Giant triple to single speed
MDL
Postby MDL » Thu Oct 27, 2011 2:24 pm
Hey guys,
Just brought a mates 3 year old gaint for something to learn about bikes on. Was thinking about making it a single speed but it has a triple on the front and the largest is a 52 ring. Would I have to replace this or could I get something to fit on the back? I was just going to use a conversion kit on the back but I'm not sure weather this would work.
I'll post photos later and see what u guys think.
MDL
Re: Giant triple to single speed
Postby Mulger bill » Thu Oct 27, 2011 10:31 pm
Can't see it being a huge problem unless you're talking swaged rings. Add the kit for the rear hub and put your chainring of choice onto the middle position, you will need to get singlespeed specific chainring bolts or a bunch of washers to pack out the existing units.
MDL
Postby MDL » Fri Oct 28, 2011 1:52 am
Thinking about somehting like this -
http://www.cyclingexpress.com/cycle/dmr ... r-red.aspx
But would it would for the right ratio? I live in a nice hilly place.
Matthew
Postby Mulger bill » Sat Oct 29, 2011 8:51 pm
That'd do the trick methinks.
As to calculating ratios for your situation, try THIS, courtesy of Sheldon Brown. It'll give you an idea of the best chainring size for your situation.
MDL
Postby MDL » Sat Oct 29, 2011 9:08 pm
Ta. Have started pull it apart. But since I couldn't get the hoods off I have a long way.
MDL.
Postby Mulger bill » Sat Oct 29, 2011 9:23 pm
Hoods? As in brake levers? What type?
MDL
Postby MDL » Wed Nov 02, 2011 4:36 pm
Was going to start pulling it apart. Looked at the Bar tape and saw that the hood covers need to come off first? tips?
MDL
MDL
Postby MDL » Wed Nov 02, 2011 4:39 pm
lol i should just use youtube more often.
MDL
MDL
Postby MDL » Wed Nov 09, 2011 1:54 am
Managered to get the bar tape off. The Brake leaver are off. All the cables are gone. I suppose i now have to learn how to brake a chain and start around that area.
MDL
Postby Mulger bill » Wed Nov 09, 2011 6:46 pm
That's a youtube again...
MDL
Postby MDL » Wed Nov 09, 2011 6:58 pm
Mulger bill wrote:That's a youtube again...
Lol yep.
MDL
