Fixie commuter
• Page 2 of 2 • 1, 2
Re: Fixie commuterThe freewheel should hold the same chainline if you are talking about a flip/flop hub. I would be looking at the spacers on the rear axel if you got two different chainlines on the one hub.
Merida Ride Lite 93 2012
Mojo Urban fixed 1984 Christoff R.I.P
Re: Fixie commuter
That's you, not the bike. You climb harder on a fixie because you can't change into an easier gear and spin.
Re: Fixie commuter
You're right. I'll have to check when I get it back, then work out what I can do if it is a problem. Humans are not so much rational beings, as rationalizing ones.
![]() 2010 Giant Yukon with slicks and stuff. 2008 Salsa Casseroll 2010 SE Lager
Re: Fixie commuter
Oh I know. I have to climb faster because it's too hard to go slow. I'm trying to transfer that to the geared bike, but gears tempt you lots... Humans are not so much rational beings, as rationalizing ones.
Re: Fixie commuterAre you still locking it up outside? If so, what method do you use to lock it up?
I'm also commuter who goes through earlwood/marrickville (but currently running SS, contemplating switching to fixed), there are definitely some killer hills.
Re: Fixie commuter
Big U lock and a cable. That said, I have my last commute to the airport next week, circumstances have changed a little. Then the fixie comes up to Orange, where I have some killer hills and may have to go back to SS to get down them in one piece. Humans are not so much rational beings, as rationalizing ones.
Return to Fixed Gear/ Single Speed Who is onlineUsers browsing this forum: No registered users |
