Track sprocket won't fit my chain.
• Page 1 of 1
Track sprocket won't fit my chain.I'm lost. I've read all chains have a 1/2" pitch. But my track sprockets won't fit. The distance between the teeth is slightly greater on my rear cogs, so the chain skips. What am I missing?
If this is covered elsewhere, just point.
Re: Track sprocket won't fit my chain.Are you using 3/32" chain on a 1/8" sprocket?
volutamus scandemus
Re: Track sprocket won't fit my chain.New sprockets, new chain. One 1/8" sprocket. One 3/32". Chain is 3/32" and won't fit either. Pitch between the teeth seems wrong. I'm doing something dumb, just not sure what.
You can't fit a 3/32" chain on a 1/8" sprocket, the sprocket will be too wide for the chain. - Dave
There's your problem. volutamus scandemus
Re: Track sprocket won't fit my chain.Don't some older chains and sprockets have a wider spacing as in gap in between teeth on the sprocket?
Or am I just mony balony? ![]()
Yes, some older bikes had 1" pitch, modern stuff is 1/2" pitch. You won't find a bike shop stocking 1" pitch stuff this side of... I dunno, the 50s or something. In any event, a 1/2" chain will still run on a 1" pitch sprocket. But that's not the issue for the OP. Grumps You are very tedious, and grumpy. Stay at home and give advice from your armchair.
- Stonedpirate, June 2010
Re: Track sprocket won't fit my chain.not using some old dura-ace 10 stuff are you?
google shimano 10 pitch if you are internet experts: ruining bikes since '10 | http://www.redbubble.com/people/munga
Re: Track sprocket won't fit my chain.It's not the width, it's the pitch. I was comparing and couldn't understand why the pitch was the same.
Thanks for your comments. I'll do some more searching.
What model chain is it? While you're at it, what model sprockets? Grumps You are very tedious, and grumpy. Stay at home and give advice from your armchair.
Re: Track sprocket won't fit my chain.hey, have this been resolved? which parts did you have at the end of the day? =)
• Page 1 of 1
Return to Fixed Gear/ Single Speed Who is onlineUsers browsing this forum: No registered users |
