126mm Fixie Conversion
Postby MountGower » Sat Oct 27, 2007 6:38 pm
Error. This post can no longer be displayed.
- europa
Postby europa » Sat Oct 27, 2007 6:45 pm
The spacing won't cause you any grief. Track spacing is 120 so you'll need some spacers in there, but it's not an issue.
The main thing to look for is horizontal dropouts so you can adjust the chain tension ... otherwise you wind up with discussions like the one in my Jamis Fixie thread.
- mikesbytes
Postby mikesbytes » Sat Oct 27, 2007 7:32 pm
Its steel ? Get the rear forks adjusted to 120.
- tallywhacker
Postby tallywhacker » Sat Oct 27, 2007 9:12 pm
you can cold set 126 down to 120. Sheldon likes to use a bit of wood to bend each stay in slightly another way is a long bolt thru the dropouts and gradually tighten till you get the correct spacing.
If you think about it regular dropouts on a road fixed are far more sensible than trackends. Easier to change a flat
Postby thomas_cho » Sun Oct 28, 2007 7:51 am
firstly $5 bike .. how good is that!
Now ... I have a 126mm spaced frame as well. I am thinking of getting a 130mm spaced Surly fixed/free hub, and removing 4mm worth of spacers. Or is it better to go 120mm and space it up?
Any comments re: Surly hubs?
- europa
Postby europa » Sun Oct 28, 2007 9:11 am
Surly hubs are expensive - go to your lbs and buy a novatech ... or whatever it is they're selling.
Don't worry about the spacing, just fit spacers to do the job in whatever frame you're running. It'd be different if you were doing a super schmick job (and you don't start them with a $5 frame ) but even then, it's not necessary.
- europa
Postby europa » Sun Oct 28, 2007 2:24 pm
Nah, you bung an extra washer on either side and do it up tight You're only looking for 3mm on either side.MountGower wrote:Thanks everyone.
Will a 6mm spacer mean the wheel is 3mm off centre?
On one of my track wheel sets, the locking nuts for the cones are normal thickness nuts, not the more usual thin ones
Postby thomas_cho » Sun Oct 28, 2007 3:58 pm
okay ... so novatech or formula hubs are sound enough from what I am reading and no need to spend on the surly hub, and get a 120mm spaced track hub, and then space it to match your rear dropouts?
Are there hub dimensions of the novatech or formula hubs online? My intention is to build the wheel myself using a open pro rim, and I need to work out the spoke lengths.
mtgower sorry to hijack the thread again ...
Postby vee_dub » Sun Oct 28, 2007 7:36 pm
if u using open pro get urself a better hub.thomas_cho wrote:okay ... so novatech or formula hubs are sound enough from what I am reading and no need to spend on the surly hub, and get a 120mm spaced track hub, and then space it to match your rear dropouts?
- MichaelB
Postby vee_dub » Mon Oct 29, 2007 10:45 am
Goooooo MichaelB...look forward to see another fixed gear.MichaelB wrote:Just bought myself a Novatech hub from the LBS on Saturday.
$65 incl GST (with two lockrings).
Looks purdy.
Nice score there Mount for $5. So, how do u know it is a Repco frame given the stickers and paint condition ?
- MichaelB
Postby MichaelB » Mon Oct 29, 2007 1:08 pm
Setting up some sort of a breeding program ?MountGower wrote:Michael
The serial number is clear. All I need now is somewhere I can go to confirm these numbers as I have another Repco and am looking at buying two more.
My brother in law has a Repco Olympic 12 (in blue/white) witha small/med frame that can go to a good home for the right price I think
Postby vee_dub » Mon Oct 29, 2007 3:35 pm
I have a repco frame repainted with british racing green with black fork for sale. 54cm...if anyone from sydney let me know...i will let it go for right price too.MichaelB wrote:Setting up some sort of a breeding program ?MountGower wrote:Michael
Return to “Fixed Gear/ Single Speed”
