Wheel Build
sil3nt
Wheel Build
Postby sil3nt » Thu Mar 28, 2013 6:01 pm
Hey guy's, I am planning to do my first ever wheel build and I am trying to figure out what spokes to use, I originally was going down the DT Swiss Comp spoke path but recently a friend of mine who has built a number of wheels suggested Sapim CX Ray spokes (aero).
The build is on a pair of DT Swiss RR585 32 Hole Rims and 32 Hole Large flange Miche Primato track hubs. I kind of like the look of having an aero style spoke which I have on both my Shimano C50 and Comsmic Elite road wheels but I am not overly fussed if I don't go that way.
Has anyone had experience with the CX Rays before ? Any pros or cons, someone mentioned that maybe doing a first wheel build on a aero spoke may also not be the best idea given they are a little more difficult to lace ?
Also I have had a quick look around online and the cheapest I can find them so far is around 2.95 per spoke (AT) Starbike.com and a very similar price from Jenson in the USA.
If anyone else has some other spoke suggestion they think I should consider please feel free to give your 2 cents ;)
Cheers in advance folks
Re: Wheel Build
Postby familyguy » Thu Mar 28, 2013 10:51 pm
Will you need to file your hubs for aero spokes?
Spirito might be your man for info here.
sil3nt
Re: Wheel Build
Postby sil3nt » Thu Mar 28, 2013 10:58 pm
familyguy wrote:Will you need to file your hubs for aero spokes?
The Sapim CX-rays don't need any special treatment or filing according to the manufacturer.
Re: Wheel Build
Postby familyguy » Fri Mar 29, 2013 9:18 am
Ah, I see now. They're a 2.3mm blade width, so should sneak in. Is this for track use, or street as well?
HLC
Re: Wheel Build
Postby HLC » Fri Mar 29, 2013 10:49 am
In my opinion aero spokes are easier to build with as you can see if the spoke is twisting or not.
Just like anything, take your time and enjoy the process.
I can't help you regarding place of purchase though.
sil3nt
Re: Wheel Build
Postby sil3nt » Fri Mar 29, 2013 7:56 pm
familyguy wrote:Ah, I see now. They're a 2.3mm blade width, so should sneak in. Is this for track use, or street as well?
Hey Jim this is for street use mainly commuting kms. But I did plan on doing some track training in the off season but I'll probably build another bike for that use.
sil3nt
Re: Wheel Build
Postby sil3nt » Fri Mar 29, 2013 7:59 pm
HLC wrote:In my opinion aero spokes are easier to build with as you can see if the spoke is twisting or not.
Thanks hlc someone else mentioned the same thing about twisting. I'm not going to build them in a rush.
