My first SS, a 29er MTB
• Page 1 of 1
My first SS, a 29er MTBOk guys, after nearly a year and not too much trouble with my specialised hardrock 29er I've decided I'm going to drop the cassette off the rear end and go single speed. Trying to do it on the cheap and it is my main bike so it gets used to ride to work (only 5kms return), drag the daughter around in her trailer on weekends(anywhere from 10 to 20kms) and alittle bush work when i get time. It's pritty hilly here but can manage with 42:16 when by myself on the road but wanting something lower for the bush work and with the trailer on. Have heard of people running 2 crank rings and 2 sprokets down the back and changing the chain from one set to the other. Anyone out the done this and what parts do you guys use or recomend? Dont really want to change the rear wheel if possible as I would like to keep the disc brake. So, what do you all think? Any idea's or suggestions would be helpful.
if in doubt, pull it out.
Re: My first SS, a 29er MTB
What's the point??? harden up and go true S/S(ie one gear) or just keep the gears.
Fair enough, point taken. if in doubt, pull it out.
Re: My first SS, a 29er MTBI see no problem in having 2 different gearing setups for two different applications, it makes perfect sense. its why I have two SS bikes, one for MTBing, one for commuting. they have different gearing arrangements and different setups because its sensible to do so. if I only had one bike I would have two gearing arrangements on it to maintain the SS but I would use a Paul "Melvin" with a double chain ring up front and single sprocket at the back:
http://www.paulcomp.com/melvin.html ![]() Life is not about waiting for the rain to pass.....it's about learning to dance (or ride) in the rain.
- anonymous
Re: My first SS, a 29er MTBIn terms of gearing i would suggest the same approach i used before building my first SS road bike, sticking my geared bike in one gear and doing the whole commute on it. If that gear wasn't a good compromise i'd just click it one either way until i found a good gear, then built the SS with that.
Re: My first SS, a 29er MTBAnd i had no idea Paul's was still around, i thought they died out in the early 90s.
But reaaly whats the point of calling it S/S when it's clearly not? It's bi speed, and very agricultural at that if you have to manually change stuff. The whole point of Single speeding is uncluttered simplicity, not chain tensioners and multiple sprockets and chain rings. Horizontal drop outs, 1 rear sprocket, and one chain ring is the essence of single speed, any thing more complex and you may as well stick with gears. if you take one step further into S/s simplicity you will be fixed, and that will sort the men from the boys.
Re: My first SS, a 29er MTBThere's a bloke around my local area who started off with a single speed and then put on Truvativ Hammerschmidt cranks to make the hills a little easier. It was a 'readers ride' in one of the mountain biking mags a couple of years ago, full carbon 4 spoke Xentis wheels and all. Personally i can't stand SS off road, there's just too much difference in the terrain for it to be practical (although i vividly remember being passed at a horrendously muddy race last year by a bloke on a SS who was flying past everyone else with their clogged gears).
Re: My first SS, a 29er MTBThanks for your input guys, think I'll order a 16t kit for the rear, move my 42t ring into the middle and leave my nanny gear there just in case, will proberly just reduce the chain length so it's close on the big ring but leave the derailleur on so I can move the chain down to the nanny and still have tension. Cant hurt to try I guess.
no different to original racing bikes with flip flop hubs, I suppose they were not real SS either. as for the dual pulley tensioner, yeah sure unecessary for a HT frame and I do like the clean unadulterated look of SS, but a tensioner is very useful when you have an SS duallie. had two of those with Melvins. think HT MTB SSing is fun, try an MTB duallie SS with a well setup rear shock. makes 24hr solo racing very comfortable and freakishly fun. glad I'm man enough to be a fixie rider for commuting. at the end of the day the OP asked for a solution to a problem, instead of telling him to your 42t chain ring will likely not run on the middle of the crank and will foul the frames chain stay. Life is not about waiting for the rain to pass.....it's about learning to dance (or ride) in the rain.
- anonymous
There, cut out all that superfluous drivel and edited it down to the crux of your post!
Re: My first SS, a 29er MTBThanks for everyones ideas, opinions etc, if i was in a position to have 10 different bikes I would but at the moment I'm not so I have to get by with just one. To get around my local single track on street gearing I would have to have legs like Mal Meninga which I havent so hence a 2 speed it is. Thanks oxford for your tips, and you were right, the 42 wont fit where the middle sproket used to. Am going to get a 12t for the rear and keep the 32 on the front for normal use and flick the chain down to the 22 when I cant go any further, seems the most realistic choice for me at the moment. Maybe I'm greedy and want to much from 1 bike but I'm really liking the hardtail mtb and have finally got comfortable on it. I am thanfully for all the idea's that has been put across, although sometimes HTFU doesnt help much. Cheers.
Good point , in light of that, you may find this interesting if you havn't already seen it http://sheldonbrown.org/hercules.html Sheldon is always worth a search on any cycling issue.
Re: My first SS, a 29er MTBThanks BRLVR.v2, what I was thinking but not quite so many options, just one gear for the road, and drop down to the little ring for the bush or up the big climb home with the trailer and daughter on board. Was intersted in old mates split gear crank and belt setup but I'm trying to do this on a minimum budget.
Re: My first SS, a 29er MTBRighto then, its been done for near a week now and its great. Not realy single speed but almost. running a 32 and 22 front and got a 17 on the back. only use the small crank in the bush, change it by hand. Cant believe I waited so long to go with one cog at the back. Its funny how every 2nd bloke comes into work and ask's where is the rest of the gears, when you tell em they still dont get it, this is usually when I say that's why you have gears. Think I will be putting a 20T cog on the back soon and have more fun in the scrub. Its strange but once you go single you dont seam to care about speed as much but more about the ride and the pedalling, a lot more enjoyable I reckon. Thanks everyone for the advice.
Re: My first SS, a 29er MTBCool, well done. Got any pics of the setup to share?
Another convert. Might be ghetto, but who cares? ![]() Life is not about waiting for the rain to pass.....it's about learning to dance (or ride) in the rain.
- anonymous
Re: My first SS, a 29er MTBWould post some photos but I cant work out how to paste them.
Re: My first SS, a 29er MTB...whatever the road rules, self-preservation is the absolute priority for a cyclist when mixing it with motorised traffic.
• Page 1 of 1
Return to Fixed Gear/ Single Speed Who is onlineUsers browsing this forum: No registered users |
