SS 29er MTB Build - Belt Drive!
Caelum
Postby Caelum » Sun Jul 21, 2013 7:05 pm
Hi folks :)
Has been a while since i've graced these forums, but i thought that this was worth making a comeback for. Nearly posted this in the MTB forum, but thought you folks would appreciate the single-speediness of it more than them ;)
The project:
To build a 29er rigid single speed belt driven mountain bike, from scratch (with the exclusion of the frame). The frame i'm getting fitted with a headset by the builder, but will otherwise be naked. I've purchased a fair amount of the parts required so far, with not too many bits to go - though the build itself won't begin until early-mid August, due to my current travel plans.
Anyway, you probably want to know what parts i'll be using...
Frame: Pipedream Skookum (Reynolds 853 chromo steel)
Fork: Ritchey WCS Carbon Mountain rigid 29"
'Bars: Easton EC70 Carbon
Headset: Hope Pick'n'Mix
Bottom Bracket/Chainset: Shimano XT M780 Triple (soon to be a single...)
Seatpost: Easton EC70 Carbon
Brakes: Avid Elixir 7 160mm
Hubs: White Industries MI6
Rims: Velocity Blunt SL 29er 32h
Spokes: DT Swiss Champion
Chainring: 42t Gates CDX
Sprocket: 20t Gates CDX
Pedals:Crank Brothers Eggbeater 3
Original budget was "Under $3000" (of which, the frame takes up ~$800), and i'm sure i'm going to go over by about $500... So far have spent $1900+, and have about $1500 to go i suggest. In reality, you could get away with an under $2000 bike based on this frame, if you drop the spec on them a bit, and take a bit of a hit as far as weight goes.
Based on the parts list above, the weight should come in under 10kilograms, hopefully somewhere closer to (or under) 9kg when in 'commuter mode' using 700x28mm tyres.
The combination of a 42t/20t chainset and sprocket should mean that i can use the same belt if i move it down to a 39t/24t system for off-road use, according to the gates belt drive calculator (on their website).
Whilst i've never 'built' (built-up is probably more accurate) my own bike before, i do 99% of my own bike maintenance, and have done ever since i was a youngin'. So none of the parts are all that of a worry for me. That said, i have fixed/replaced spokes on my wheels before, but i've never built them from scratch as i will be here. I have no doubt that Sheldon Brown (the saint that he is) will be of great assistance there :)
Anyway, that's about all for now.... Just can't wait to build it up! (and ofcourse, ride it)
Re: SS 29er MTB Build - Belt Drive!
Postby trailgumby » Sun Jul 21, 2013 7:35 pm
Nice! :)
Is teh belt drive the one with the guide rib on the pulleys and the matching slot down the middle of the belt? Very interested to hear how that goes.
Caelum
Postby Caelum » Sun Jul 21, 2013 8:11 pm
Yeah, that's the one. Seems to be a much better system than the original belt drive system. The older system was prone to throwing belts if the chainline wasn't perfect, got mud/rocks in it, etc..
Was talking to Stuart from Pipedream (the frame manufacturer) about it, and chainline/etc a few days ago - he even said that small variances in chainline were acceptable (though should still be avoided, obviously) as a result of the centre guide.
Will be sourcing the gates carbon drive equipment from The Flying Machine, here in perth. Nearly bought a frame from them (the UCX or U29), but decided against it due to lack of tyre clearance for wider tyres.
Caelum
Postby Caelum » Wed Aug 14, 2013 8:59 pm
Build is slowly progressing now... Have the fork on, but haven't cut the (carbon) steerer yet... have just finished up lacing the wheels, just need to true them up now and they're good to go... Have the BB on as well... So getting there! More pics will follow soon :)
HappyHumber
Postby HappyHumber » Thu Aug 15, 2013 8:55 am
More pics?
Sorry, I think I missed the first lot :P
- Kym
Caelum
Postby Caelum » Thu Aug 15, 2013 10:40 am
Haha, yeah, fair point ;)
Here we go...
gabrielle260
Postby gabrielle260 » Thu Aug 15, 2013 10:48 am
Thanks for including the hairy leg! Lol!
Looks like it will be a beauty when it's done!
gabrielle260
gabrielle260
HappyHumber
Postby HappyHumber » Thu Aug 15, 2013 11:55 am
We heard you the first time, Andrew :P
This 'quick reply' box can be a bit of a trap.
- Kym
Caelum
Postby Caelum » Thu Aug 15, 2013 9:14 pm
Sorry about that Andrew....
I'll shave for you next time ;)
gabrielle260
Postby gabrielle260 » Thu Aug 15, 2013 9:22 pm
Sorry guys - something went a bit wonky with Tapatalk... It wasn't funny enough to say 3 times!
Postby Mulger bill » Thu Aug 15, 2013 11:20 pm
My GLW loves those wheels! :)
Caelum, that workstand: Is the QR on the clamp factory or did you MacGyver it?
Shaun
Caelum
Postby Caelum » Fri Aug 16, 2013 10:22 am
A bit of both...
There was a QR on the bike stand... but it didn't clamp in place and stay there... So it's just tightened up with a wing-nut... Works alright through, for the price.
Postby Mulger bill » Fri Aug 16, 2013 11:18 pm
Thanks mate :)
RobertFrith
Postby RobertFrith » Fri Aug 16, 2013 11:28 pm
Unboxing heaven
Caelum
Postby Caelum » Sun Aug 18, 2013 3:26 pm
Just out of interest i put the wheels on the scales, to see what they weighed in at...
Front: 0.858kg
Rear: 1.006kg
Total: 1.864kg
To reiterate the components used:
Front Hub: White Industries MI6
Rear Hub: White Industries MI6 (shimano)
Rims: Velocity Blunt SL 32h
Spokes: DT Swiss double butted 2/1.8/2mm
Nipples: Brass 12mm
rheicel
Postby rheicel » Sun Aug 18, 2013 3:40 pm
Caelum wrote:Just out of interest i put the wheels on the scales, to see what they weighed in at...
Front: 0.858kg
Rear: 1.006kg
Total: 1.864kg
Rims: Velocity Blunt SL 36h
Nipples: Brass 12mm
Looks good. I am planning to have a similar wheelset to be built by XLR8. Now I know how much weight to expect.
Caelum
Postby Caelum » Sun Aug 18, 2013 4:14 pm
Ah, good... Information should be free :)
Also, just spotted a typo/error in my post... The rims/hubs are 32h, not 36h.
Postby trailgumby » Sun Aug 18, 2013 4:17 pm
36 hole rims? What do you weigh? :shock:
Caelum
Postby Caelum » Sun Aug 18, 2013 6:01 pm
Note the correction, above...
Weigh in at about 90kg :)
brasstinman
Postby brasstinman » Fri Aug 23, 2013 12:14 pm
Looks like a fun build. I had a 29er Spot belt drive, the original belt before the one you have. It was so good to ride but the alignment was an issue and the belt would slip on the teeth and make a horrible sound. Once it was nice and straight it was great to ride. Oh I also had to tighten the piss out of it to keep it from making a horrible noise when I climbed up steep hills and there was heaps of pressure being put on the belt.
Apart from that the belt was awesome, quiet and instant responsive. I'd definitely get another one.
Commuting and training on a Nishiki Navajo single speed
Building a GT Tachyon Crossover
Suntour with 105 groupset
Caelum
Postby Caelum » Thu Nov 07, 2013 10:06 am
I suppose i should post an update to this...
She's now on the road, however haven't got the belt on it yet - i should have some time in the coming weeks to get that sorted though, thankfully :)
Pictured below in road-bike boots.... But have got some 29er knobblies to throw on it as well, for the rough stuff. Rides like an absolute dream!
otisqld
Postby otisqld » Thu Jun 26, 2014 1:06 pm
Hi, any chance of a further update? I am considering one of these frames, and would love to hear how it's going. Mine would be a traditional build with derailleurs, but still keen for any info.
