[SYD] - 9 Speed Tiagra Parts & Other Goodies
tyliftw
Postby tyliftw » Fri Jan 03, 2014 11:24 pm
As part of my new year's cleanup, I'm letting go of some Shimano Tiagra 9 speed parts that are gathering dust in the corner. They are a mixture of 4400 and 4500 series parts. Pickup is available in Sydney (Kingsgrove/Hurstville area), or postage can be arranged, at buyer's cost. However, local buyers will take priority. Willing to take offers. Worst I'll do is say no. :)
#1: Tiagra 4500 Shifter Set - $70
Happens to be leftover from a groupset that I bought, and I have no use for the shifters. Condition is quite good, gears click through fine, a few scratches and marks on the lever blades.
#2: Tiagra 4400 Shifter Set DAMAGED - $30
Used to be mounted on my friend's bike before he swapped them out. LHS shifts absolutely fine, no dramas whatsoever. RHS clicks fine for about 3 or 4 gears, then seems to jam. However, it is possible to cycle through the rest of the gears, although you will have to press quite hard on small lever to get to the rest of the gears. Cosmetic condition is quite good, although RHS lever seems to be bent. Could be used as is on a beater, repaired or salvaged for parts.
#3: Tiagra 4400 Crankset 52/39 170mm - $40
Also used to be mounted on my friend's bike, before switching over to a compact. Chainrings seem to be in good condition, no real issues while in use. However, slight damage to the drive side square taper was discovered on removal, looks like bike's previous owner tried to take it out. May be slight damage to threads, although I was able to remove the crank using a crank puller without too much drama. Closeup of damage is included.
#4: Tiagra 4400 Rear Derailleur - $15
Had no problems while in use, condition is great for its age.
#5: Tiagra 4500 Rear Derailleur - $20
Superficial scratches, seems to be working fine.
#6: Tiagra 9 speed 11-25 Cassette - $10
Relatively low mileage. Missing a 1mm spacer that goes between one of the cogs, but that's all.
#7: Sora 3300 Brakeset - $20
#8: 3T Stem - $10
-17 degree, 120mm length, 26.0mm clamp. Some rust on faceplate bolts.
Shoot me a PM if you're interested, or for more details and photos!
Cannondale CAAD7 SRAM Rival
Centurion Triathlon Master Ultegra 6500
tyliftw
Re: [SYD] - 9 Speed Tiagra Parts & Other Goodies
Postby tyliftw » Mon Jan 06, 2014 3:01 pm
All parts apart from cranks sold, pending payment.
Users browsing this forum: Google Feedfetcher, utedeej
