can the chainline be a problem when building a fixie
Postby malaka » Mon Jan 03, 2011 1:21 am
I am thinking of building a single speed bike myself (with all the good new frames/parts available on the internet)
I have pulled apart many bikes over 20 years and have a good mechanical aptitude
but i am not sure about the chainline and how you line up a front spocket with rear cog
are most popular sprockets/cranks similar offsets?
or will i just have to trial and error with spacers on the rear axle?
thanks
malaka
by BNA » Mon Jan 03, 2011 1:47 am
Re: can the chainline be a problem when building a fixie
Postby darkhorse75 » Mon Jan 03, 2011 1:47 am
Most track hubs will give a chainline of about 42mm give or take a mm, your job is to come up with a bottom bracket length and crank combo that comes as close to this as possible. easy.
darkhorse75
Postby drubie » Mon Jan 03, 2011 5:19 pm
darkhorse75 wrote:Most track hubs will give a chainline of about 42mm give or take a mm, your job is to come up with a bottom bracket length and crank combo that comes as close to this as possible. easy.
Where's the fun in that? I thought it was supposed to be trial and error, a bag full of mis matched parts you found / ebayed / scored from the tip etc., some spare time, some spacers, a spoke tool and a set of cone spanners. It's impossible to take more than 15 minutes to get a working chain line even if you're using re-purposed road parts, as long as you know how to true a wheel and can adjust a bearing cone.
Trial and error FTW!
drubie
Postby HappyHumber » Mon Jan 03, 2011 5:37 pm
drubie wrote:Trial and error FTW!
+1
But you do take all the magic out of it, Droobs.... ;)
Kym
HappyHumber
Postby aaron » Tue Jan 04, 2011 12:26 pm
Yes it can
aaron
