Shimano Dura-ace Bar End Shifters
Postby Aushiker » Tue Dec 04, 2012 9:50 pm
In looking at options for a trike or velomobile specification I was considering going with Shimano Dura-ace Bar end shifters based on my experience as a touring cyclist where they are popular. However, I notice over at BROL that there seems to be a bit of dislike for more recent incarnations of the shifters with some riders reporting issues.
I am curious to know if anyone here has had negative experiences with their Shimano Dura-ace Bar end shifters as my Google searches only bring up threads at BROL and the Catrike forum.
by Forum Ads » Tue Dec 04, 2012 10:02 pm
Re: Shimano Dura-ace Bar End Shifters
Postby Chef » Tue Dec 04, 2012 10:02 pm
Hi,
I have no experience with recumbents, but do use 9 and 10 speed dura ace bar end shifters - both are latest gen (I was so happy with the 9-speed set up on my disc trucker that I went with bar ends on my new cross bike).
They work fine - I am very happy with the 10 speed as i routed cables under the bar tape and was concerned that shifting would be affected by the extra bends, but indexing is perfect.
"A dessert without cheese is like a beautiful woman with only one eye."
Jean Anthelme Brillat-Savarin
Chef
Postby Aushiker » Tue Dec 04, 2012 10:04 pm
Chef wrote:Hi,
Yeah that is my experience on a diamond frame too, which is what got me wondering if this was a particular issue to trikes and/or BROL members :)
Postby Baalzamon » Tue Dec 04, 2012 10:43 pm
I had them on my Ice trike and loved them compared to the twist shifters.
Baalzamon
Postby Baalzamon » Tue Dec 04, 2012 10:59 pm
Also might add that I did lose a shifter bolt but it was a no brainer to replace it.
Baalzamon
Postby John Lewis » Wed Dec 05, 2012 12:17 am
I've had no trouble with the 8 speed version.
I have heard of some problems due to that round plastic part breaking probably due to UV degradation.
That wouldn't really be a problem if you could buy spares but unfortunately it seems Shimano don't make them available.
John
John Lewis
Postby just4tehhalibut » Wed Dec 05, 2012 12:22 am
Grip shifters can be a bit messy for replacing cables, not as nice in the actual shifting, but can be an advantage when you're cruising along. Since most trikes are underseat steer this means that bar end shifters will stick up on the ends of the handlebars, grip shifters don't and provide you a flat rubbery surface on the end of each bar to rest your hands on while pedalling along. In other words you have to grip with bar ends but can deckchair with grip shifters.
If I was touring however I'd consider bar ends on durability and maintenance.
just4tehhalibut
Postby fthills » Sun Dec 09, 2012 11:11 am
Hi Andrew,
The latest iteration lack the facility to use them in friction mode,like the shifters of old on downtubes .The new models can only be used indexed.
This makes for a considerable reduction in versatility if you want to experiment with different derailleur/ cassette combinations .
Friction means you can use any brand derailleur and any cassette, with no modification required.
If you need to know which model numbers have /haven't got friction mode let me know and I'll have a look at the boxes in my spare parts box
fthills
Postby william » Mon Dec 10, 2012 4:46 pm
I have 9 speed Dura Ace on my Bacchetta. It initially had sram grip shifters. I went back to grip shifters and immediately went back to the bar ends.
I think the 10 speed versions are the ones that have had durability problems but not widespread as the complainers will have you believe.
I also have 10 speed Sram bar ends on my Musashi and have no problems at all. These have covered about 9,000K's and the Shimano 9 speed has seen about 14,000K's. Both sets still working like new.
william
Postby John Lewis » Mon Dec 10, 2012 11:14 pm
Take a look at Pauls Thumbies
I read of them used on some Quests.
I thought they would convert to friction but reading it seems to suggest it depends on the barcon you are converting.
http://www.paulcomp.com/thumbies.html
John
John Lewis
Postby nessbike » Sun Dec 16, 2012 4:42 pm
devotees of pauls thumbies (and I have a couple of pairs) might also be interested in a newish product from taiwanese company microshift. Thumb shifters in 8, 9 or 10spd out of the box: http://www.microshift.com.tw/city_Shifters.html . A friend got a new bike recently speced with the 10spd version, they work suprisingly well and don't look to bad (not big and clunky like some thumb shifters. And slightly better priced and less fiddling than pauls thumbie bases and seperate shift lever units from bar end shifters. Cheers Alex
nessbike
Return to Recumbents
