best chain alignment
newbikeorupgrade
Postby newbikeorupgrade » Tue Mar 20, 2012 1:07 pm
Having recently got a single speed I thought the chain would be aligned perfectly...
But on the rear its on one side and on the front its on the other side is this normal?
Should it not be perfectly straight?
slidetaker
Re: best chain alignment
Postby slidetaker » Tue Mar 20, 2012 1:24 pm
I fail to understand your message.
However, I think something like this is close enought
Moe
Postby Moe » Wed Mar 21, 2012 2:44 pm
If you've converted a roadie, there's a few ways around this, invest in a new bottom bracket with a shorter axle (10-11mm should do it) and/or invest in a new crank set, preferably with the option of placing the chainring either side of the crank.
If you're using a converted road wheelset, you should have spacers with the cog on the cassette, then it's as easy as moving them around to get the perfect alignment.
Hope this helps.
Users browsing this forum: Exabot [Bot]
