(MELB) Surly LHT Fork, CC Headset, Headset adapter, stem etc
axeman74
Postby axeman74 » Sun Oct 27, 2013 12:39 pm
A few more item surplus to requirements.
Pickup from South Morang, or post Australia wide. PM me for a postage price>
- SURLY LHT 26" Touring Fork. Brand new. Best touring fork on the market. Google for specs. 300mm steerer uncut, full set of rack mounts. This was trial fitted to a frame so has some teeth marks on the dropouts, but is otherwise in brand new condition. $80
- Cane Creek SC1 1" Threadless headset, nice quality sealed bearing headset, hard to find decent quality 1" threadless nowadays. $15.
- Bontrager SSR MTB Stem, 1 1/8 steerer, 31.8 clamp, 90mm length, $10
- Satori "Heads Up" Steerer length extender, Brand New, 1 1/8 threadless, extends your steerer length if it has been cut too short. $20
- Bikelane Seat post clamp with rack mounts, brand new, 28.6, use to attach rear rack mounts when you do not have frame eyelets. $10
axeman74
Re: (MELB) Surly LHT Fork, CC Headset, Headset adapter, stem
Postby axeman74 » Tue Oct 29, 2013 8:35 pm
BUMP
garthmci
Postby garthmci » Tue Oct 29, 2013 11:09 pm
That seatpost clamp, does it replace the seatpost clamp, or jus go above it on the seatpost?
HappyHumber
Postby HappyHumber » Tue Oct 29, 2013 11:47 pm
garthmci wrote:That seatpost clamp, does it replace the seatpost clamp, or jus go above it on the seatpost?
I'd say it's for the more modern frames where there is no actual clamp integral to the seat post. It's a seperate unit that sits slightly atop the seat tube. It'd only suit that sort of frame, replacing your original, garden variety clamp.
OP may clarify or correct as they see fit :)
- Kym
Since I keep misplacing my common sense down the shed, I guess I'll have to borrow someone elses off the internet.
axeman74
Postby axeman74 » Wed Oct 30, 2013 5:39 am
Thanks you Happyhumber, you are 100% correct. This replaces your original 28.6 seat post clamp, so your frame need to have a removable clamp.
Axeman74
axeman74
Postby axeman74 » Sun Nov 10, 2013 9:13 am
BUMP
axeman74
Postby axeman74 » Tue Nov 12, 2013 6:53 pm
LHT Fork sold, all other items still available
HappyHumber
Postby HappyHumber » Tue Nov 12, 2013 7:07 pm
I can't seem to find any Cane-Creek doco for the SC-1. My Google-Fu is failing me.
- Kym
axeman74
Postby axeman74 » Tue Nov 12, 2013 8:13 pm
Happyhumber, I think these have been out of production for some time so probably wont find much online about them. If you need any info re dimensions just let me know and will be happy to oblige.
HappyHumber
Postby HappyHumber » Wed Nov 13, 2013 10:18 pm
pm'ed for techo discussion :)
- Kym
axeman74
Postby axeman74 » Mon Nov 18, 2013 4:55 pm
Cane Creek Headset sold pending payment
baabaa
Postby baabaa » Mon Nov 18, 2013 8:09 pm
http://old.canecreek.com/manuals/Headse ... ctions.pdf
maybe the 1" version of the S3 which is the 1 1/8"?
axeman74
Postby axeman74 » Fri Nov 22, 2013 8:34 pm
BUMP Satori headset extender reduced to $15
axeman74
Postby axeman74 » Wed Dec 11, 2013 10:05 pm
Bump
axeman74
Postby axeman74 » Tue Dec 17, 2013 10:05 pm
Bontrager stem sold, steering adapter and clamp still available
axeman74
Postby axeman74 » Fri Jan 03, 2014 4:43 pm
Bump
dominicj
Postby dominicj » Fri Jan 03, 2014 5:24 pm
Have to check seat tube diameter but if it fits I will take the clamp.
axeman74
Postby axeman74 » Fri Jan 03, 2014 5:53 pm
Ok mate let me know thanks
