Upgrading BB, cranks and brakes - SE Lager
acb
Postby acb » Wed Mar 19, 2014 7:05 pm
Hi guys. Quick qn.
Have one of these http://www.sebikes.com/archive/2010/700c-lager3
Would like to update / upgrade some components, namely BB, cranks and brakes.
BB, will this fit? http://www.wiggle.com.au/campagnolo-rec ... 5360326602
To go with these http://www.wiggle.com.au/campagnolo-rec ... -chainset/
Brakes : http://www.wiggle.com.au/tektro-r539-lo ... er-brakes/
Mucho thanks in advance.
HLC
Re: Upgrading BB, cranks and brakes - SE Lager
Postby HLC » Wed Mar 19, 2014 7:39 pm
Yes,
Yes,
and No.
Your bike uses standard reach brakes, and these tektro's being long reach will not fit. That being said, they wouldn't be a real upgrade to what you have.
A combination of Levers, cables, and high quality brakes (dual pivot) - Dura Ace, Sram Red, Campagnolo record will give you much better stopping power.
drubie
Postby drubie » Wed Mar 19, 2014 10:37 pm
Unless the bb is worn out...why replace it? Better to put the money toward a classic track frame and some tools I reckon.
Sent from my Nexus 7 using Tapatalk
acb
Postby acb » Thu Mar 20, 2014 5:51 pm
Thanks HLC - from my quick search I thought the brakes were long drop. Makes it easier anyway.
Drubie - BB is rooted. Classic frame would be ideal but too time poor (fml) to find one / build it / source parts etc etc
HappyHumber
Postby HappyHumber » Thu Mar 20, 2014 7:11 pm
Whoah! Someone want to spot me the spondoolies for a set of them Record Pistas whilst I am flat broke and they're on sale!?
(way too nice for an S.E. Lager, imo.... but hey it's your bike.. your money...)
- Kym
acb
Postby acb » Fri Mar 28, 2014 11:14 pm
drubie wrote:Unless the bb is worn out...why replace it? Better to put the money toward a classic track frame and some tools I reckon.
Thought it was worthwhile replying to say that I took this advice and am now looking at sourcing a frame and building up on that. Cheers
Postby singlespeedscott » Sun Apr 13, 2014 10:12 am
If you really going to put Campagnolo Pistas on the Lager, instead of the pista bottom bracket, get a 111mm Veloce or Centaur bottom bracket. The dimensions are identical to the Pista item and they are sealed. Dont buy a Record or Chorus road 111m BB though as they are asymetrical and are designed for triple cranksets.
Postby singlespeedscott » Sun Apr 13, 2014 10:13 am
HappyHumber wrote:Whoah! Someone want to spot me the spondoolies for a set of them Record Pistas whilst I am flat broke and they're on sale!?
I got mine from Ribble a while back for $225 AUD
KGB
Postby KGB » Wed Apr 16, 2014 12:06 pm
singlespeedscott wrote:If you really going to put Campagnolo Pistas on the Lager, instead of the pista bottom bracket, get a 111mm Veloce or Centaur bottom bracket. The dimensions are identical to the Pista item and they are sealed. Dont buy a Record or Chorus road 111m BB though as they are asymetrical and are designed for triple cranksets.
Good tip.
The standard Record/Chorus double BB's are 102mm.
acb
Postby acb » Mon Apr 21, 2014 10:22 am
Thanks for the assistance. I ended up scoring a real good deal on a Miche CS, BB, and chain.
Postby singlespeedscott » Mon Apr 21, 2014 1:02 pm
acb wrote:Thanks for the assistance. I ended up scoring a real good deal on a Miche CS, BB, and chain.
Make sure you crank up that Miche BB nice and snug as they have habit of loosening off.
