Velocity A23 Tubeless 1508g wheelset - sensible 24/28h
Velo13
Postby Velo13 » Fri Feb 14, 2014 1:01 pm
XLR8 built wheelset (1506g) using Velocity A23 wide tubeless rim. New freehub (Campag or Shimano).
Demo wheelset ridden for less than 500km (incl once in the rain). Very good used condition. Straight and round. Good and even spoke tensions.
$575 delivered to the mainland east coast. RRP is $999 for this wheelset.
As follows:
Velocity A23 tubeless ready rims (silver). 24h front, 28h offcentre rear.
Black DT Aerolite spokes (DT version of CX-Rays) - radial front and non-drive side, 2x driveside
Brass nipples
Velocity Pro Hubs (top quality ABEC 5 bearings from Enduro in USA)
Will be fitted with a new freehub (11s Campag or 10s Shimano - your choice).
rheicel
Re: Velocity A23 Tubeless 1508g wheelset - sensible 24/28h
Postby rheicel » Fri Feb 14, 2014 1:04 pm
Oh Dear, this is so tempting!
Image Image
Velo13
Postby Velo13 » Fri Feb 14, 2014 1:13 pm
I just shipped you a pair Rheicel!
Yours did have CX-Rays and White Industries hubs .... similar beasties though.
robbo
Postby robbo » Fri Feb 14, 2014 7:26 pm
Josh,
You built me some awesome wheels with WI hubs and archetype rims.
I'm fat and seem to hit a lot of pot hokes so you built them 2x at the front and 3x at the back.
Would these suffer the punishment if I pit them on my 2nd bike?
Rob
Sent from my GT-I9300 using Tapatalk 2
defy1
Postby defy1 » Fri Feb 14, 2014 7:54 pm
would take them if they were in the $400 ballpark..:/
mtbboy41
Postby mtbboy41 » Fri Feb 14, 2014 7:57 pm
Can you put a shimano 11 speed cluster on these wheels?
Velo13
Postby Velo13 » Sat Feb 15, 2014 11:30 am
robbo wrote:Josh,
Rob
Hi Rob,
At your weight, these are probably a bit light for that kind of punishment. The Archetype, HED C2 or Rouler has a bit more mass in the rim, so will be stiffer and more reliable.
I weigh 82kgs and found these to be just fine. I admit that I am a "finesse" rider and tend to ride "light" on my equipment, but I do ride on some of the worst roads in the country!
I'd say this build is good for a rider up to about 85kgs. Above that they should be okay, but will not be greatly stiff.
Velo13
Postby Velo13 » Sat Feb 15, 2014 11:32 am
defy1 wrote:would take them if they were in the $400 ballpark..:/
Thanks Defy, but I would like to hold out for a bit more. These are priced at cost at the moment.
Your interest is registered though, and I'll keep it in mind if that's okay with you?
Velo13
Postby Velo13 » Sat Feb 15, 2014 11:35 am
mtbboy41 wrote:Can you put a shimano 11 speed cluster on these wheels?
I will supply these with a new freehub that suits either:
1) 9/10/11s Campagnolo, or
2) 8/9/10s Shimano
If you want to run 11s Shimano on these, just use the Campag freehub and a Campag 11s cassette - spacing is the same, works perfectly.
Velo13
Postby Velo13 » Wed Feb 19, 2014 4:20 pm
Bump!
Velo13
Postby Velo13 » Thu Feb 20, 2014 8:24 pm
Sold, pending payment.
I have another couple of demos that need to go, so watch this space.
Velo13
Postby Velo13 » Wed Feb 26, 2014 8:56 pm
Yep, deposit taken. Thank you umpires. Thank you ball boys.
Velo13
Postby Velo13 » Wed Jun 11, 2014 9:18 am
SOLD
Users browsing this forum: Bing [Bot], Google [Bot]
