
got these as shells only
120mm + spacing
pictures axles and cones will work but you'll need the right size seals
confusing aluminium bearing races? I thought someone had pressed the cups
out but the bit the seals press into is still there?
item: Zues left side BB cup
price: $10
details: no wear on bearing surface
item: Suntour NJS stamped track hub lockring
price: $15
details: probably nos, looks unused(came in box with another packaged nos one)
item: Sante headset
price: $45
no bearings and some rust dots from storage
item: look clipless pedals
price: $15
details: grey, lightly used. unsure of cleat ype.
item: nos 600 front hub seals
price: $20 a pair, profiteering!
details: 5 pairs available
item: nos chrome plastic crank caps
price: $10 pair
details: no taper on edge
item: nos pearl silver/white crank caps
price: $10
details: maybe sante?
GreenGaz
Re: WTS Perth Vintage bikes and parts, nos etc
Postby GreenGaz » Sun Apr 14, 2013 3:09 pm
Hi, any idea on postage cost to 4170 on the 600 gear?
Dimitrizee
Postby Dimitrizee » Sun Apr 14, 2013 6:07 pm
Sent PM regarding crank caps..
Postby QuangVuong » Sun Apr 14, 2013 7:10 pm
Ill grab that Sakae stem! PM'd
Postby familyguy » Sun Apr 14, 2013 9:31 pm
Those Look pedals would use the older delta cleats FYI. I have a pair of those and the red and white version. For early models, they are still insanely good pedals. I can't justify another set...
I am interested to know what the shaped stem to the left of the Sakae is though?
metalrideroz
Postby metalrideroz » Mon Apr 15, 2013 10:37 am
familyguy wrote:Those Look pedals would use the older delta cleats FYI. I have a pair of those and the red and white version. For early models, they are still insanely good pedals. I can't justify another set...
Thanks for cleat info. Shaped stem is 120mm, i think its that taiwan or japan brand, something-jin? Theres a scratch along the top aswell.
bradz
Re: [Perth] Vintage bikes and parts, nos etc
Postby bradz » Mon Apr 15, 2013 2:04 pm
Keen on some quill stems.
PM Sent
HappyHumber
Postby HappyHumber » Mon Apr 15, 2013 2:35 pm
'zact same as me, Jim. As far as dedicated road pedals go - I ownly own/use second hand old Look Delta compatible pedals. Shimano pedals were at one stage for a while using the mech under license (I presume) from Look before they introduced their SPD/SL system.
Delta cleats & covers are all still readily available from Wiggle / The Fleabay etc. I'd recommend these as a good starter road pedal.... once I started on them myself 3 or 4 years ago, I never bothered with newies and I have about 5 or 6 diff pairs :D
- Kym
Proud to have been a regular during BNA's heyday. I'm still reachable by PM (email alerts) - dec 2016
metalrideroz
Postby metalrideroz » Fri Apr 19, 2013 12:24 pm
Various stems and crank caps sold. Thankyou people.
Shogun now $80
Vintage now $450
metalrideroz
Postby metalrideroz » Mon May 06, 2013 9:57 am
Shogun frame+fork+headset now $50
Will seperate; Campagnolo shifter, derailleur, cables etc with Everest freewheel $70
Nos Zeus dearailleur, shifter etc. $50
metalrideroz
Postby metalrideroz » Mon May 20, 2013 11:27 am
bump.
metalrideroz
Postby metalrideroz » Wed Jun 05, 2013 4:25 pm
BUMP. Offers if you want.
Denny
Postby Denny » Wed Jun 05, 2013 8:29 pm
Hi
Keen on the dura ace cassette, pm sent.
dv
Postby dv » Wed Jun 05, 2013 11:36 pm
PM'ed re: vintage shifters and derailleurs
metalrideroz
Postby metalrideroz » Sat Jul 13, 2013 2:56 pm
shogun and dura-ace freewheel sold. Other stuff still available.
metalrideroz
Postby metalrideroz » Sat Aug 03, 2013 12:15 pm
bump. Campag gear stuff off vintage bike sold. Sante headset sold.
metalrideroz
Postby metalrideroz » Sat Aug 24, 2013 1:28 pm
Bump. Any questions ask.
metalrideroz
Postby metalrideroz » Sat Oct 12, 2013 2:53 pm
Vintage bike now fixed only. Will need a dust off and polish. $320
Well used early 90s 105 Cranks, brakes, levers, $30
Will post updated photos soon along with some other parts.
martc101
Postby martc101 » Sat Oct 12, 2013 4:44 pm
Hi, are any of the stems 21.10 steerer diameter?
metalrideroz
Postby metalrideroz » Sun Oct 13, 2013 1:41 pm
martc101 wrote:Hi, are any of the stems 21.10 steerer diameter?
No, all 22.2.
item: shimano pedal tool and one key release set
price : $15
postage: yes
details: One key release came off those weird select/r?a? cranks so not sure if they will fit a normal crank.
item: sr laprade post
price : $15
postage: yes
details: 27.0 needs mega clean/polish.
item: 1055 7spd groupset
price : $50
postage: yes
details: Slight wear on chainrings. Will clean up ok if you know what you're doing. No hoods, will throw in some borderline usable ones. Brakes are nutted not recessed for some reason.
item: clb? stronglight? headset top bit
price : $10
postage: yes
details: needle bearing. Super light, plastic cup!
item: raleigh saddle bag
price : $10
postage: yes
details: New. nylon?/canvas? medium to large size. Suit saddle with rear bag slot things.
item: campagnolo skewer
price : $10
postage: yes
details: bent, get the hammer out.
item: various 6spd indexed downtube shifters
price : $10 set
postage: yes
details: 5 shimano, all have different pattern grip area. 1 suntour accushift.
item: kusuki steel drops
price : $10
postage: yes
details: narrow 36cm c-c. For your fixie?
item: sugino fluted post
price : $10
postage: yes
details: 26.0
item: SDG titanium railed saddle
price : $0
postage: yes
details: free with something else. needs recover and some foam missing.
item: biopace crankset
price : $15
postage: yes
details: 170mm, steel chainrings.
item: lapize toe clips
price : $5
postage: yes
details: Made in france. Medium. chrome pitted but still look ok to use.
item: 60s bike
price : $320
postage: yes
details: see first post for details. Now fixed only. Comes with new cotter pins and a brake/lever.
item: 3spd bicycle
price : $120
postage: no
details:shimano 3cc 3 speed coaster hub. 57cm.
ecru
Postby ecru » Sun Oct 13, 2013 5:15 pm
Would you happen to have a square taper 175mm crankset? Say 52ish/36ish.
metalrideroz
Postby metalrideroz » Mon Oct 14, 2013 1:08 pm
ecru wrote:Would you happen to have a square taper 175mm crankset? Say 52ish/36ish.
No. The 105 cranks are the closest at 172.5mm, 52/42. That chainring combination is not standard you would have to buy a smaller inner chainring. I don't think you can get a 36t in 130bcd, 39t is more common.
Thanks.
metalrideroz
Postby metalrideroz » Sun Oct 20, 2013 2:16 pm
Look pedals and 600 parts sold.
HappyHumber
Postby HappyHumber » Sun Oct 20, 2013 5:09 pm
PM'ed re: CLB Levers.
- Kym
PeppeX
Postby PeppeX » Mon Oct 21, 2013 10:18 pm
Any quill stem left? I am after something 10cm stem length and something more flat (not tilted down so much). I assume they are 25.4mm?
