TOURING -another "help me buy a recumbent (TRIKE) thread"
• Page 1 of 1
TOURING -another "help me buy a recumbent (TRIKE) thread"Looking at adding something extra to my bike touring capacity. One option is to buy a fat bike (and be desert sand savvy). The other is to buy a recumbent (probably trike). Probably have a real use for the fat bike once a year and the trike every fortnight, so at the moment a recumbent is looking pretty good. As you can probably guess, I have zero experience with either recumbents or trikes.
All the good rides in my area have mountains which tend to make you feel every gram of touring gear onboard. I figure a trike will help lessen the load (or at least make it less of a sweat). Things that concern me/to avoid about a trike: 1. Having two wheels at the back so you get a face full of what ever the front one throws up at you (also planning to have the option of towing my extrawheel trailer, so a single rear wheel is really what I am looking at) . 2. Having to micromanage every rut and bump on the road since you can't use your legs as suspension 3. Safety issues eg : Taking up a wider slot of the road or not having the better turning response to a hazard a two wheel offers. Also the danger of not being so visible due to low position (planning on mounting some 1.5 metre balinese flags to add a "here I am" factor) 4.Low ground clearance ( is the low point on many trikes somewhere between the front and back wheels? - so you are likely to bottom out on a speed bump ?- or is more closer to the wheel/s? - so that whatever the wheel is clearing, there is a good chance the bike will clear unless you chance on some derailleur smashing rock or log that MTB'ers are similarly wary of)? what looks good in a design 1. carrying luggage space (preferably with regular panniers bags - I already have some great ortielbs - I usually tour with between two and four panniers depending on circumstance) I could go with a simple two bag pannier carrying option since I could tag along the extrawheel cargo trailer to bring the other two as the need arises) . Whatever the case, a strong pannier rack is definitely on the cards 2. good low maintenance seat (the mesh one's look good since they are ventilated and seem to offer an element of suspension) 3. avoiding disc brakes would be good since they can be a bit high maintenance (although I would be willing to go for disc brakes if it was part of a model that was perfect in some other aspect) 4. In two minds about whether suspension would be a good idea (smooth out the bumps) or a bad idea (add yet another thing that could potentially go wrong). However I am pretty much convinced that coil suspension is the only sort of suspension for long distance touring - running into trouble with air suspension and no bike shop for 500 km is simply not worth it 5. Seen some models that can take either a 700 or a 20/26 rear wheel (I like the idea of having a speedy option for short two day tours and an endurance option with three uniform wheels... avoiding the necessity of carrying extra repair/replacement gear for the different wheel sizes). Not a must for the final choice but I like it 6. Dynamo hub on one of the wheels is not a must but sounds good (for the purpose of powering front and rear lights) 7. I imagine it would mostly see use on sealed roads, but having some sort of off-road capacity, eg: dirt road, would add to the fun I am about 180cm and 80kg. Price wise, I am willing to go around $4000, but anything over $3000 has me thinking whether it is really worth it. Having said all this, if you think there is a good reason for ignoring/adding something to my design "for's" and "against's", please feel free to chime in. Here are some models (mostly just one type of model per brand) I have been thinking about (mostly using flyingfurniture website because they have all the specs easily accessible ... may actually make purchase at http://www.recumbent.net.au/ in sydney or epic cycles in brisbane ... just in case anyone thinks I am spamming the innocent public ) : In summary here are the 4 models that seem most suitable. ICE Sprint 26 - fast touring $3,050 (swap rear wheel for 700 or 26 as need arises?) HP Velotechnik Scorpion FX $3,650 (onroad/offroad suspension?) Catrike Expedition $2,710 (on-road/off-road - good luggage?) Greenspeed magnum $2990 (onroad/offroad strongest frame?) Details and a few more I squizzed at here: 1. Greenspeed magnum $2990 http://www.greenspeed.com.au/pdfs/Greenspeed.Magnum.pdf pro's - strong frame - high ground clearance - good price - no disc brakes - small pack down size (33 x 29 x 18") - 3 uniform wheels con's - only takes a single pannier rack (and not the strongest sort, even if you opt for the special one ..... (not sure if rear pannier racks are pretty much generic on recumbents or if there a host of different racks for every brand) 2. Performer JC70 $1590 http://www.flyingfurniture.com.au/shop/ ... -mesh-seat pro's - low price - seems speedy - single pannier rack but good load carrying (30kg) cons -seat looks like it would get weathered and worn out - 2 different sized wheels - disc brakes 3. HP Velotechnik Scorpion FX $3,650 http://www.flyingfurniture.com.au/shop/ ... ding-trike pro's - folds up - 3 uniform tyres - pannier rack option for 4 bags/ 50 kg - coil suspension - on road and off road - mesh seat option - 10 yr warranty on frame cons - disc brakes 4. ICE Adventure - touring/commuting - folding trike $2,890.00 http://www.flyingfurniture.com.au/shop/ ... ding-trike pro's -suspension optional (for more $) -good price -no disc brakes - mesh seat -folds cons - not the best racks 5.Catrike Villager - tourer / commuter $2,310.00 http://www.flyingfurniture.com.au/shop/ ... commuting- pro's - low price -folding -adjustable seat - reasonable pannier carrying upgrades available - good ground clearance cons -disc brakes 6. ICE Sprint 26 - fast touring $3,050 http://www.flyingfurniture.com.au/shop/ ... -options-0 pro's - takes 25 or 700 wheel - good seat cons -moderate luggage capacity -disc brakes 7. Catrike Expedition $2,710 http://www.flyingfurniture.com.au/shop/ ... gcommuting pro's -great luggage capacity - strong frame -uniform wheels - good seat - good price cons - disc brakes Suggestions welcome PS - going for a test ride on greenspeed trike (not a model I think I am interested in) on saturday just to get a feel for the whole trike thing GO!! Run!!! GAAAAAAAAAHHHHHHH!!!!!!
Re: TOURING -another "help me buy a recumbent (TRIKE) threadIce Adventure?
Regardless if you are going to be carrying more than 25kg of weight you will require a trailer. Racks typically rated to that. Mudguards, Rear Rack are pricey options Do not buy a trailer from FlyingFurniture. They are cheaper direct from radical design. Suspension is damn nice to get, I'm glad FF screwed up on me so I did get full suspension Would be worth a trip to FF to have a good look and compare the HP Velo to the Ice Adventure/Sprint to the Greenspeed Magnum. Performer JC20 my opinion I tried and wasn't impressed. FYI my Ice Adventure I get my camping gear, and my clothing with a bit of food on no problem. It is rated to 25kg then need the trailer Masi Speciale CX 2008 - Brooks B17 special saddle, Garmin Edge 810
Re: TOURING -another "help me buy a recumbent (TRIKE) threadstill finding more
Freedom explorer with high clearance (AT) $ 2250 http://www.freedomhpvs.com/explorer_web_page.htm or more speedy (large rear wheel) Sirrocco (AT) $ 3322 http://www.freedomhpvs.com/Sirrocco_web_page.htm or high clearance skinny profile (but non-meshed seat) Gizmo (AT) $3700 http://www.trisled.com.au/gizmo.asp Logo trikes look good - no idea on prices but guessing they are coming in around the same mark MRT - good luggage capacity $2490 http://mrrecumbenttrikes.com/mrt.html swift touring - good luggage $2,850 http://mrrecumbenttrikes.com/touring.html and on a final expensive note ... The SWAGMAN $4,390 http://mrrecumbenttrikes.com/swagman.html and SWIFT Adventure $4,890AUD http://www.mrrecumbenttrikes.com/adventure.html both full suspension ... at the very least I think we can add .... Gizmo (AT) $3700 (skinny profile high clearance) MRT - good luggage capacity $2490 swift touring - good luggage $2,850 Last edited by Cheesewheel on Thu Sep 27, 2012 11:03 am, edited 2 times in total.
Re: TOURING -another "help me buy a recumbent (TRIKE) threadLogo trikes the owner is AWOL back doing engineering so will be a good wait from him
some of the racks on FF are rated to 30kg - Probably won't be going over 25 but I figure the more weight they can handle, the less likely they are to break. Anyways if extra luggage is a non-issue I guess we can scrub it as a pro ... although even having extra real estate to play with is an attractive option eg ![]() Not making my rear and front pannier ortliebs redundant is always a plus (not sure exactly how the front ones are hooked up there ... or even how much clearance they have) )
hoping to avoid mudguards if possible - just another thing to lose a screw and clatter around - from the look s of it, they won't keep anything off the drive train anyways. I notice FF has prices for mudguard etc group sets and drive train guard protection etc group sets.
already have an extra wheel pannier trailer (basically just a pannier rack on a wheel) and bags for it. Hoping to stick with that.
Is your suspension only really doing anything much when you leave a sealed road? is that the rear suspension only $3,550 (within my budget) http://www.flyingfurniture.com.au/shop/ ... ding-trike or dual$4,590.00 (approaching the outer orbits of my budget) http://www.flyingfurniture.com.au/shop/ ... dard-model or the special priced dual $3,990 (just within my budget) http://www.flyingfurniture.com.au/shop/ ... y-option-0 . If something did go wrong with them and they went flaccid, would your trike still be ride-able?
Yeah I forgot all about that - I already have a dynamo hub on my extra wheel trailer - I guess I wanted to go for two so I could keep the lights going and recharge stuff at the same time.
I live two states away - the plan would be to iron out whatever specs I wanted and catch a plane to pick it up then ride it home (in time for work) The plus of the magnum is its weight capacity - thinking I might be able to squish in extra luggage (ie water for long dry hauls)
so that's two panniers and a little something tied to the top? I read a few of your other posts about your trike adventures - I recall you made mention that it wasn't the best thing to ride to work (car problems maybe?) so I take it you mean it comes in to its own when its a bit out of the urban stretch ... you mention somewhere about some plastic coming off the seat or something (and this caused a problem with seat adjustment .... which you solved by jury rigging some solution - details escape me now).. Any fault/wear and tear that seems to arise from use/design that makes you pause for thought? EDIT - I mixed up your name with other blogs and stuff on trikes I was reading - It was a QR skewer that you got replaced - I think its time to stop surfing the net looking for stuff on recumbents and take a nap. -yawn- GO!! Run!!! GAAAAAAAAAHHHHHHH!!!!!!
Re: TOURING -another "help me buy a recumbent (TRIKE) threadThe ICE FS (Full suspension) trike use elastomers......so not sure how they could fail apart from physically removing the elastomer......
There is not much that can go wrong..... I have an ICE Vortex FS and it's brilliant, I used to own a Greenspeed GT5 and it's chalk & cheese.......The FS ICE trikes win hands down compare to my old GT5 - no contest...... To put it into perspective, coarse chip on a GT5 trike killed a decent LED lamp in just 40 minutes - the high frequency vibration was that bad.......the replacement lamp is still going strong 4000km later on my FS Vortex. Hydraulic disc brakes are brilliant, where does this idea of hydraulic disc brakes being unreliable come from ? I have them on my MTB and had them on 2 trikes and faultless......low maintenance - just inspect every 500km when I turn my tyres and wipe off some dust and check the pad thickness....... And powerful enough to lift the rear wheel during emergency stops !! Baalz, also seems to love his FS Adventure too !! Just me thoughts.....
Re: TOURING -another "help me buy a recumbent (TRIKE) threadHydro brakes vs drum brakes
Scenario doing 25kph Phil in his vortex + with hydraulic discs Me in my adventure with drum brakes We both brake at the same time. Phil came to a dead stop in less than a metre, took me 5m to come to a stop Chain tubes are brilliant Just remember as well trikes have a weight limit. So figure 80kg in your body weight, few kg in water You will be upto over 95kg easily imo depending on your camping equipment etc Shame you can't get a Stein trike over here.... I would have jumped at one of those Masi Speciale CX 2008 - Brooks B17 special saddle, Garmin Edge 810
Re: TOURING -another "help me buy a recumbent (TRIKE) threadCat among the pidgeons here......
go for a Velomobile.... a "trike-in-a-shell" i.e., Trisled Rotovelo.....chuck all the gear in, and away ya go.. Moving on from my old 'bent..... now a Velonaut !!
Trisled Rotovelo..... and away we go!!
Re: TOURING -another "help me buy a recumbent (TRIKE) threadJust thought I'd chime in too.
I have a LogoTrike. Very nice. Pity Martin is taking a sabbatical from trike building. My experience is the disk brakes are great and have given no trouble in thousands of km. Mudguards are pretty much essential in the wet or you will get covered in muck. Look where the front wheels are in relation to you. we, my wife and I have never had a problem with themudguards coming loose or rattling on the Logos. A couple, Andrew and Joanne Hooker rode Logos round Australia and also from Dead Horse Alaska down into the US. On the round Australia ride the used bob trailers successfully. I didn't hear them complain about rough roads even though their trikes didn't have suspension. That was probably because they were not travelling at any great speed while touring though. I know that given a choice I will use the trike to tour every time. John
In my opinion seek out a trike that has an adjustable seat so you can fine tune the angle as a fixed back when touring you will soon find out is just not right. Steal frames are better for touring as repairs can be made with ease and most cow cocky's/towns have welders where as you will be hard pressed to find someone to fix alloy. Also don't be too concerned trying to find narrow width in trikes I find that when touring having a wider cockpit is more relaxing and stable. I also find direct steer is better for touring it gives more room and better adjustment for fine tuning handling along with tuning your hand position to be more relaxed. Some trikes have bushings in the steer while most have bearings for be I want bearings. I use a MTB crank and chainrings when touring it gives me enough top end plus allows me to climb the biggest steepest mother out there hauling a trailer so many of the trikes come with a road set-up for cranks. I hope this has helps you a little. Ricky
Re: TOURING -another "help me buy a recumbent (TRIKE) threadThanks for the info so far folks.
(SkOrPn you have three layers of mesh on your seat? Is it easy enough to jury rig shade cloth on the seat frame? Also interested in detail about your solar set up if you've got a link where you've discussed it in detail) as far as models jockeying for position ... at least a disc brake on the rear would be good, mudguards and an adjustable seat a must. Chain tubes sound like a good idea too. Steel frame would be good for impromptu repairs Greenspeed magnum (maybe get a disc brake customed for the rear) http://www.greenspeed.com.au/pdfs/Greenspeed.Magnum.pdf Catrike Trail - tourer / commuter (new adjustable seat angle model) - would have preferred an adjustable seat on their expedition model so I could cash in on the better luggage carriage .... http://www.flyingfurniture.com.au/shop/ ... ommuting-0 an Ice model with http://www.flyingfurniture.com.au/shop/ ... y-option-0 http://www.flyingfurniture.com.au/shop/ ... ding-trike or without suspension http://www.flyingfurniture.com.au/shop/ ... ding-trike Still unsure why The GTO touring trike gets such a high price tag http://www.greenspeed.com.au/gto.html GO!! Run!!! GAAAAAAAAAHHHHHHH!!!!!!
Re: TOURING -another "help me buy a recumbent (TRIKE) threadAsk how I go on the weekend
My Ice Adventure FS HD is tackling a portion of the Munda Biddi. Changed the rear tyre to a knobby BMX one, may need to lose my mudguard but small concession for rear traction on pea gravel! Masi Speciale CX 2008 - Brooks B17 special saddle, Garmin Edge 810
Hi CW I have the ACS10 mesh in the below link which I use three layers to make up my own personal level of comfort. http://www.empind.com.au/shop/item/air-circulation-mesh-acs10 As for Jury rigging shade cloth to the frame it can be done but in my case both the bucket style and older style would need some thinking and messing around for it to be done and I would say a heavy duty sewing machine. I use a standard home sewing machine when making my ACS10 mesh seat but to do as you asked on mine I think building a new chair frame that is more straight sided would be cheaper or even buying a pre-made one from another trike manufacture and retro fitting. I don't have a link to any discussion on my solar set-up but what I do have is a Brunton 26w fordable solar panel which charges all my devices that I drape over the trailer and have wires made up that are hidden and connect to the bike much like a car trailer wiring set-up. I also have a 16000mAh Solar Power Universal Charger that charges or powers everything from 5v-19v and in the case of phones and the likes will charge them back to being full in 2 hrs and you get about 6 charges from that unit before itself needs charging either via mains power it's own solar cell or external solar panel. http://store.bruntonoutdoor.com/portable-power/foldable-solar-panels/solaris-26-12v/ ![]() ![]() Both devices are protected so there idiot proof they can't be wired up wrong or wrong settings use on a device that your charging or running as a power source. Ricky
Re: TOURING -another "help me buy a recumbent (TRIKE) threadAfter doing my lose-your-inhibitions-against-riding-through-hilly-terrain tour on a fully loaded surly + extrawheel I gave serious thought to the idea of moving over to a trike (particularly when going down hill - on more than one occasion I nearly lost it to speed wobbles .... what to speak of coming down on a gravel road ). I think I will go for something a bit more expensive (probably an ICE tourer with some sort of suspension) than what I had originally set out. This will push the purchase date back some time. Might come back to this thread later when I have the extra $$$.
Thanks for all your help guys GO!! Run!!! GAAAAAAAAAHHHHHHH!!!!!!
Re: TOURING -another "help me buy a recumbent (TRIKE) threadCW can I make a suggestion from experience if your going to tour on a trike and use a trailer get the trike fitted with 203mm rotors the 160mm rotors that come stock on many of the trikes just don't cut it there not up to the task of long steep decent. Even if your not going to get a trailer for a trike the bigger rotors will still be a god send to have they really make the world of difference. If you set up the rod ends and balance your load right you will have an easy ride down hills even towing a trailer. On mine I have hit over 80km towing and it's been real stable plus you can corner on a knife edge if needed. The other great thing about 3 wheels is if going up hill you can stop dead and have your bike balanced/stable to either take pictures of just relax no trying to keep control of bike balance like a DF. If you get a ICE trike your in good hands there a great machine and well built for the money you spend so good luck in finding your new bike.
Ricky
Re: TOURING -another "help me buy a recumbent (TRIKE) threadRe ACS10
I think I posted pictures here of how I did my seat pad. Ventisit style. I used small cable ties and it is pretty much like the ventisit method I think. Finished pad ![]() I have to get off line now as I am off to the city 4.30 am tomorrow. I'll look for the post when I get back and if I can't find it I'll repost the details. For the "shade cloth style I used some outdoor furniture mesh. Its like shadecloth but stronger. my local upholsterer had it. I got him to stitch a tubular fold down each side, punched some semicircular holes and slid some ali wire (later brake cable outer) down the tubes . It wraps round the seat sides and is tensioned with cable ties but it could be bungy cord if you wish. ![]() ![]() John
Single wheel trailers and tadpole trikesnot wanting to throw a spanner in the works but I recall concerns regarding single wheel trailers and tadpole trikes. I remember Greenspeed were selling and spruiking BoB trailers, but switched to Burleys. I also seem to recall that ICE were not recommending them for their suspended models at least. I've done a little hunting but can't find (and don't have the time) the threads at Bentrider to link to.
The concern centered around twisting forces applied to the rear triangle in turns. It was some time ago, which may explain my difficulty in finding the relevant links, but worth asking the question of suppliers if you're intending to use the Extrawheel. cheers glen I like to ride my tricycle
Spanner rejected I asked Ice Trikes about my Ice Adventure FS HD and they suggested the Cyclone IV Trekking and so did FlyingFurniture Masi Speciale CX 2008 - Brooks B17 special saddle, Garmin Edge 810
• Page 1 of 1
Who is onlineUsers browsing this forum: eldavo |
