Scicon Aerocomfort question
AndyRevill
Postby AndyRevill » Sun Apr 22, 2018 5:23 pm
Hi All,
We're heading to Scotland in a few months and I'm keen to take the road bike for some highland touring. I'm looking at getting the Aerocomfort 2.0 but I notice that most airlines seem to state that handlebars should be turned parallel to the top tube while the Scicon seems to work with them staying as they are.
So my question is, do people rotate them and if so can you still use the relevant straps or do you just ignore that requirement?
Thanks in advance,
Andy
Trek 1.7 dec.
Trek Domane 4.5
biker jk
Re: Scicon Aerocomfort question
Postby biker jk » Sun Apr 22, 2018 5:29 pm
Just use the bag as it's designed. One tip to stop the shifters from potentially being knocked is to use a length of PVC piping across the handlebar (slightly wider than its length and sitting in the recess of the hoods).
Also note that the Aerocomfort 2.0 can not accommodate disc brakes (in case you buy such a bike in future). The Aerocomfort 3.0 can be used with thru-axles.
AndyRevill
Postby AndyRevill » Sun Apr 22, 2018 6:20 pm
biker jk wrote:Just use the bag as it's designed. One tip to stop the shifters from potentially being knocked is to use a length of PVC piping across the handlebar (slightly wider than its length and sitting in the recess of the hoods).
Thanks, my instinct was to do that until told otherwise. Also thanks for the reminder re the pvc, I remember seeing the post a while back. Not sure a new bike is on the horizon :( So will take the cheaper price.
Cheers, Andy
Trek 1.7 dec.
Trek Domane 4.5
BugsBunny
Postby BugsBunny » Tue Apr 24, 2018 11:22 am
I've been on a few bike tours with fellow bikers using the Scicon Aero bag. They all keep the handlebars in their original position. It certainly makes the assembly/disassembly much faster.
As a word of caution, there have been instances where the brake levers get pushed out of alignment due to the protruding nature of the way it fits in the bag, most likely due to poor handling during the air transportation.
MichaelB
Postby MichaelB » Tue Apr 24, 2018 11:59 am
Agree with the 1st bit - Qatar airlines never betted an eyelid.
re the 2nd bit, Discs are fine, but they need to be QR (v 2.0 is QR only). The bag worked fine with my Volagi Liscio when I went to Italy in 2016. - See the Review I did here
Note also that Wiggle do a similar bag to the Aerocomfort (actually made by Scicon) - Wiggle dhb Soft wheeled buike bag , but the handlebars need to be rotated (despite the pics), other than that, it's the same, but made to a budget.
