I can't remove my rear wheel!
Postby chrisjie » Sun Jul 11, 2010 5:21 pm
My first rear wheel flat. I tried to remove the rear wheel using an allen key that fits perfectly into the nut. But it wont budge at all. Anti-clockwise I've put my whole body weight behind it. Nothing. Both sides wont budge a single millimetre. Am I doing something wrong? Or should I take it down to the bike shop and get them to use a tool?
One side
Other side
chrisjie
by Forum Ads » Sun Jul 11, 2010 5:39 pm
Re: I can't remove my rear wheel!
Postby chrisjie » Sun Jul 11, 2010 5:39 pm
ok i found a glove and really gave the side with the chain on another crack and it loosened. Still working on the other. :(
chrisjie
Postby Cinder » Sun Jul 11, 2010 5:55 pm
Got something you can use to increase the leverage, eg a tube you can put over the key to make the handle longer (be careful how much you increase it tho)...
Cinder
Postby chrisjie » Sun Jul 11, 2010 10:48 pm
All good. I changed the angle I was going from, I leant over from the other side of the bike. Got the spare tire on only to find out the metal spike was too short. need a dif size :)
chrisjie
Postby rustychisel » Mon Jul 12, 2010 10:34 am
chrisjie wrote: Got the spare tire on only to find out the metal spike was too short. need a dif size :)
errrr, valve housing? :idea:
rustychisel
Postby rein08 » Tue Jul 13, 2010 9:10 pm
Try putting oil to loosen them.
Ive done that.
It works. :)
rein08
Users browsing this forum: sil3nt
