WTS: Supernova E3 Dynamo Front Light
Postby paul.ferris » Wed Oct 08, 2008 8:27 pm
As-new Supernova E3 Dynamo Front Light - $250
Only one week old - as new condition! Retails for $390, I'm offering my spare one for just $250. A great deal.
Comes with mounting instructions, fork mounting system (you need to have a hole in your fork to mount this light), and electric cables - everything you need to hook this light up!
The Supernova E3 is a dynamo powered front light - the brightest available in the world! It will run of any 6V hub or bottle dynamo (use your exisiting dynamo or buy a high quality Shimano dynohub from any bike store for $150). This means:
* No batteries - powered by the bike's own motion
* Light is rated to run for 10,000 hours, so no need to do anything with the light, ever!
This light is made in Germany, and is extremely high quality and extremely bright! Named the highlight of the year by the Swiss VELOMAGAZIN, the E3 has received many awards for its design and high quality.
To see how bright this light is in comparison to its competition check out the independent comparison at velociped.ch/docs/Dynamo-Scheinwerfervergleich_2008.pdf
This light is ideal for
* Communting - with its bright and wide beam, oncoming cars will see you and give you plenty of space
* Mountain biking - its wide beam acts well to illuminate whole path and any overhanging obstacles
* Long-distance cycling - ride night after night with no worry about batteries running out!
Features of the E3
• Up to 220 Lumen – We are always using the brightest LED available
• Reaches 90% brightness at 7-8 km/h (4-5 mph)
• With 3-min. stand light for front
• LED can be upgraded at Supernova at any time
• 100,000 hrs LED life - enough to cycle around the world 10 times
• smooth, harmonic illumination pattern
• Optimized cooling surface (8500 mm²) with cooling fins.
• Corrosion-resistant, anodized aluminium housing
• High-quality mounts
• O-Rings made from EPDM material resistant to UV radiation
• Compact and rugged push-button
• Designed to be upgradeable with the newest LED (although currently represents the latest technology) at a fair price
For more info and images visit supernova-lights . com
Contact me via PM, or paul.ferris [at] gmail [dot] com or 0420 354 366
Note: This post approved by a moderator :)
And Moderater adds - Please don't forget to add the right post title - WTS or WTB - it makes it much easier
paul.ferris
by BNA » Mon Oct 13, 2008 8:04 pm
Postby paul.ferris » Mon Oct 13, 2008 8:04 pm
bump - still avaliable!
paul.ferris
Users browsing this forum: a, geoff87, Typhoon Ken, Wakatuki
