Leg length and Lowracers
• Page 1 of 1
Leg length and LowracersI was told that you need at least a 32 inch inside seam measurement for a 406 front wheel lowracer.
Otherwise you have to go to smaller wheels. Not real keen on 16" wheels or a moving BB. So anybody out there with lowracer experience like to comment. I have only a 30 inch (762mm) inside seam. I think the main concern is to avod pedal overlap. At the moment I'm building a LWB lowracer. It's long 1829mm and heavy. Should be interesting even if impractical so I'm thinking of SWB and twisted chain FWD. John Lewis.
Re: Leg length and LowracersHi John,
I can't offer specific experience, but you can significantly reduce the severity of pedal overlap by fitting 145mm cranks. I've got them on my 'bent and love them - more power, higher cadence and less knee strain. It will also shorten the effective boom length by ~30mm. Cheers, Graeme Think outside the double triangle.
--------------------------------------- My web site: www.scenebyhird.com --------------------------------------- The Bicycle Transportation Alliance
Re: Leg length and LowracersWont be an issue on your bike John! Your wheel is out front of the cranks.
On the SWB style, it can be a problem. Shorter cranks can help, as can raisng the boom higher above the wheel. I'm not sure about inseam, but my xseam is 40" (5'6' tall), and my SWB has a 451 front wheel. Not that low though, mid racer format, seat height about 500mm. As far as i know, heel interfernce is only an issue on tight turns, and that can be reduced by using varying techniques. Cheers!
Rob --------------------------------------------------- Homebuilt trike, with electric assist 26"/20" trike, "Goanna" SWB recumbent, 700C/451 , "Kookaburra", homebuilt. FWD project (Cyclone). Optima Raptor
Thanks Graeme. I had thought of that as a possibillity. Where did you get them? I know Greenspeed will alter cranks at a price and you can do it yourself if you can find the taps. A commercial ready made source would be nice though. I need to do some scale drawings or some sort of mockup to see what's possible in a bike. John Lewis
Hi Rob, Hope the foot is coming good. Yes, no trouble on LWB but I'm looking at a short. I don't have a problem on my SWB Bentech so I can't see the problem on a low racer. Heel interference is no trouble. I live with that on the 'tech. Only took a ride or two to get used to. Just that I've been told that on a lowracer with a short inseam/ Xseam you get hard pedal interference and that's a no no. Seems to me that putting the BB higher would help but there might be a comfort issue. Some people don't like the BB higher than the seat. John Lewis
Re: Leg length and LowracersG"day John,
I got a set of Forza cranks from Power on Cycling in the US, for US$35. The quote on postage to Australia was US$27 for one set. I ended up buying a set of 145mm and a set of 155mm, just in case the 145mm were too short (they aren't) and the postage came to US$35 for the package. They are standard square taper road triple cranks - I simply swapped my chainrings across from the old crank set. Cheers, Graeme Think outside the double triangle.
Re: Leg length and LowracersThanks Graeme.
Might look at gettin some soon. John Lewis
Re: Leg length and LowracersTri Sled also have short cranks, but I notice only in the 110/74 BCD format.
http://www.trisled.com.au/shop/shopdisp ... cat=Cranks . As for bb height above seat level, I have about 6" which seems ok. There are other bikes that have even more, maybe 10" or so? Cheers!
I'm about a 750 inside seam. I have a SWB lowracer (homebuilt) with the following specs Wheelbase 1240 mm Front wheel 20 inch (406) Rear wheel 26 inch (559) Cranks Bontrager (Truvativ) 165mm Seat height 32cm BB height 56cm (BB height above seat base 24cm) Seat angle 25 deg approx Chainline - beside front fork. see: http://www.aerialpursuits.com/misc/talon.htm Heel strike is generally only a problem when turning sharp and forgetting NOT to pedal. Because of the chain line, the radious of turns under power are severely limited and so heel strike does not occur. I would very much like to be a few inches taller or not have such stubby legs. John R.
Re: Leg length and LowracersThanks John. That is encouraging news. We'll see how I go. I'll build it in steel though.
I'd like to give the carbon a shot but would need to study a bit first. I think for a first attempt steel will be the go. be interesting to compare the lwb and swb versions whenI'm done. The short legs is a pain. I sat on Kalgrm's highracer on its 700 wheels the other week to see how I'd fare. It was doable but would not be too satisfactory for commuting start stop as I really had to stretch to reach the ground. I think I'd be right with 559 wheels though. John Lewis
Re: Leg length and LowracersIt's not the soft interface of a heel strike you have to worry about.
It's hard interface of a crank arm that will bring you undone. The NoCom BatMoBent has crank overlap and it works OK so long as you're not trying to do slaloms and as John says forget about pedalling in tight corners. ![]()
Another place for shorter cranks is Greenspeed. They don't advertise it on their web but if you call Mick he will give you further details. He devoutly swears by shorter cranks for recumbents. He re-machined mine for about $30 and are 150mm. He likes 135mm on his trikes. I think they have some Carmina square taper short cranks in stock all the time. william.
Re: Leg length and LowracersI used 150mm cranks on my M5 Shockproof (medium lowracer) and with size 10 feet there was a little bit of heel interference when a heel would scrape the mudguar. But that was my warning sign and never got into any trouble.
I know have 170mm cranks on my Optimat Baron Raptor. I have also kept my size 10 feet Both bikes have 406 rims on the front. I think heel strike is only a minor issue and would recommend designing the bike for its major purpose. eg fast, relaxed, comfortable cycling and not put any importance on heel strike. Many Optima Baron riders actually drop the chain, which causes greater steering compromises in slow corners than heel strike. These guys also state that steering with a dropped chain is only a minor problem when doing slow tight turns. I guess a bike with a bit of challenge for the riders built into it is a better bike than one that is just too easy to ride???? I hope these observations help.
Re: Leg length and LowracersGood points Brad - under normal usage, heel strike is a rare thing and should not unduly influence the design of the bike.
Re: Leg length and LowracersThanks for all the information guys.
I am not cocerned with heel strike. I have that on my current SWB and can live with it. I simply don't notice it anymore but it tipped me off a couple of times at first. What I am concerned with is the hard interference from pedals and cranks. Probably ok most of the time or in a race situation but it doesn't make for relaxed riding. Peters Nocom is a great racing machine and a thing of beauty but I don't think I'd want to ride it on the cycle path or street. Thanks for the heads up on Greenspeed william John Lewis
Re: Leg length and LowracersTri-sled have short cranks for $50 in their on-line store.
Thanks Peter. I check them out. I need some for a mate wth knee troubles to try too. John Lewis
• Page 1 of 1
Who is onlineUsers browsing this forum: Joeblake |
