Masi Uno 2013
Cinelligazzetta
Masi Uno 2013
Postby Cinelligazzetta » Tue May 23, 2017 7:17 pm
Do anybody have a Masi Uno ?
Have you ever replaced cranks ?
Baalzamon
Re: Masi Uno 2013
Postby Baalzamon » Tue May 23, 2017 8:29 pm
Going off specs, it's a square taper bottom bracket so you want cranks to suit that, or change the BB to suit the new cranks.
Cinelligazzetta
Re: Masi Uno 2013
Postby Cinelligazzetta » Wed May 24, 2017 1:09 pm
Ordered Sram Omnuims with BB hope they fit :? :roll:
Re: Masi Uno 2013
Postby Mulger bill » Wed May 24, 2017 9:25 pm
Cinelligazzetta wrote:Ordered Sram Omnuims with BB hope they fit :? :roll:
With BB? Check spindle length against the old when it comes
Cinelligazzetta
Re: Masi Uno 2013
Postby Cinelligazzetta » Wed May 24, 2017 11:38 pm
Unfortunately its a completely different system. (sram omniums) External BB compared to the square taper one that it already has ! Im just gunna live in hope :roll:
Ant_S
Re: Masi Uno 2013
Postby Ant_S » Fri Jun 23, 2017 11:51 am
I reckon you should be fine. The only issue sometimes with them is frame clearance with the spider to the rear chain stay cause they're really chunky, is that what you're referring to? There is a chart you can find online with a template so you can check your frame.
I changed a Fuji Track Comp over to SRAM Omniums with SRAM BB. I couldn't find anything at all online so I just bought & hoped and they fit no dramas. They also fit on my new frame which is a Hillbrick SS. I did read something about people sometimes using spacers but then some problems where the BB doesn't seat right or something so best not to do that.
From what I read it is a buy, hope, if they hit your frame, sell & buy some nice square taper cranks instead like Sugino 75s
