[ADL] - 57cm Alan Frame, Nitto Bars, Track BBs, Saddles etc.
Rusty62
Postby Rusty62 » Fri May 03, 2013 12:15 am
Item: Alan Aluminium frame - Some Damage
Price: $60
Postage Available: courier at buyers cost
Details: 57cm x 57cm lugged aluminium frame. One of the first Alu frames I believe. I bought this intending to repair the cracks pictured, but I no longer have the time or money. It's in fairly rough condition but still looks fairly nice. maybe repair it and ride it again or polish up and use as a display piece. Headset included (Shimano 600 I think - not sure of condition)
OTHER ITEMS
Item: Campagnolo Seatpost 26mm
Price: $15
Postage Available: yes, buyer pays
Details Campagnolo seatpost 26mm, unsure of model, very scratched up on the cylindrical part, not too bad on the streamlined part. single bolt clamp.
Item: Vittoria Rubino Pros (pair) in White
Price: $20 for the pair
Details 700c x 23 about 80% to 90% of life remaining, no slits or holes. Decided I didn't like the colour
Item: Hutchinson Equinox 2 - white stripe
Price: $15
Details 700C x 23 95%+ life left, still has seam visible less than 150ks on it. Taken off new bike when matching tyre was destroyed by road debris. no cuts or holes
Item: Shimano 600 aero levers
Price: $20
Details not sure of year, as there's no visible serial no. but in very good condition, minimal scratching on lever - would likely polish out perfectly.
Item: Nitto B125 NJS
Price: $60
Details Steel version (I believe). 25.4 clamp diameter, 360 wide. literally perfect condition except a small, barely noticable scratch on underside of bars near clamp area.
Item: Un-branded black stem 110mm
Price: $5
Details 26mm clamp, 1inch steerer, 110mm length, angle somewhere around 4-6 degrees. faceplate bolts quite rusted - cosmetic only, still fits allen key and threads are fine.
Item: Black Shimano 105 5700 Hoods
Price: $10
Details used for about 300kms, replaced with Hudz
Item: Shimano pedals - PD-A550
Price: $15
Details minimal scratching, plastic cages snapped, repaired with tape. no straps
Item: Token carbon BB - Sq taper/68mm/102mm - SOLD!
Price: $30
Details 102mm spindle. 68mm, BSA 1.37 x 24T, ISO square taper. sealed bearings, cro-mo axle and carbon body. Still in box, fitted once, realized spindle was wrong size. some cosmetic scratches from installation.
Item: Origin8 Torq-Lite Pro Pulsion Bottom Bracket
Price: $20
Details Fitted once and never again used. 115mm spindle. 68mm shell, BSA 1.37 x 24T, Campagnolo square taper, cro-mo axle and aluminium shell and cups. Claimed weight - 235g
Item: Rav X Race X saddle - Black
Price: $25
Details in good condition - some dirt and slight wear on saddle.
Item: Fizik Antares Saddle -Black/White
Price: $45
Details Good condition aside from moderate wear on surface of saddle. No abrasions or crash damage. With the Fizik clip system on underside.
Jangari
Re: [ADL] - 57cm Alan Frame, Nitto Bars, Track BBs, Saddles
Postby Jangari » Fri May 03, 2013 10:12 am
Rusty62 wrote:Item: Token carbon BB - Sq taper/68mm/102mm
Price: $30
Dibs!
scotto
Postby scotto » Fri May 03, 2013 1:32 pm
might call dibs on the bars. will need to measure my sons track bars, but i think these are narrower, which is what i want. will repost from home this arvo.
bookworm1707
Postby bookworm1707 » Fri May 03, 2013 3:10 pm
Any of a try/buy for the fizik saddle? Will PM you.
240ZR
Postby 240ZR » Fri May 03, 2013 4:25 pm
Dibs on Campy seat post
Rusty62
Postby Rusty62 » Fri May 03, 2013 5:52 pm
Campy Seatpost reserved for 240ZR - awaiting PM to sort postage, payment etc.
Fizik saddle being trialled by bookworm1707 on Monday
Bars still reserved for Scotto - awaiting the decision
Token BB SOLD - payment received and ready for postage
scotto
Postby scotto » Fri May 03, 2013 7:21 pm
yep, i'll take the bars. pm me your bank details and postage to nsw 2153 pls rusty.
thx scott
LG
Postby LG » Fri May 03, 2013 8:38 pm
For some strange reason I'm tempted to grab the ALAN for a wall ornament. Would you be willing to pull the fork out, bubble wrap the tubes & fork, strap the fork to the side and send via Aus Post? A box & freight would be a cost killer for me.
LG = Low Gear
Postby QuangVuong » Fri May 03, 2013 10:24 pm
Ill grab them RX100 pedals! PM sent
240ZR
Postby 240ZR » Fri May 03, 2013 10:27 pm
Sent u a PM earlier today Rusty but still in my outbox, check to see if ur inbox is full.
Re: seat post, Vittorias & Alan.
Rusty62
Postby Rusty62 » Fri May 03, 2013 11:52 pm
Pedals now gone to QuangVuong (awaiting payment and postage details)
Bars Gone to Scotto (awaiting payment and postage details)
Seatpost, Rubinos and ALAN held for 240ZR
LG, Sorry, but 240ZR did message me before you posted here, so he has first priority on the frame. You're next in line if it falls through.
Rusty62
Postby Rusty62 » Sat May 04, 2013 12:12 pm
Seatpost, Rubinos and ALAN all gone to 240ZR, sorry LG.
LG
Postby LG » Sat May 04, 2013 2:40 pm
To be honest rusty, I'm quite relieved :lol:
LG = Low Gear
Rusty62
Postby Rusty62 » Mon May 06, 2013 3:13 pm
Fizik now sold! thanks Bookworm :)
Still for sale are the following:
Origin8 BB
RavX saddle
Stem
Shimano 600 levers
Hutchinson tyre
Ultegra Hoods
Rusty62
[ADL] - Price Drop: Tyres, Levers, Bottom Bracket, Saddle et
Postby Rusty62 » Sun May 12, 2013 11:09 pm
Still available and with reduced prices:
Price: reduced to $10
Details: 700C x 23 95%+ life left, still has seam visible less than 150ks on it. Taken off new bike when matching tyre was destroyed by road debris. no cuts or holes
Price: reduced to $15
Details: not sure of year, as there's no visible serial no. but in very good condition, minimal scratching on lever - would likely polish out perfectly.
Price: $5
Details: 26mm clamp, 1inch steerer, 110mm length, angle somewhere around 4-6 degrees. faceplate bolts quite rusted - cosmetic only, still fits allen key and threads are fine.
Price: $10
Details: used for about 300kms, replaced with Hudz
Details: Fitted once and never again used. 115mm spindle. 68mm shell, BSA 1.37 x 24T, Campagnolo square taper, cro-mo axle and aluminium shell and cups. Claimed weight - 235g
Price: reduced to $20
Details: in good condition - some dirt and slight wear on saddle.
bigfriendlyvegan
Postby bigfriendlyvegan » Mon May 13, 2013 5:25 pm
PM'd re saddle and stem
Rusty62
Postby Rusty62 » Fri May 17, 2013 12:43 pm
Stem and Rav X saddle now sold and posted.
Still remaining:
Price: $10
TedDancin
Postby TedDancin » Fri May 17, 2013 12:53 pm
PM sent re tyre and 600 levers.
