Scicon Aerocomfort question
AndyRevill
Postby AndyRevill » Sun Apr 22, 2018 5:23 pm
Hi All,
We're heading to Scotland in a few months and I'm keen to take the road bike for some highland touring. I'm looking at getting the Aerocomfort 2.0 but I notice that most airlines seem to state that handlebars should be turned parallel to the top tube while the Scicon seems to work with them staying as they are.
So my question is, do people rotate them and if so can you still use the relevant straps or do you just ignore that requirement?
Thanks in advance,
Andy
Trek 1.7 dec.
Trek Domane 4.5
biker jk
Re: Scicon Aerocomfort question
Postby biker jk » Sun Apr 22, 2018 5:29 pm
Just use the bag as it's designed. One tip to stop the shifters from potentially being knocked is to use a length of PVC piping across the handlebar (slightly wider than its length and sitting in the recess of the hoods).
Also note that the Aerocomfort 2.0 can not accommodate disc brakes (in case you buy such a bike in future). The Aerocomfort 3.0 can be used with thru-axles.
AndyRevill
Postby AndyRevill » Sun Apr 22, 2018 6:20 pm
biker jk wrote:Just use the bag as it's designed. One tip to stop the shifters from potentially being knocked is to use a length of PVC piping across the handlebar (slightly wider than its length and sitting in the recess of the hoods).
Thanks, my instinct was to do that until told otherwise. Also thanks for the reminder re the pvc, I remember seeing the post a while back. Not sure a new bike is on the horizon :( So will take the cheaper price.
Cheers, Andy
Trek 1.7 dec.
Trek Domane 4.5
BugsBunny
Postby BugsBunny » Tue Apr 24, 2018 11:22 am
I've been on a few bike tours with fellow bikers using the Scicon Aero bag. They all keep the handlebars in their original position. It certainly makes the assembly/disassembly much faster.
As a word of caution, there have been instances where the brake levers get pushed out of alignment due to the protruding nature of the way it fits in the bag, most likely due to poor handling during the air transportation.
MichaelB
Postby MichaelB » Tue Apr 24, 2018 11:59 am
Agree with the 1st bit - Qatar airlines never betted an eyelid.
re the 2nd bit, Discs are fine, but they need to be QR (v 2.0 is QR only). The bag worked fine with my Volagi Liscio when I went to Italy in 2016. - See the Review I did here
Note also that Wiggle do a similar bag to the Aerocomfort (actually made by Scicon) - Wiggle dhb Soft wheeled buike bag , but the handlebars need to be rotated (despite the pics), other than that, it's the same, but made to a budget.
g-boaf
Postby g-boaf » Wed Jun 13, 2018 2:07 pm
BugsBunny wrote:I've been on a few bike tours with fellow bikers using the Scicon Aero bag. They all keep the handlebars in their original position. It certainly makes the assembly/disassembly much faster.
I had that with a Scicon Aerocomfort last year coming back with Emirates. Somewhere between Venice, Dubai and Sydney they got pushed inwards. Might not have helped that the entire Brazilian football team with all of their stuff was on our flight too.
This year I'm not using a borrowed bag so was going to go for one of these:
https://www.99bikes.com.au/bike-bag-evoc-pro-black
The reason being is that the Scicon bags in my experience behave a bit like evil shopping trolleys and go fish-tailing all over the place, not exactly ideal when you are battling with other stuff as well. However having to disassemble the handlebars is a deterrent.
A_P
Postby A_P » Wed Jun 13, 2018 4:24 pm
↑ I have the Evoc, it is seriously easy to wheel around airports.
g-boaf
Postby g-boaf » Tue Jun 26, 2018 10:42 am
A_P wrote:↑ I have the Evoc, it is seriously easy to wheel around airports.
I ended up going with Scicon Aerocomfort 3.0 - the version aimed at TT bikes because it was a price too good to pass up.
The wheels on it are a lot better than the older version.
Derny Driver
Postby Derny Driver » Tue Jun 26, 2018 12:01 pm
I have an old SciCon bag ... the original wheels were terrible - fragile and easily smashed. I replaced all 4 with heavy duty ones from Bunnings. The front 2 are whopping big castors which rotate, for the rear 2 I used heavy duty fixed non-turning wheels. Solves the problem of the thing wanting to go sideways every time you pull it.
g-boaf
Postby g-boaf » Tue Jun 26, 2018 12:32 pm
That sideways thing is the bit that drove me mad the most. When you've already got a big trolley bag you are pulling along and a backpack, it's really annoying especially with those narrow winding queues they love to have at airports.
The other thing the old one would do is beach itself (like an F1 car in a gravel trap) on any tactile tiles like what they have on railway station platforms. At least the newer ones have much larger wheels that lift it higher off the ground.
Good suggestion on changing the wheels - much appreciated, I'll see about doing that with mine.
queequeg
Postby queequeg » Tue Jun 26, 2018 12:57 pm
That's what I got for my aborted Europe trip, instead of the Aerocomfort, which was originally my first choice. However, after seeing far too many pictures of smashed handlebars and broken gear levers, I took the advice of the tour company and went with the Evoc. Maybe one day I'll even get to use it! Doctor gave me the all clear for riding again today, so now I just need to to slowly rebuild.
g-boaf
Postby g-boaf » Tue Jun 26, 2018 1:52 pm
Yeah I read that you got the all clear - that's awesome news. :)
AndyRevill
Postby AndyRevill » Thu Jul 05, 2018 9:50 pm
By way of a mid-trip update, I ended up with the Aerocomfort 3.0. Packed the bike with a heap of pipe lagging on exposed parts of the frame and a section of cardboard poster tube between the handlebars. All arrived in perfect condition (Etihad). Did an 8 day ride around the west coast of Scotland (highly recommended, especially if you like hills).
Only drama was when putting the bike back in the bag for storage for the rest of the trip I discovered the locking T-piece for the bottom quick release frame (the bit that allows you to adjust the overall length and clamp it in position) had lost the threaded insert from the plastic knob. Contacted Scicon UK and within an hour they had arranged for a free replacement to be sent - DHL from Italy! Can't fault that for worldwide service :D
here's hoping the return trip goes just as well!
Andy
Trek 1.7 dec.
Trek Domane 4.5
