Damm It
Rowley Runner
Damm It
Postby Rowley Runner » Tue Jul 17, 2012 12:54 am
Doctors advice "No exercise for at least two weeks" Reason prepatellar bursitis :( (AKA housemaids knee) why did i get it? To many consecutive days at the driving range trying to improve my swing :shock: I think the moral of this story is clear to all :roll:
RR
Bents for La Tour
Baalzamon
Re: Damm It
Postby Baalzamon » Tue Jul 17, 2012 9:15 am
don't play golf ;)
Baalzamon
Re: Damm It
Postby Baalzamon » Tue Jul 17, 2012 9:18 am
And get better via resting as well.
And I'm going damn it as well.
Since putting my fairing on the trike it won't go thru the door. Reason trike is too wide for the doors and I used to turn it on it's side.
Solution :shock:
Phil
Re: Damm It
Postby Phil » Tue Jul 17, 2012 3:24 pm
Maybe you need a Vortex ;-)
Baalzamon
Re: Damm It
Postby Baalzamon » Tue Jul 17, 2012 3:40 pm
Phil wrote:Maybe you need a Vortex ;-)
I think you should check your work email about that :)
bradwoodbr
Re: Damm It
Postby bradwoodbr » Wed Jul 18, 2012 12:47 am
Baalzamon wrote:And get better via resting as well.
Solution :shock:
Have you tried doing it rear wheel first, on its side to angle it through the doorway?
Optima Baron Raptor
Low Racer - Recumbent
http://lowracerrider.blogspot.com/
Rotovelo velomobile
Baalzamon
Re: Damm It
Postby Baalzamon » Wed Jul 18, 2012 9:37 am
Solution :shock:
Yep tried that, that was how I was doing it first, rear wheel and then tip on side. Now that not possible with the fairing on as it makes the height too wide on it's side.
Gotta keep those double doors clear of pallets!!!!
just4tehhalibut
Re: Damm It - Obstructionist Fairings
Postby just4tehhalibut » Wed Jul 18, 2012 3:59 pm
What is the mount used with your fairing?
I was thinking that if the trike with fairing was just a tad over the doorway width then maybe if the mount had a pivot or quick-release on the post that sits in front of the seat you could drop it down. The fairing that you have had options for mounts, if you got the fixed mount this might still be modified, but only do so if it'll fit anyway.
Another option might be plonking the trike onto a furniture trolley or engine hoist, rolling it into the house that way and storing on that trolley standing up or at an angle. Giles Puckett did something like this years back when making his own full trike fairing.
Nobody
Re: Damm It
Postby Nobody » Wed Jul 18, 2012 4:55 pm
Solution :shock:
Rebuild the door and jam to make them bigger? Oh, you mean an easier solution... maybe build a shed for it with a ground anchor to chain it to? Sell it and ride your DF? Make a QR for the fairing? Move house?
Baalzamon
Re: Damm It
Postby Baalzamon » Wed Jul 18, 2012 5:18 pm
It's the terracycle gx fairing with stock with the One Point Mount Kit.
Rebuild door hmmm I've got a sledgehammer :twisted: Metal frame with glass surrounds
Sell my trike :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock:
I think you get the picture.
Ride my DF :cry: :cry: :cry: :cry: :cry: :cry: :cry:
Got a shoulder injury that prevents it
The One Point Mount Kit I have an issue with it. The clamp provided gave no tension and wouldn't clamp to the post. I got a hose clamp to fix it temporarily
John Lewis
Re: Damm It
Postby John Lewis » Wed Jul 18, 2012 5:27 pm
Get in touch with the guy at Terracycle.
They probably have an answer. I think he did ask you to contact him re the original problem when you mentioned it on BROL. Check back on that thread.
If all else fails send it down here and I'll put it on my trike. :D
It certainly looks neat. Did you get a chance to see if it gave more speed? I reckon that and a tailbox ought to give a few kmh.
John
Joeblake
Re: Damm It
Postby Joeblake » Wed Jul 18, 2012 8:06 pm
Solution :shock:
Are you renting or buying?
It could possibly be time to think about storing your Precioussss in a shed or something like Poiter's.
I had a slightly similar problem (just the trike without the fairing), so I solved it (albeit rather expensively) by getting an enclosed patio on the back of the house. There were other reasons for the patio as well, but it's certainly made life a lot easier to store two trikes, a mountain bike, a Dahon fold-up and a BoB trailer.
Joe
To acquire immunity to eloquence is of the utmost importance to the citizens of a democracy
Bertrand Russell
Baalzamon
Re: Damm It
Postby Baalzamon » Wed Jul 18, 2012 9:28 pm
No no, no problems getting in to home
It's work
Joeblake
Re: Damm It
Postby Joeblake » Wed Jul 18, 2012 9:37 pm
Oh, I see.
To quote Mythbusters:
Image :wink:
Joe
Bertrand Russell
Nobody
Re: Damm It
Postby Nobody » Wed Jul 18, 2012 9:57 pm
Easy then. Get another job and make sure you measure the door before accepting their offer. :D
Phil
Re: Damm It
Postby Phil » Thu Jul 19, 2012 2:52 pm
Nobody wrote:Easy then. Get another job and make sure you measure the door before accepting their offer. :D
I think this is the ideal solution!
