fuji feather bottom bracket size?
Postby eugenesix » Thu Jun 24, 2010 8:57 pm
hi all, im new to all this but im about to buy a set of sugino mighty comp crankset, but im unsure if i will need to buy a new bottom bracket (103mm sugino messenger).
im hoping that the existing bracket will fit the new cranks? any help would be appreciated thanks.
eugenesix
by Forum Ads » Sat Jun 26, 2010 1:40 pm
Re: fuji feather bottom bracket size?
Postby darkhorse75 » Sat Jun 26, 2010 1:40 pm
I know that for Sugino 75's and Sugino Super mighty track cranks you need 109.5mm ISO taper bottom bracket. Not sure if your crnks will be the same though.
darkhorse75
Postby darkhorse75 » Tue Jun 29, 2010 12:20 am
Just had alook on the net and Sugino mighty comp does indeed use 103mm JIS bottom bracket, same as Sugino Messenger.
darkhorse75
