Hour Record thread
Re: Hour Record thread
Postby warthog1 » Tue Apr 21, 2015 1:28 pm
I've never raced track. How much, if any, would Wiggo's track heritage favour him over Der Panzerwagen should Tony Martin have a crack?
- Alex Simmons/RST
Postby Alex Simmons/RST » Tue Apr 21, 2015 4:10 pm
Well I can't really speculate about Martin's current track craft and a differential to Wiggins in that regard. He's not totally void of track experience though - he was a member of team that won German team pursuit championship about a decade ago. Team pursuit success at elite level suggest he possesses or can reclaim reasonable track skill levels.warthog1 wrote:Thanks for that Alex
I did an analysis of the impact of track craft on track lines for six pro-continental pro riders. Even quality road riders vary quite a lot in their track proficiency:
http://alex-cycle.blogspot.com.au/2015/ ... thers.html" onclick="window.open(this.href);return false;
Postby warthog1 » Tue Apr 21, 2015 5:25 pm
Thanks again AlexAlex Simmons wrote: If you ride 10cm wider in the turns, you add 10cm x 2 x PI = 62.8cm per lap.
If the extra width is measured on the track's surface, well the actual addition to the distance the wheel travels is reduced by the cosine of the banking angle. e.g. say the track's turns are, on average, banked at 40 degrees, and you ride 10cm above the black line. Then the actual additional track radius ridden is cosine (40 degrees) x 10cm = 7.7cm, and the additional distance per lap = 7.7cm x 2 x PI = 48.1cm. Nearly half a metre.
Do that over 200 laps or so for an elite hour record and you'll ride ~100 metres more than you need to. And that's for riding only a hand's width above the black line.
Given they should be pretty close if TM does have a crack it could make some difference.
Postby CKinnard » Tue Apr 21, 2015 8:36 pm
what's Wiggo's CdA?Alex Simmons/RST wrote:Wiggins has superior W/m^2 compared with Dennis
Postby warthog1 » Tue Apr 21, 2015 8:48 pm
In my uneducated opinion
Postby Bluejay87 » Tue Apr 21, 2015 8:56 pm
Would the aero benefit outweigh the loss of oxygen and therefore power. Was just reading this old article about Jens Voigt which suggested his FTP is 420-440 at sea level compared to 370w at 9000-10,000 feet. Seems like such a drop in power would need a huge aero benefit to be adequately compensated for:warthog1 wrote:not doing it at altitude seems counterintuitive.
http://velonews.competitor.com/2012/08/ ... nge_235832" onclick="window.open(this.href);return false;
Postby warthog1 » Tue Apr 21, 2015 9:02 pm
Voigt’s functional threshold power (FTP) at sea level is around 420-440W, so adjusting 12 percent off for the elevation, I’ve estimated Voigt’s FTP at 370W for this high elevation race.
Read more at http://velonews.competitor.com/2012/08/ ... arkPZAD.99" onclick="window.open(this.href);return false;
Alex has probably forgotten more about bike racing than I know so I'll go with his opinion.Alex Simmons/RST wrote:
Choosing to ride at sea level is a mistake IMO, but the home court was clearly too big a sales and marketing opportunity to pass up.
Also this bloke was no fool
http://en.wikipedia.org/wiki/Hour_record" onclick="window.open(this.href);return false;In 1972 Eddy Merckx set the hour record in Mexico City at an altitude of 2,300m (7,550 ft) where he proclaimed it to have been "the hardest ride I have ever done".
Postby CKinnard » Tue Apr 21, 2015 10:23 pm
I'm wondering on what basis Alex says Wiggo's is superior to Dennis'.warthog1 wrote:I don't believe you need to know it or could know unless you have done aero testing with him. The fact that he has been faster than Rohan means he is either more aero or is generating more power or both.
I think one has to be very careful comparing road ITT course results with track.
Anyway, I'm sure this event is going to generate a lot of interest.
And hopefully we'll all end up better informed about what makes a cyclist go faster...and stop spending $10,000+ on a bike only to end a ride at the local cafe hoeing into cream puffs (rather than eating rabbit food, and stretching hams and spine)
Topically, I had a low fat soy flat white this morning with one of the lads, who rolled up on a new Storck with Cosmic deep sections and super record groupo.
- Alex Simmons/RST
Postby Alex Simmons/RST » Wed Apr 22, 2015 7:31 am
For the simple reason that he has proven to be faster than Dennis in the same flat TTs. That requires superior W/m^2.CKinnard wrote:I'm wondering on what basis Alex says Wiggo's is superior to Dennis'.
Wiggins is no mug when it comes to track W/m^2 either, with several of the fastest individual pursuit times in history.
- Alex Simmons/RST
Postby Alex Simmons/RST » Wed Apr 22, 2015 8:13 am
Yes, it does. You are correct in that it is a balance between the physical benefit and physiological cost.Bluejay87 wrote:Would the aero benefit outweigh the loss of oxygen and therefore power.warthog1 wrote:not doing it at altitude seems counterintuitive.
It is variable of course as adaptation to altitude is individually variable and so how much one benefits depends, but there is benefit at altitude provided you use a suitable venue. Not all tracks have a fast surface, and there are other considerations wrt environmental conditions to account for, but in general for an elite athlete who has altitude-adapted, ceteris paribus, higher altitude = faster (within the altitude range of suitable available tracks).
I wrote about that here as well:
http://alex-cycle.blogspot.com.au/2014/ ... rt-ii.html" onclick="window.open(this.href);return false;
The reason a lot of sea level records exist in historical record is the availability of suitable venues and logistics. Not many quality tracks were available at high altitude close to where riders lived and worked.
I have a bit of experience with this stuff.
I have personally coached 3 successful (and still current) hour records at masters/age cat level, and provided technical and consulting advice on other successful hour records, including at altitude and elite national records. Where altitude was involved, the individual's power loss fell within the ranges discussed in that blog item. Where possible, testing should be performed to assess an individual's response, and a strong plan for adaptation be developed (it will vary by individual). That requires extra time, cost and other logistical considerations, so not everyone is up for that but if you truly want to squeeze every last metre out of yourself, then that's what you should do.
As for track aerodynamics, I kind of know a little bit, given I'm a pioneer in the field of practical track aerodynamic field testing and optimisation and many years ago provided analysis and methodology tools for others to freely use if they want to do their own experiments, using both a "classical" field testing approach (as described by Coggan, Martin et al) and another (virtual elevation modelling as described originally by Prof Robert Chung) which morphed into the freely available Aerolab on Golden Cheetah and programmed by my friend Andy Froncioni. I've delivered many aero testing seminars to people from all around the world, theory and practical. I also do track aero testing and optimisation work for a living using technologies developed with my good buddies at Alphamantis and in now use by the AIS and several pro teams. I'll just leave it at that.
- Alex Simmons/RST
Postby Alex Simmons/RST » Wed Apr 22, 2015 8:29 am
Yes, just having these discussions is fun - bit of pub banter.CKinnard wrote:Anyway, I'm sure this event is going to generate a lot of interest.
As to what makes one go faster - that's pretty simple - it's a simple supply and demand equation:
i. increase available power
ii. reduce the resistance forces
and to win races, you need to add to i. "and use it wisely"
the challenge is what to prioritise, and that depends on your individual goals/objectives. If it's to enjoy yourself and have a bit of fun, then ride and eat what you like. Who cares if it's a $10 clunker or a $10k super rig? If the goal is to win championships, well the equation is somewhat different, that requires talent, hard work, discipline, motivation, experience and so on. And it will also involve minimising resistance forces through intelligent equipment and bike position choices.
Postby warthog1 » Wed Apr 29, 2015 5:31 pm
http://www.cyclingnews.com/news/dennis- ... nd-wiggins" onclick="window.open(this.href);return false;
- find_bruce
- Moderator
Postby find_bruce » Sun May 03, 2015 5:32 am
http://www.cyclingnews.com/races/alex-d ... 15/results" onclick="window.open(this.href);return false;
Postby CKinnard » Sun May 03, 2015 5:54 am
- Alex Simmons/RST
Postby Alex Simmons/RST » Sun May 03, 2015 8:04 am
Air density approx 1.16kg/m^3
- find_bruce
- Moderator
Postby find_bruce » Sun May 03, 2015 8:08 am
Dowsett knew that Dennis faded in the final quarter.CKinnard wrote:wow... he seemed to hold a very straight course. impressed with his self control to keep pace sub record for the first 50 odd minutes.
Much more consistent and fading in the final quarter hour which probably resulted from slight lift in pace half way. About a 25W drop towards the end compared with average. Well executed and shows the benefit of track preparation and thinking about how to better execute the pacing strategy (BMC contacted Xav to get our thoughts after Bobridge's effort).
- ldrcycles
Postby ldrcycles » Sun May 03, 2015 11:52 am
Tallies with Dowsett's comments that it wasn't as hard as he expected, and thinks he may have more.find_bruce wrote:The graph of Dowsett's effort posted above by Alex is impressive. Given the huge kick at the end, I wonder if he couldn't have gone out slightly harder. Easy for me to say but of course much, much harder to do
- Alex Simmons/RST
Postby Alex Simmons/RST » Sun May 03, 2015 12:19 pm
Dowsett listened to sound advice and executed very well.
- Alex Simmons/RST
Postby Alex Simmons/RST » Sat May 09, 2015 1:21 pm
- find_bruce
- Moderator
Postby find_bruce » Sat May 09, 2015 2:03 pm
It seems Wiggins is taking the more aggressive strategyAlex Simmons/RST wrote:Dowsett's strategy was to set a new world hour record, not to the ride the absolute most he could on the day. The latter objective requires a slightly riskier pacing strategy. Of course the two strategies can overlap, but not always. e.g. Voigt and Dowsett used this slightly more conservative and smart approach to set a record.
"It sounds a bit horrible to say but I could break the record tomorrow. But I don’t just want to break it, I want to put it right up there, as far out of reach as I can," Wiggins told The Times. "I've got 55km in my head and I think it’s realistic. And I think if I do it, it will stand for 20 years."
- ldrcycles
Postby ldrcycles » Mon Jun 08, 2015 6:21 am
- foo on patrol
Postby foo on patrol » Mon Jun 08, 2015 7:34 am
Foo
Goal 6000km
- find_bruce
- Moderator
Postby find_bruce » Mon Jun 08, 2015 8:16 am
Faded at the end, reportedly due to heat. Pacing graph from Alex's mate Xavier Disley
Interestingly Xavier estimates that the high air pressure in London cost Wiggins 490m
Postby GAV!N » Mon Jun 08, 2015 8:16 am
Return to “International and National Tours and Events”
