Cold setting frames
• Page 1 of 1
Cold setting framesI had a fruitless search in this forum, but was wondering what a tried and true methos of cold setting to 125mm is? Other than the Sheldon method, that is...
Projectus Distractus Maxima.
Re: Cold setting frames
126mm frame on 130mm axle == just stretch it over, don't bend it permanently. It's not that hard. So we get the leaders we deserve and we elect, we get the companies and the products that we ask for, right? And we have to ask for different things. – Paul Gilding
Re: Cold setting framesWhy 125mm? Track/fixie hubs (should) = 120mm.
If you're spacing a frame inwards to 120mm, you might have a slight issue with the dropouts not being straight in relation to one another. Not a problem on a road hub with a QR or the like, but on fixed hubs it can mean slippage. Good serrated nuts can fix that. I spaced my steel frame out to 130mm with a chair and a length of wall stud. It wasnt quite centred though, so it runs more like 63mm one side and 67mm t'other. Jim MY RIDES: My Velospace Profile
Re: Cold setting framesany good old school LBS should have tools for aligning dropouts, and making sure it is square.....mmmmm3380.
I'm not quite sure what you're expecting hear... There is no magic to this. Sure, there are special tools which the professionals use to check alignment, etc... but these are all easily emulated as per the info on Sheldon's site. I've respaced a couple of frames so far. You have to be careful with harder steels like cr-mo or mn-mo, because they require a bit more force... and it is very easy to apply too much. They are 'springier' and it can be difficult to tell how much force is enough. Once you get it to the point you're happy with it, using the string method described on Sheldon's website, look along the seat stays and make sure that they both look fairly similar in the way they bend. If you find that one of the seat stays is visibly kinked and a true wheel doesn't sit straight, you can use Dave Moulton's method for straightening stays. Just make sure that you have a spacer of some sort between the dropouts. The best advice I can give is to take your time, and maintain a cool head. This is not a difficult thing to do. volutamus scandemus
Re: Cold setting frames3/8" threaded rod (9.5mm) with nuts and washers. I recall reading that you have to use the threaded rod to spread the rear to approx 15 to 20mm more than the final width that you want the frame to be cold-set. However, I cannot find it right now.
Martin Christopher Hartley
http://raleightwenty.webs.com - the top web resource for the Raleigh Twenty http://madmartysblog.blogspot.com - my cycling adventures
• Page 1 of 1
Return to Fixed Gear/ Single Speed Who is onlineUsers browsing this forum: No registered users |
