Brake Kit - Front
Brake Kit - Front
Postby Sydguy » Thu Jul 05, 2012 9:22 pm
Hi Team
Looking for a front brake for Azzurri Pista, stock track bars.
Few places do rear brake kits, because most bikes come with front brake.
Anyone know a place doing the whole front brake? Dual pivot, lever and cables in a pack?
JM
Sydguy
by BNA » Fri Jul 06, 2012 9:05 am
Re: Brake Kit - Front
Postby lucky7 » Fri Jul 06, 2012 9:05 am
Quite a few on ebay - was looking for similar the other week before deciding to go with a front and rear set.
lucky7
Postby Sydguy » Fri Jul 06, 2012 1:39 pm
Seems the lever, cable and caliper are sold separtely.
If anyone knows where I can grab the whole lot online or in a store please post.
JM
Sydguy
Postby HLC » Fri Jul 06, 2012 1:59 pm
Sydguy wrote:Seems the lever, cable and caliper are sold separtely.
JM
And that's pretty much how it is anywhere.
A bike shop might be able to 'make up' a package for you but grabbing all 3 separate items off the shelf, and if you are lucky, giving you a pathetic discount... but it will still be dearer than buying online no doubt.
HLC
Postby lucky7 » Fri Jul 06, 2012 2:05 pm
http://www.ebay.com.au/itm/DIA-COMPE-BR ... 48424a039f
http://www.ebay.com.au/itm/Track-Bike-B ... 519b6ba3dd
seems the above 2 mount onto the forks. I swear I saw some road brakes in a front only setup with lever & cable
I bit the bullet and went a SRAM or Tektro set for around the $40 mark...decided 2 brakes is probably safer anyway
lucky7
Postby Sydguy » Fri Jul 06, 2012 9:44 pm
Cheers - I had thought $50 for whole front brake would be enough, looks like a bit more!
JM
Sydguy
Postby cray- » Mon Jul 09, 2012 2:02 am
Just read that the fork on your Azzuri is drilled for a brake so no need for those clamp on kits that Lucky7 posted. Surely you can get a lever, caliper & cable separately online for less than $50, just pick your fave online store & fill your cart, how hard can it be?
cray-
Popular Bike Shops
Torpedo 7 Cycling Express
“Bicycles BNA Twitter
“Bicycles BNA Facebook
“Google+ BNA Google+
“Bicycles BNA Newsletter
“Bicycles BNA on Strava
