L"Equipe analyses Froome's data
Alex Simmons/RST
Re: L"Equipe analyses Froome's data
Postby Alex Simmons/RST » Tue Jul 23, 2013 7:26 pm
hannos wrote:If SKY / Froome have nothing to hide, then release the data publicly. From all the team. From the last several years.
That will prove beyond doubt he's either clean or dirty.
No, it won't.
Or put it this way. Say the data was released.
In what way would it prove a rider wasn't doping?
It what way would it prove he was?
biker jk
Postby biker jk » Tue Jul 23, 2013 7:40 pm
No, it won't.
In the same way that USADA found Armstrong's biological passport suggested there was a one in a million chance he was riding clean at the 2009 TdF. Let's see Froome's power data and biological passport for the past 3-4 years.
Postby toolonglegs » Tue Jul 23, 2013 8:16 pm
You don't need to see his power data or passport... The passport is seen by experts already and if they was any obvious issue we would have long since heard about it after it had been leaked to L'equipe.
His power data is his property... He has already released it to an expert, whether you believe in the integrity of the that expert bears little relevance. If it was my property I certainly wouldn't release it to a world full of Internet experts ... Because like Alex says, it doesn't prove or disprove doping, it is just more curiosity fodder for the forums.
Saying that he may well release it... But unless you know his exact weight, bike weight etc on that day then it is not all that accurate... Unless you have ALL his power files for the last few years maybe.
Alex Simmons/RST
Postby Alex Simmons/RST » Tue Jul 23, 2013 8:24 pm
There's a big difference between data measuring what a rider did performance wise (e.g. power) and data that's indicative of what doping a rider may have been using, which is hemotological or investigative in nature.
Power tells us what a rider did, not why.
If you cannot answer the question: "what power = doping?" then how does it help?
And if a rider doesn't exceed a certain arbitrary power level, does that mean they are not doping?
Power data as a dopeometer is a red herring.
biker jk
Re: L
Postby biker jk » Tue Jul 23, 2013 8:44 pm
toolonglegs wrote:You don't need to see his power data or passport... The passport is seen by experts already and if they was any obvious issue we would have long since heard about it after it had been leaked to L'equipe.
First of all Armstrong's suspect biological passport was not flagged by the expert panel. This suggests the system is broken and testing for PEDs needs to be taken away from the UCI. I have no faith in the UCI testing procedures. Second (and this is in response to Alex as well), I note that at last year's TdF Wiggins said that Sky were riding at 450W on the climbs and for a rider to launch a successful attack would require sustaining 500W for 20 minutes which could only be achieved by doping. So there are red flags for power numbers on climbs which can be used to indicate the strong possibility of doping and used in conjunction with the biological passport (examined by Ashenden for example) we could obtain some clarity around Froome's performance.
warthog1
Postby warthog1 » Tue Jul 23, 2013 8:44 pm
Alex stop being objective and factual. It's out of character with the rest of the thread. :P
jcjordan
Postby jcjordan » Tue Jul 23, 2013 8:55 pm
I think you will find Wiggo was being a bit flippant.
500W would be very different for different riders based on there weight and at what point it was in the race.
I am with Alex I can't even how power to weight can be used as a indicator of doping.
That being said once you add it to the bio passport data you should start to see improvement in the targeting of both testing and investigations.
So for Armstrong no being picked up I think this has more to do with the infancy of the program than any failing of the system.
Sent from my GT-I9305T using Tapatalk 4 Beta
James
Re: L
Postby Mulger bill » Tue Jul 23, 2013 9:17 pm
biker jk wrote:...testing for PEDs needs to be taken away from the UCI. I have no faith in the UCI testing procedures.
Can't say a word agin this, if you want transparency...
biker jk wrote:Second (and this is in response to Alex as well), I note that at last year's TdF Wiggins said that Sky were riding at 450W on the climbs and for a rider to launch a successful attack would require sustaining 500W for 20 minutes which could only be achieved by doping. So there are red flags for power numbers on climbs which can be used to indicate the strong possibility of doping and used in conjunction with the biological passport (examined by Ashenden for example) we could obtain some clarity around Froome's performance.
Ummm, no offence to Sir Braddles but I'm not sure I'd be seeking him out for an expert opinion on anything beyond surviving looking at 6 black and blue bums for thousands of km. :wink:
Re: L
Postby toolonglegs » Tue Jul 23, 2013 9:30 pm
I thought WADA and the AFDL tested at various TDF's... Not the UCI.
Also as Wiggo was on oval chain rings last year his quoted power readings can not be compared to someone using round rings.
Still fail to see how anyone here is going to see something a panel of experts are not seeing.
Froome shouldn't have to release anything unless everyone has to...
jcjordan
Postby jcjordan » Tue Jul 23, 2013 9:36 pm
toolonglegs wrote:I thought WADA and the AFDL tested at various TDF's... Not the UCI.
Froome should have to release anything unless everyone has to...
Ok off topic but I keep hearing that opalised rings give different power readings but my experience did not show this.
I use rotar ring on a P2M and did a climb multiple times and compared power reading against time and found them to be well within the 1% calibration error factor.
James
Re: L
Postby toolonglegs » Tue Jul 23, 2013 9:38 pm
Alex can answer this better than me ... I remember him mentioning that there is no way they can be comparable.
Alex Simmons/RST
Re: L
Postby Alex Simmons/RST » Tue Jul 23, 2013 9:50 pm
It depends on how the power meter samples crank rotational speed.
P2M haven't told us how they sample rotational speed, but it may be plausible they are less prone to artificial inflation of power numbers compared with crank based power meters that sample rotational speed once per revolution. All we know is they use accelerometers to determine crank rotational speed and not reed switches, but that doesn't tell us whether P2M actually samples rotational speed with greater frequency than say an SRM or a Quarq.
Non-round rings cause crank meters to over report power as the peak torque values are over sampled and "dead spots" are under sampled. If I had to put a rough estimate of how much the effect is, I'd say it'd be in the vicinity of a few percent.
Alex Simmons/RST
Re: L
Postby Alex Simmons/RST » Tue Jul 23, 2013 9:58 pm
I'm not saying we shouldn't seek a better system for anti-doping control. All I'm saying is that power data won't help. We don't need power data to know who finished first, or climbed the fastest, and perhaps should be the target of more frequent testing.
vander
Re: L
Postby vander » Tue Jul 23, 2013 10:11 pm
Yes people will pick up things. Firstly the "panel of experts" often dont even see the files only if it is flagged by the system. Secondly they only get very specific points. They did look at Armstrongs numbers from his biopassport, and at the time they said they were OK, however it was incomplete missing some key data points. When looked at as a whole it became a lot more clear that he was doping.
The biopassport is poor at picking whether people are doping, however what it does is helps to control how much they can dope, not too dissimilar from the 50% HCT rule but more individual and more sensitive.
Power data will never be proof that someone is doping. However it can provide some indication or help to highlight some suspect performances. Looking past numbers from times when we know the people were doping we can get an idea of what is achievable naturally and what is "not normal". While "not normal" doesnt imply doping it is an indication. All I can say is getting times up a few climbs close to the all time best times (including the dopers) is "not normal".
I agree that transparency will only be a good thing. Giving out a few climbs in the last few years post his transformation to an analyst with a clouded past (I know that the facade is they did not choose him but I dont believe that to be the case) to me is doing the opposite to what they wanted, its a cheap PR stunt, which they seem good at.
@alex the number that I heard thrown around was 20-30W at around 400W so 5ish% dont know if this was based on anything or an arbitrary number.
jcjordan
Postby jcjordan » Wed Jul 24, 2013 11:09 am
toolonglegs wrote:
jcjordan wrote:[quote="toolonglegs"]I thought WADA and the AFDL tested at various TDF's... Not the UCI.
Non-round rings cause crank meters to over report power as the peak torque values are over sampled and "dead spots" are under sampled. If I had to put a rough estimate of how much the effect is, I'd say it'd be in the vicinity of a few percent.[/quote]
Thanks Alex
Based on DC Rainmakers review the sample rate is 50hz. I am not technically knowledgeable to determine if that is good or bad against the competitors.
James
Alex Simmons/RST
Re: L
Postby Alex Simmons/RST » Wed Jul 24, 2013 1:57 pm
jcjordan wrote:Based on DC Rainmakers review the sample rate is 50hz. I am not technically knowledgeable to determine if that is good or bad against the competitors.
Power2Max did not clarify whether they are sampling rotational speed at 50Hz, or just torque at 50Hz. There's quite a difference between those measurements and how it affects readings when using non-round rings.
For reference, an SRM samples torque at 200Hz and rotational speed once per crank revolution.
jcjordan
Postby jcjordan » Wed Jul 24, 2013 1:59 pm
James
