N55 Spaceframe Vehicle New Style Recumbent Help!!!
Re: N55 Spaceframe Vehicle New Style Recumbent Help!!!
Postby John Lewis » Sat Jan 19, 2013 12:26 am
Thanks for the information Stephan.
I did see some of that on the German Forum after I posted but my German ability is pretty poor. I got th general idea though.
I have seen this motor and I understand it has been tried in a Mango Velomobile.
http://www.sunstaribike.com/products/e-bike-folding-bicycle/
What I would like to see is a setup like that which allows you still to use your 3 chain rings.
I'm surprised at your weight. It is very respectable.My LogoTrike weighs 20kg. That's with the rack, mudguards and a SRAM DualDrive.
The Delta Wolf trike I built is 25KG but it is built of square section mild steel 40mm x 1.6 mm and the rear axles are 19mm in heavy industrial bearings.
John
John Lewis
by Forum Ads » Sat Jan 19, 2013 1:50 am
Postby shs2_de » Sat Jan 19, 2013 1:50 am
Hi John,
I'm afraid that this motor won't fit between the frame construstion.
And the limitation for 33 teeth on the front chain ring is an issue.
For my 3- seater project I made the decision to split the chain, put a backwheel axis in between and use the normal back axis chainwheel as a switchable gearbox. If it works, you will have full flexibility and at least 21 gears in combination with a back-wheel motor
Think even in the ome seater, this method will work, if placed in front of the steering bridge.
I will optimize the chainwheels here, but that will be the principle.
Unfortunately we have plenty of snow here, and it make no sense to have my first ride those days.
http://www.velomobilforum.de/forum/attachment.php?attachmentid=39217&d=1357381455
stephan
shs2_de
Postby shs2_de » Mon Jan 21, 2013 3:04 am
Snow for Australia!
I like to share some impression in the snow with you. Have fun and watch my wheels in the air at 1:18 ;-)
Have fun
Stephan
shs2_de
Postby shs2_de » Thu Feb 14, 2013 4:15 am
The next one is ready:
shs2_de
Previous
Return to Recumbents
