Lowracer build from scooter
Postby Storm » Fri Feb 06, 2009 2:43 pm
I have started building a lowracer as it seems to be a common bent evolution, I need it to be simple, cheap and light.
I found some childrens scooters are good candidates for a main frame, already partly welded, one could bolt on a boom and end up with a bike with minimal tools.
The frame started as a cyclops (#mart?) 10" wheeled scooter, I extended the rear forks to accept 16" wheels, used a couple of aly tubes vice-flattened both ends for the seat stays, I shortened the steerer tube to accept a standard 16" front fork from huffy bmx, the seat is fron harry(uba tracker, thanks) when he changed to mesh but it could have been plywood or aly if I wanted to be frugal, I had this cheap TIG ovalised mtb from collections cut up for the boom and plans are to MIG tack it and take it to a pro TIG welder. The boom looks a little wierd with the extra extension tho I thought I might put a bottle mount or something on the end.
It weighs around 10Kg atm without the cranks and I it could be less with aly rims/hubs slicks, so let me know you think?
http://i306.photobucket.com/albums/nn271/Glenspictures/100_0280Small.jpg?t=1233895648
~~~~ ~ @_,~,- -_-’o,~~~ ~ @_,~,- -_-’o,
~~~ ~ (*)\____/(*)~~~ ~ (*)\____/(*)
Storm
by BNA » Fri Feb 06, 2009 4:42 pm
Postby toolonglegs » Fri Feb 06, 2009 4:42 pm
:lol: :lol: :lol: I like!.
Postby Mulger bill » Fri Feb 06, 2009 6:18 pm
Hey clever!
Definitely gotta see the results.
Shaun
microbent.
Postby Storm » Sun Feb 22, 2009 10:51 pm
http://i306.photobucket.com/albums/nn271/Glenspictures/DSC00047Small.jpg?t=1235306282
http://i306.photobucket.com/albums/nn271/Glenspictures/DSC00048Small.jpg?t=1235307203
A little progress made, the boom is now on and a BB cup has been welded on for a freewheel with pawls removed to act as an interdrive, I want to run short cranks on it and have heard some good reviews, has anyone here use them or have an opinion of them?
Storm
Postby bradwoodbr » Mon Feb 23, 2009 10:53 am
I think short cranks work just as well as 170s.
I used 145s on an M5 Shockproof with 20inch wheels and they worked really well. They save the knees from being overpowered.
Utilising a higher cadence and one lower gear was necessary for hill climbing. This is the way I compensated for the slightly smaller amount of leverage due to the shorter cranks. It was easy for me to spin the higher cadence and once I had good leg strength, hill climbing rate was good. There was no heel strike for me either. I have size 12 feet and had no probs with tight turns.
My current bike came with 170 cranks and I intend to change them to 150s.
Optima Baron Raptor
Low Racer - Recumbent
http://lowracerrider.blogspot.com/
bradwoodbr
Return to Recumbents
Users browsing this forum: The_Eggman
